Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Mar 13, 2009 at 11:24 AM
    #61
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I went to my dealer and asked for the LSD additive and he said the Toyota doesn't make the additive they just buy it from Car Quest. He showed me the bottle which was this 7oz bottle but I noticed in your picture that your dealer gave you this the 4 oz bottle. I wonder what the difference is?
    EDIT...
    I emailed the company and this is the response I got:
  2. Mar 16, 2009 at 4:07 PM
    #62
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    OK, so i just drained my fluid and there was a little spring on the drain plug magnet. Truck has 73k miles and this is the first time for it to be changed. Doesn't have LSD or anything just v6 4x4. The spring is approx 1/2" long and really weak. Any ideas? Since it has been this long just fill it up and go on? Never any issues with the truck.
  3. Mar 16, 2009 at 4:25 PM
    #63
    BIGLuke
    BIGLuke I'm a TW addict!
    Luke
    Chicago suburbs IL
    07 4X4 tacoma SR5 Double Cab Shortbed Speedwy
    ok i feel like an idiot asking this but can someone tell me how do i know if i have the lsd??? i've got an 07 4x4 offroad eddition
  4. Mar 16, 2009 at 4:28 PM
    #64
    j0sh
    Oklahoma
    '10 TRD Sport 4x4
    look at the pictures. It should have a sticker showing LSD or not.
  5. Mar 16, 2009 at 4:34 PM
    #65
    harshest
    Michigan
    05 PreRunner SR5
    I believe the offroads have a locker and the sports have the lsd
  6. Mar 16, 2009 at 4:42 PM
    #66
    BIGLuke
    Luke
    Chicago suburbs IL
    so would you happen to know if i need to use the additive if i have the locker??
  7. Mar 16, 2009 at 4:50 PM
    #67
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    no add for locker i did my truck and silversevens truck which has a locker no add for the locker.
  8. Mar 16, 2009 at 4:54 PM
    #68
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    Hey guys, good write up but....
    You forgot to add a very important part to your list of required items.
    Qty. 2 Drain and fill plug gaskets Part Number 12157-10010
    They are metal crush gaskets that get flattened to seal between the plug and the housing. The more you reuse them the greater the chance to overtorque and crush them, eventually they will crack/leak/loosen.:eek:
    You can see the shiny metal ring in one of your pictures, on the plug.
    They are like a buck or two at the dealer, I bought two when I did mine back in November.:)
  9. Mar 16, 2009 at 4:56 PM
    #69
    BIGLuke
    Luke
    Chicago suburbs IL
    awesome thanks. am gonna try to get the royal purple if i can get it at the auto store
  10. Mar 16, 2009 at 4:57 PM
    #70
    harshest
    Michigan
    05 PreRunner SR5
    My 05 didn't call for any? My dealer looked up my parts by my VIN and said I didn't need any, I specifically asked if I need them too.
  11. Mar 16, 2009 at 4:58 PM
    #71
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    Cool that will work. It a pretty easy job. I still need to do my front.
  12. Mar 16, 2009 at 5:15 PM
    #72
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I checked on this, and everyone said no washers were needed. I have always re used the one on the vehicle, and never had an issue. Good to know that there is a replacement though. Thanks. :)
    TacomaCZman likes this.
  13. Mar 16, 2009 at 6:43 PM
    #73
    j0sh
    Oklahoma
    '10 TRD Sport 4x4
    upon further looking at the "spring" it turned out to be a piece of metal shaving :D
    since it went so long without changing the fluid, I bought some cheap gear oil at walmart, ran it through for a couple miles, drained it then filled it with Lucas.
  14. Mar 16, 2009 at 6:56 PM
    #74
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    If I can be so bold as to add to the instructions here, when I did mine I put a floor jack under the right rear spring seat and lifted that side of the truck up about 8 inches. Quite a bit more old fluid ran out. The drain plug isn't in the center of the diff, not sure why, but stands to reason the stuff that gets left behind if you don't tilt the axle would be the thicker nastier crap.
    bkrdave36, Huzie11, Kricci1 and 3 others like this.
  15. Mar 16, 2009 at 6:57 PM
    #75
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I tried this, and no more oil came out.....Was your truck on level ground?
  16. Mar 16, 2009 at 7:00 PM
    #76
    HerNameIsLucy
    RIP Lucy.
    Yup. Quite a bit more came out. I had just driven up to get the diff lube so there might have been a lot in the axle tube too. Hmm...I should have lifted the left side too...
    Stryker420 likes this.
  17. Mar 16, 2009 at 7:04 PM
    #77
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I usually change mine "cold". Not sure how much satys in the axel, but I cant imagine much would. I have noticed that the plug is off centered a bit, but its pretty flush with the bottom on the inside of the 3rd member.
  18. Mar 16, 2009 at 9:19 PM
    #78
    BIGLuke
    Luke
    Chicago suburbs IL
    went to the auto store and the rp was $17 a bottle. I thought that was too much so decided to go wit lucas gear oil. the job its self was realy easy, the only thing that was kinda agravating was putting the oil back in it took forever. now i didn't notice much difference if any but maybe it will take a lil time. thank you all for the help and chris' write-up made it very very easy. thanks again .
  19. Mar 16, 2009 at 9:20 PM
    #79
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help. :)
  20. Mar 17, 2009 at 5:23 AM
    #80
    j0sh
    Oklahoma
    '10 TRD Sport 4x4
    Does the front take the same fluid? And how much?
