Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Feb 22, 2011 at 11:29 AM
    #681
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If your putting 4 quarts in, odds are, your not on a level surface. The rear diff capacity is listed as 2.91 to 3.01 quarts. Not "Fill until oil flows out of hole".
  2. Feb 22, 2011 at 11:59 AM
    #682
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    true but also
    Or person putting oil miscalculated,
    Or bottles had less oil then was written,
    or axle seals are shot
    or for some odd reason housing has more room then average.
    Thats why there is a
    So regardless what happened things have enough oil to work in.
    And if you fill until oil overflows then you are at 0 part of the above statement.
    I am just saying I would be much more worry having level too low then thinking I have 4 qt and up to the fill plug.:notsure:
  3. Feb 22, 2011 at 4:37 PM
    #683
    eckcessive
    eckcessive Well-Known Member
    Ken
    Gilbert, AZ
    in between Tacoma's
    Thanks Chris and Brian for posting something I'm sure for you guys is a no brainer. I'm hoping with my recent Tacoma purchase that I will do more of this type of maintenance myself rather than paying the dealership to do it.
    Let me post a few questions that were not covered very well... at least I didn't pull the info out of the thread very well...
    Q: I've got about 45k miles and I don't know if the previous owner changed the diff fluids or not, my guess is they probably didn't. I've seen references to using cheap oil to flush it out if it hadn't been changed in a long time... do you think 45k miles would require a 'flush out'?
    Q: I saw some references to changing gaskets, is that recommended or required or would I only do it if it was leaking? Not sure if I want to tackle this or not.
    Q: I saw references to new metal washers, but sounded to me like the oldies are still fine. Any problems with using the old ones?
    Q: My owners manual says my 2007 DblCab TRD OffRoad needs 1.1qt for Transfer case, 1.6qt for Front Diff, and 3.0qt for Rear Diff. Obviously 3qt for Rear is pretty easy but do I just estimate the 1.1qt and 1.6qt or do you break out a measuring cup or something. Is it important to be exact or just as close as you can get?
    Still trying to decide if I want to run regular or synthetic.
    Thx,
    Ken
  4. Feb 22, 2011 at 5:03 PM
    #684
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You shouldnt have to "flush" any of the old oil. A simple drain and fill is good enough. There are no gaskets you need to worry about. I've re used the plug washers, but your supposed to replace them. AS for the fluid amounts, you can aprozimate. for the ".6", use just a little bit over half the bottle, and for the ".1", use 1 tenth of the bottle.
  5. Feb 22, 2011 at 5:10 PM
    #685
    eckcessive
    Ken
    Gilbert, AZ
    in between Tacoma's
    Awesome... thanks for the quick reply.
  6. Mar 1, 2011 at 1:36 PM
    #686
    FTB530
    FTB530 Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    Well i filled my differaential cases to the fill hole, now i found my owners manual and it states 2.80 for the rear,1.5 for the front and 1.o for tranfer case ,so now im going to go drain them and see how much of i mistake i made.
  7. Mar 1, 2011 at 1:57 PM
    #687
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I dont have a factory owners manual. Does anyone know what the amount would be for the rear diff on a 2002 prerunner?
  8. Mar 1, 2011 at 2:22 PM
    #688
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Did anybody else have the front start dripping out right at the 1.5 mark? On all the others it did not happen that way.
  9. Mar 3, 2011 at 4:38 PM
    #689
    DblD
    DblD Well-Known Member
    Dave
    SW Missouri
    '18 DCSB TRD/OR - Prem. & Tech.
    Great information here. Thanks to all who have posted before me. I changed the Front and Rear Differential fluids today along with the Transfer Case. I couldn’t find any pictures of the Front Diff so I took a few as I was working.
    Here is the Front Differential as pictured from the driver’s side tire. The skid plate is removed in this photo.
    I couldn’t get enough leverage on the short 10mm Hex Key. An extension off a bottle jack handle helped get the drain plug loosened.
    I short length of tubing and a small hose clamp allowed me to have a cold beverage while the differential filled. Poke a hole in the top of the oil container to allow air to escape and speed up the process.
    For reference this service was done on an ’09 Dbl Cab 4x4 with the Off Road Package
    Front Differential capacity: 1.59 quarts
    Rear Differential capacity: 3.12 quarts
    Transfer Case capacity: 1.1 quarts
    dd
  10. Mar 9, 2011 at 12:27 PM
    #690
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    First, special thanks to Chris4x4, Brianr, DblD, & all the others that have contributed to this thread. Made it very clear and simple to complete the maintenance.
    Just did them all: Rear Diff, Xfer Case, Manual Trans, & Front Diff.
    One thing in particular to note: Don't put off the front diff! Mine was dirty as the rear diff; and the magnet had as much or more shavings on it as the rear.
    Granted, the winters up here have me engaging 4WD as needed for conditions more often than some, but I was still surprised at how dirty the front diff oil was.
    Additionally, a socket style (fits on socket wrench/breaker bar) 10mm hex key made the removal of the front diff plugs easy.
  11. Mar 9, 2011 at 2:10 PM
    #691
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Well i drained my rear diff again,because i filled to the fill hole the first time since i didnt have my owners manual, found the Om and it says 2.8 quarts,it did not hold 2.8 quarts before coming out the top hole,but close,im leaving it good at that going to drain the TC and front diff and see how close they are,if close next time ill fill to top hole again,I second the ratchet and hex head to get the front diff plugs out alot easier.
  12. Mar 10, 2011 at 7:19 AM
    #692
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I own a 96 tacoma it ask for 80-90. Is it ok to use 75-90 (for more MPG)? Or should I stay with the 80-90.
  13. Mar 10, 2011 at 7:19 AM
    #693
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    75-90 is fine.
  14. Mar 10, 2011 at 7:24 AM
    #694
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Nice, Thanks Chris
  15. Mar 10, 2011 at 7:30 AM
    #695
    Taco Erik
    Taco Erik Well-Known Member
    Erik
    Phoenix, ARIZONA 602
    2004 tacoma totalled, new 2005 Tacoma
    3" toytec coils with Bilstein 5100 shocks, camburg uca's, 1" AAL, Uws toolbox, 12" kicker sub system, flowmaster super 40s, more mods to come new build
    i live in phoenix chris i realized ur from az as well? i wonder if you knoiw of any off road meet ups that are going on with tacoma owners?
  16. Mar 10, 2011 at 7:31 AM
    #696
    Taco Erik
    Erik
    pm me if you know any?
  17. Mar 10, 2011 at 7:31 AM
    #697
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The AZ guys go off road sometimes, and post when in the AZ section. Check it out from time to time.
  18. Mar 10, 2011 at 11:13 AM
    #698
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    AHHH. One more question how tight should it be again.. 15lbs right. I think that's what I did on my 08.
  19. Mar 12, 2011 at 4:30 AM
    #699
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    So basically, just filling to the fill hole is fine then?
    I gotta check my user manual too, I am assuming I will need the LSD additive since mine is an 09.
    EDIT:
    Nevermind, I read the thread, no LSD needed, and I should fill the amount specified, not necessarily to the hole. Amazing what a little reading will do. :D
    Also wanna throw out there that dino oil is probably best, see this thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/145108-regearing-4-56-a.html
  20. Mar 12, 2011 at 4:14 PM
    #700
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    subd for future reference :)
    TW is awesome.
