Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 23, 2011 at 8:12 AM
    #721
    05SuperChrg
    05SuperChrg Well-Known Member
    SF Bay Area
    TRD Supercharger, TRD Air Filter,Rancho 9000's, Old Man,Fumoto Oil Drain Valve,Kenwood Sub, Sony HU,Wet Okole, debadged,satoshi,Slee Sliders
    Will it hurt if I accidentally put in the LSD additive with 75-90 Redline in a locker rear end? I have a TRD OR.
  2. Apr 23, 2011 at 10:42 AM
    #722
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It wont hurt anything.
  3. Apr 27, 2011 at 11:31 AM
    #723
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Thanks for a good writeup. It's probably in the thread somewhere, but I didnt read the whole thing. Any suggestions on a good synthetic? I purchased my current taco recently, and am transitioning to full synthetic. Also slight clunk ever so often when going in and out of 4wd. Is that normal?
  4. Apr 27, 2011 at 12:14 PM
    #724
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    ...I'm sorry but I didn't want to read through all 38 pages..I been wanting to change my differential fluid(bought the truck used in Jan. 09 @ 25k..now have 72k) so I went to all of my local auto store (o'reillys, baxter, napa) and all they have is 75w-90 with limited slip(All Valvoline with that weight is what they carry). I have an 05 TRD OR 4x4...can I use this or is this a big no no?
    They have a lot of synthetic 75w-90 in stock but I'm not sure if I can just drain the old fluids and fill it back up with the synthetic. Will that cause a problem if I went that route instead? Thanks in advance for the help/info.
    Joe
  5. Apr 27, 2011 at 2:04 PM
    #725
    JoeTacoma02
    Bump for tacoteacher and I.
  6. Apr 27, 2011 at 3:03 PM
    #726
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Read the thread :)
  7. Apr 27, 2011 at 3:14 PM
    #727
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Exactly.
  8. Apr 27, 2011 at 4:15 PM
    #728
    JoeTacoma02
    Soooo much reading :rain::sadviolin:
  9. Apr 27, 2011 at 4:28 PM
    #729
    JoeTacoma02
    Skimmed through it..found my answer..looks like I'm going synthetic. Thanks for the "How To" thread :)
  10. Apr 27, 2011 at 5:09 PM
    #730
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. Apr 29, 2011 at 7:05 PM
    #731
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    First off I want to thank those that started this thread and all that have posted...alot of great information!!! I just got done reading the entire tread for the 2nd time. It seems there's been different fill techniques discussed throughout the thread. Some say put the exact amount called out, other's say fill till it starts to drip out from the fill hole. I think either way is fine as long as the level is within spec.
    The amounts called out for the V6 4WD (1.1qt transfer case, 3.0qt rear diff, and 1.6qt front diff) are only "approximate" capacities according to the Chilton's manual. It says to add as necessary to bring to appropriate level which they say is at or near the bottom of the fill hole.
    The below instructions say to check that the oil level is "within" 5mm (0 to 0.20 in.) of the bottom of the filler plug opening. As I understand this it can be at the botton of the opening (zero) or up to 5mm (or 0.20 inch) below. It seems to me it would be alot easier to just fill till it starts to come out of the fill hole rather than trying to measure the "approximate" amount called out making sure the truck is on a level surface while doing so.
    INSPECT DIFFERENTIAL OIL
    (a) Stop the vehicle on a level place.
    (b) Remove the differential filler plug and gasket.
    (c) Check that the oil level is within 5mm (0 to 0.20 in.)
    NOTICE:
    • Excessively large or small quantities of oil
    may cause problems.
    • After replacing the oil, drive the vehicle and
    check the oil level again.
    HINT:
    If necessary, fill the rear differential carrier assembly
    with hypoid gear oil.
    Oil grade:
    Hypoid gear oil API GL-5
    Recommended viscosity:
    Above -18°C (0°F) SAE 90
    Below -18°C (0°F) SAE 80W or 80W-90
    Capacity:
    Differential carrier assembly front:
    1.45 to 1.55 litters
    (1.54 to 1.64 US qts, 1.28 to 1.36 lmp. qts)
    Rear differential carrier assembly:
    2WD: 3.26 to 3.36 litters
    (3.45 to 3.55 US qts, 2.87 to 2.95 lmp. qts)
    Pre, 4WD: 2.75 to 2.85 litters
    (2.91 to 3.01 US qts, 2.42 to 2.50 lmp. qts)
    (d) Check for oil leakage if the oil level is low.
