Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 1, 2012 at 8:52 AM
    #941
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    Sounds good to me...doing it today!! Will update on how fluid looked at 30k miles
  2. Apr 1, 2012 at 10:18 AM
    #942
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Well I drained the fluid and I must say it looked pretty good after 30k miles like new nice gold color....I wonder if the original owner had it done before I bought it at 26k miles...there was a WHITE dot and slash on the fill plug...wonder if that means the dealer did it....either way the fluid is changed again...the drain plug was gunked pretty good with shavings...all done
  3. Apr 2, 2012 at 1:35 PM
    #943
    Gabe911
    FLORIDA
    10 PreRunner MGM
    The "LS" only means its safe for use in a Limited slip diff....It has no friction modifyer in it. So yes i just put the same in my truck which has the rear diff locker...but no LSD sticker on rear pumpkin....I used Mobil 1 but...Valvoline is a good product as well...go for it you have the right fluid
  4. Apr 2, 2012 at 3:41 PM
    #944
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... Sub'd ... :popcorn:
  5. Apr 2, 2012 at 5:38 PM
    #945
    Gabe911
    FLORIDA
    10 PreRunner MGM
    If you have a LSD then you can use this ..but you will need to add the 4oz tube additive...this product is safe for both rear-ends...limited slip diffs have clutches in it, and requires a "limited slip" lube additive. The "locking" rear is different "locking diff" must either be mechanically, electrically, or air activated and does just as it's name implies--it locks--no clutches!......someone else can chime in...but the fluid is good to go IMO
  6. Apr 3, 2012 at 2:00 PM
    #946
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can use any gear oil in a LS diff that meets the Mfr recomendations. The "LS" on some bottles is simply a marketing strategy.
  7. Apr 3, 2012 at 2:40 PM
    #947
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What about this from RP's website?
    "Max Gear is formulated with a friction modifier additive – no additional additives are necessary."
    or from DetroitTuned
    "All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary."
    Granted it's $10 more expensive than Mobil1
  8. Apr 3, 2012 at 2:42 PM
    #948
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Apr 3, 2012 at 5:14 PM
    #949
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    The front diff you want to remove the allen key bolts, fill hole before drain hole. I believe its a 10mm allen wrench you need. Mine was stuck on pretty good from factory as well. I laid on my back and braced my feet against the front tire and pulled on the allen wrench till it broke free. After that i could spin it with my fingers easily. They torque them on pretty good at factory thats for sure.
  10. Apr 6, 2012 at 2:49 PM
    #950
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  11. Apr 7, 2012 at 10:10 AM
    #951
    Jared07
    Jared07 Member
    Jared
    Georgia
    07 Tacoma SR5 4x4
    Walker Evans Race Shocks
    How much goes in the rear diff exactly?
  12. Apr 7, 2012 at 12:54 PM
    #952
    Gabe911
    FLORIDA
    10 PreRunner MGM
    depends on your rear...check your owners manual...most get 3 qts or a smidge more
  13. Apr 9, 2012 at 4:35 PM
    #953
    PeachEater81
    PeachEater81 Well-Known Member
    San Gregorio
    2005 Tacoma DCSB TRD Sport 4x4
    Icon C/O, Icon 2.0 Resi's, LR UCAs, Alcan 8 leaf pack, Aero 2525XL, Michelin LTX MS2, Lifetime LED heads and fogs (bad company and product - don't buy), aFe Pro Dry filter, Weathertech mats, Best Top, Hybrid Audio, Arc Amp, Arc Sub, Ram matting, Core/Hurst Short Throw Shifter, OEM Bed Mat, Antenna X....
  14. Apr 9, 2012 at 5:00 PM
    #954
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
  15. Apr 9, 2012 at 10:46 PM
    #955
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes, you have the mechanical Limited slip and you will need friction modifier.
    Amsoil Severe Gear already has friction modifier in it - I've used it in our Corvette. Don't forget to do tight 8 circles in both directions many many times to get the oils worked into the clutch paks. If you still have chatter - you may need to add more friction modifier.
    I had to add 2-4oz bottles (Ford XL3) in mine with Mobile 1 75W-90.
  16. Apr 9, 2012 at 10:56 PM
    #956
    mytacoma08
    mytacoma08 Member
    Brandon
    Austin, Texas
    O8 Tacoma Prerunner TRD Sport 6ft bed
    Great write up. I changed mine when I reached 40K
  17. Apr 10, 2012 at 8:46 PM
    #957
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I need to do this soon.
  18. Apr 10, 2012 at 8:51 PM
    #958
    wolverine8
    wolverine8 Well-Known Member
    MV
    06 Sport 4X4 - SR5
    Stock
    I did this last week, very easy to do thanks to the clear write-up by the OP & info posted by Chris4X4. Thanks guys!
  19. Apr 13, 2012 at 7:28 AM
    #959
    TruckerRich
    TruckerRich Member
    Rich
    Redding, CA
    05 Tacoma 4 dr
    Well I guess I have some work to do... We traded our Camry to my my stepson, for his Tacoma and he had never changed the gear oil or trans fluid or spark plugs either... Both are 2005's the Tacoma has 160k on it, the Camry about 65k...
  20. Apr 13, 2012 at 9:50 AM
    #960
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :eek: you might have come out on the worse end of that deal
