Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. May 23, 2011 at 5:31 PM
    #741
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
    Okay, I read through this thread and saw a question asked twice that I have. I have a 2009 reg cab and the manual says the dif uses 75-85W GL5. I ordered some from redline but I was wondering why 75-85 instead of the more std 75-90?
  2. May 23, 2011 at 5:57 PM
    #742
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
    I have another question. What does the forum think about putting anti-sieze compound on the plugs to make them easier to loosen the next time?
  3. May 24, 2011 at 3:26 PM
    #743
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I've always used it for the reason you give - to make it easier to loosen the next time - they are 2 different metals. That being said I've read that Toyota does not recommend it. I'll do it anyway on my truck because it works.
  4. May 24, 2011 at 11:41 PM
    #744
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    If you use any anti sieze or some type of lubricant you would half to multiply your torque rating by any where to .45 to 1.70. This all depends upon the type of lubricant or what grade of bolt you are using. This is to adjust for the lubricants to get the same amount of torque. This info I have found in a small hand held book called"Pocket Ref" by Thomas J.Glover. It is a fourth edition reference book with just about any thing you might need or want to know. I bought it off Amazon.com
  5. May 26, 2011 at 8:29 PM
    #745
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Will be doing this on the weekend,
    1. What amount of oil do I need for the transfer case?
    2. What amount of oil do I need for the front diff?
    3. Is the oil the same for all 3? (Front/Rear Diff & T-Case)
  6. May 27, 2011 at 12:24 AM
    #746
    george3
    New Jersey
    I have a 2.7 but I would think the 4.0 would be the same oil wise. I used the same back to front and just put it in till it started to come out. No problems. I've always done it this way.
  7. May 30, 2011 at 11:53 PM
    #747
    BIG MoFukin SERG
    BIG MoFukin SERG Well-Known Member
    Serg
    Los Angeles
    '09 MGM TRD Off Road
    5100's set at 2.5", Blacked-out badges, CB, Drop-in K&N
    Thanks for the great write-up guys...did this yesterday and it was almost too easy :D
  8. Jun 6, 2011 at 2:26 PM
    #748
    BigSteve
    BigSteve So-Cal Member
    California
    06' White Tacoma PreRunner
    Magnaflow exhaust, K&N cold air intake, Pioneer 4100 headunit w/ usb i-pod connection, 12-inch sub and 600 watt amp, tint, LED dome lights
    I tried to search this tread the best I could, but only kept finding mixed answers so...
    I have a 2006 prerunner tacoma with the TRD off road package. I know it has a locking rear differential that I can operate from inside the cab, but is this considered an LSD?
    In other words, what I am trying to figure out is if I need to add a LSD additive OR do I just use regular 75-90w gear oil?
  9. Jun 6, 2011 at 3:03 PM
    #749
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Regular oil is fine. No addative needed.
  10. Jun 6, 2011 at 8:51 PM
    #750
    beckleyota
    beckleyota Well-Known Member
    wv
    o7 taco
    vent visors,tint,kenwood headunit, trex eyelids,kenwood componants,5100's,1 aal,cabellas seatcovers,painted stereo suround
    i got my dino oil fron napa and the had the exact oil listed in ther owners manual word for word on the bottle but mine took 3 1/2 till it overflowed drove it a little and checked it agin none came out ( truck is a 07 2.7 4x4 lsdrear)
  11. Jun 6, 2011 at 10:54 PM
    #751
    BigSteve
    California
    Thanks Chris
  12. Jun 20, 2011 at 10:29 AM
    #752
    STeeCHfinger
    STeeCHfinger Member
    This is a great write up and with pic even, I read like 15 pages and said screw it...I have a 02 prerunner TRd with I believe its the electronic locker? It has a button that says RR diff lock. Im new to Toyota's, Ive always had ford and Chevy's so im used to fixing things. I want to use PR but i want to get the right stuff.
  13. Jun 23, 2011 at 8:41 AM
    #753
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    My dad's 1964 Chevy half-ton has over 500,000 miles on it (not sure of the exact mileage, speedo cable gave out for a few years). The truck is on it's 3rd engine. It still has the factory oil in the transmission and the LSD. All he's ever done is put more LSD additive in it. I cringe when I think of what it must look like inside the transmission and differential housing. I can't convince him that the godawful whine while at speed is due to failed lubrication. Needless to say I'll be changing all of my gear fluids at the proper intervals. Thanks for the writeup!
  14. Jul 10, 2011 at 9:48 AM
    #754
    greatfuldead
    greatfuldead Active Member
    central ohio
    2010 accesscab 5sp 4cyl
    none yet
    Is the torque the same on the front diff. drain-fill plugs as the rear, 36 FT-LB? Also theres no grease fittings on the front drive shaft slide yoke any info would be welcome. Thanks! This is the place to go for Taco Info
  15. Jul 10, 2011 at 10:30 AM
    #755
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The front drain plug is 48#, and the fill plug is 29#
  16. Jul 14, 2011 at 12:58 PM
    #756
    JimT
    JimT Active Member
    Jim
    Indiana
    2016 DCLB TRD Offroad
    Did this about a week ago with around 45k on the truck. OEM oil was positively black!
  17. Aug 4, 2011 at 2:57 AM
    #757
    george3
    New Jersey
    Wonder if a little antisize on the plug threads would make it easier next time.
  18. Aug 4, 2011 at 12:42 PM
    #758
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  19. Aug 4, 2011 at 12:48 PM
    #759
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    great write up guys. so what is the final say on changing these 15,000 or 30,000? Is it just personal preference?
  20. Aug 4, 2011 at 2:02 PM
    #760
    george3
    New Jersey
    I never measure anything. I just pour it in the top til it comes out the bottom. Never had any problem. I do the same with the front dif - transfer case - trans etc if I remember correctly. If it has a drain low and a fill high that is what I do. I think the important thing is to change it on a timely basis.