    (e) Install the differential filler plug and a new gasket.
    Torque: Front differential carrier assembly
    39 N*m (398 kgf*cm, 29 ft.*lbf)
    49 N*m (500 kgf*cm, 36 ft.*lbf)
  12. May 1, 2011 at 11:39 AM
    #732
    JoeTacoma02
    So...did your guys drain plug fall into the jar/bucket as well or am I the only dumb ass that used my hand to take it off once loosen? This will be fun reaching in the jar :eek::smash:
  13. May 1, 2011 at 12:23 PM
    #733
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    :DLOL, Happens all the time when I do an oil change. Don't remember the diff change - it only every 30,000.
  14. May 1, 2011 at 12:36 PM
    #734
    2010nctaco
    2010nctaco Well-Known Member
    Blake
    Concord NC
    2010 trd sport 4x4
    Thanks for the write up. Did mine a couple of days ago. I dropped the nut in the waste jug too. Put in loucus synthetic. Can't tell a difference, but makes me feel better.
    I do have a question though, my truck only has 12,000 miles and I had some metal shavings on the magnetic plug. Is that normal?
  15. May 1, 2011 at 12:41 PM
    #735
    Slodgetto
    Slodgetto Über Posre
    Silas
    Lol. I do that pretty much every single oil change. I just pour the oil through a plastic sive so I don't have to reach in there to grab the plug.
  16. May 1, 2011 at 1:38 PM
    #736
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. THe next change the oil should be more clean.
  17. May 2, 2011 at 7:03 AM
    #737
    2_wheels
    2_wheels Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    I replaced the front, rear and transfer case yesterday and replaced thefront differential with Mobil 1. Now it bind’s up and won’t release fromafter being engaged in four wheel drive. When it does it has a loud clunk and I thoughtmy front end about fell out. Yes I double checked the fluid level just like the service manual suggests after driving. It took 1.6QT.
    I think I'll be switching brands of oil for the front!
    The rear I used Lucas + additive for the LSD and it's silky smooth again:)
    Also did the transmission and replaced the manifolds and catalyticconverters too since it wouldn't pass smog check couple weeks ago. Big weekendfor maintenance at 87K miles! My OBD tester says she's good to go now & no more check eng light!
    Oh- when you drop the plug either use a magnet or do like I do and always wearrubber gloves.....
  18. May 2, 2011 at 9:17 AM
    #738
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    What happens if you do neither? :confused: When I did mine, the plug fell into the stupid bucket, I just reached in with my bare hand and got it out. Of course the truck had been off for about 2-3 hours prior to the oil change.
  19. May 5, 2011 at 12:10 AM
    #739
    Claudio D
    Claudio D Member
    saugus mass
    09 4x4 2.7
    rubber bed mat undercover tonneau hitch step-bumper protector
    To every one who put up this great info a big Thank You! I just want to add that I lowered+removed the spare tire and that helped alot. Also used a floor jack and lifted each side to the max. I got every drop out this way. Place it under each end of the rear axle with a piece of 2X4 for extra lift and allow ample time so you get it all out. I have reg cab 4X4 2.7 so I used mobil one 75-90 full synthetic 3.12 quarts no additives. Last note I got 20080 miles and the old oil still looked perfect could have gone way longer I think and I have towed lots of firewood 1cord+ each time. Next will be Front Diff. TC and Trans.
  20. May 9, 2011 at 10:59 AM
    #740
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Thanks to Brianr and Chris4x4 for the how to. I got mine changed out this weekend. I had to spray the bolts with PB Blaster and tap them with a hammer to get the rust to break loose. Other than that everything went super smooth. I drained the diff. and then lifted both sides of the axle to make sure i got it all out. When i lifted the driver side more ran out. Just a small steady stream for a few minutes. when i lifted the passenger side. Nothing came out. I cleaned off the drain plug magnet and put on new crush washers just for peace of mind. Filled with 3 quarts of 75w-90 Amsoil gear lube. Nothing cam out of the fill hole. Torqued the bolts to 36ft. lbs! :headbang:
    Can't really tell a difference in the way it drives, but i know the fresh oil is waaaay better than what was in it. The magnet had a lot of wear metal on it. I don't think any more could stick to it. Now on to the front diff. and transfer case. :woot:
