Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Feb 12, 2012 at 12:38 AM
    #901
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    Okay guys question:
    Where is the front diff drain/fill plug located for Manual Trans? I changed the Trans/ Rear diff but not the front....sorry for the questions I'm a n00b
  2. Feb 12, 2012 at 12:52 AM
    #902
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    This should help: http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    Basically go in from the drivers side along the front axle and you'll find the front diff. The pics in the attached should help. Don't be sorry...I was there last year when I did mine the first time! :cool:
  3. Feb 12, 2012 at 12:54 AM
    #903
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
  4. Feb 24, 2012 at 5:52 PM
    #904
    Frankoo1234
    Frankoo1234 Well-Known Member
    OC
    Double Cab 05 Taco PreRunner
    Running boards, Tint
    I dont know if this has been adressed i tried searching but couldnt really find how the answer.. i changed my rear diff oil for the first time (in my life and the life of the truck possibly) and first off the nuts were hard as heck to take loosen mainly the drain plug.. after PB blaster a couple knocks with the hammer it came loose.. when i unscrewed the fill lug a bunch of air pressure came out... Is that normal? or is my breather not working propperly?
    Sorry iam a noob..
  5. Feb 24, 2012 at 5:56 PM
    #905
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Normal. Heat is going to slightly preasurise the diff.
  6. Feb 24, 2012 at 9:12 PM
    #906
    Frankoo1234
    OC
    Ok thanks Chris!
    Thanks you guys guys ive learned a load of things! really do appreciate it
  7. Feb 25, 2012 at 1:00 AM
    #907
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    *pressurize*
    :p Lucky you're good w/ numbers and building/fixing stuff! ;) :D
    Sorry man...:bored: ... not much going on at work tonight. :)
  8. Feb 25, 2012 at 6:32 AM
    #908
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek:
  9. Feb 26, 2012 at 11:44 AM
    #909
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I just finished doing both differentials and the TC this AM. Easy as pie- thanks for taking the time to prepare this tutorial!
  10. Feb 26, 2012 at 12:52 PM
    #910
    desertrock
    desertrock Well-Known Member
    Keoni
    El Paso, TX / Fountain, CO
    Tacoma TRD Off Road
    ToyTec Adjustable Coils W/Bilstein 5100's, Lower front Dif Kit, Rigid Industries Dually s, Throttle body spacer, ARB Front Bumper (some mods), ALL Pro Rear Bumper, Rear Expedition Leaf Springs, Rock Sliders, upgraded Tie Rods, Budbuilt fuel tank skid plates, KN Cold Air intake, Warn HID Lights-4", Banks CatBack Exhaust, Total Chaos UCA, AllPro Transfer Case Skidplate, 886 Rear backlight mod, rock lights, TRD Hawaii Off Road decal (sockmonkey), Garage built Tire Carrier.
    strange, just changed my rear diff oil and put about 3.5 qts in. Normal?
  11. Feb 26, 2012 at 2:42 PM
    #911
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. You should have only put in 3.
  12. Feb 26, 2012 at 5:52 PM
    #912
    grivera
    Hanover, MD
    Mine may have taken a littte over 3 quarts. I let it sit for a while and then drove it about 50' before topping it off again. The 3+ quarts includes a tube of TransX LSD additive (7oz tube). The gear oil I used is Valvoline 80/90 Dino for LSD.
  13. Feb 27, 2012 at 4:08 AM
    #913
    desertrock
    Keoni
    Tacoma TRD Off Road
    I used Lucas, haven't read anywhere about the possibility of overfilling the differential nor hurting the diff if overfilled. Read everywhere to fill untill fluid comes out of the fill hole.
  14. Feb 27, 2012 at 2:25 PM
    #914
    neilc
    neilc Member
    Neil
    massachusetts
    2009 tacoma 4x4 sport
    brush guard,step up rails
    ya just came back from dealer they want 91$ per bottle,i think it takes 2 or 3 quarts i don't know if you you buy their oil it alreadt has has the additive
  15. Feb 27, 2012 at 6:09 PM
    #915
    grivera
    Hanover, MD
    I bought my oil on-line from Advance Auto Parts (on-line, store pick-up option) using an online coupon for $20 off. The total for 6 quarts of gear oil and the LSD additive was about $35. The Valvoline gear oil is for LSD differentials but posts on here indicate it's not quite enough so additional additive is recommended...
  16. Feb 29, 2012 at 5:44 PM
    #916
    beckettisgod
    beckettisgod Well-Known Member
    Vermont
    '09 TRD Sport Barcelona Red
    Fog light anytime mod, Black lower valence, In-channel AVS Ventvisors, drop-in K&N filter so far...
    Is it ok to add the LSD additive after the fact? Like say 3,000 miles later?
  17. Feb 29, 2012 at 5:45 PM
    #917
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Should be ok.
  18. Feb 29, 2012 at 5:51 PM
    #918
    beckettisgod
    Vermont
    Cool, thanks.
  19. Mar 1, 2012 at 9:59 AM
    #919
    neilc
    neilc Member
    Neil
    massachusetts
    after reading and posting i get several different messages hear,my 09 sport 4x4 6 cyl with no lsd sticker on the rear diff,but does have the box on the passenger side with all the lines coming out,i have a botton on the dash which shows to engage lsd but still don't know wether i need to add lsd or not were i have no sticker on the rear diff housing i guess i don't need it,too much contrudiction on this write up,dealer says take out fill pug if fluid is red its lsd,brown no lsd needed
  20. Mar 1, 2012 at 10:31 AM
    #920
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    No additive needed for '09 and up. It uses the brakes for the LSD not the mechanical clutches that the older models have.
