Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 14, 2012 at 6:42 AM
    #961
    TruckerRich
    TruckerRich Member
    Rich
    Redding, CA
    05 Tacoma 4 dr
    It's a great truck, runs real good. Engine oil changed regularly… The wife only drives it a few miles to work and back.
  2. Apr 15, 2012 at 8:27 AM
    #962
    Phrendo
    Phrendo Member
    Austin, TX
    09 Sport
    Could the main page be edited to note that 2009+ Sports do not necessarily have LSD? It took me forever to read through this, though realistically 'bend over and look under the back of the truck for the sticker' is probably the best method for checking. Could also note the Torque for each bolt, which I think is 36ftlb.
    2009 Sport, Valvoline 80w-90, No additive, changed at 30K.
    All in all it took me 30 minutes, most of that was pumping. Oil came out clear gold, with little on magnet and I tow 4000 pounds fairly often.
    It took around 3.3 Qts to hit the overflow. Does that sound like to much? I think I may go warm up the oil, then see if it will drain any more.
    Thanks for all of the great info.
  3. Apr 15, 2012 at 8:30 AM
    #963
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Edit made. The manual calls for 3 quarts. Not more. Over filling the diff can cause the oil to cavitate, thus causing the gears to over heat.
  4. Apr 15, 2012 at 5:02 PM
    #964
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Newbie here, this is a great forum. Took care of this today. The Fill hole bolt was a real SOB. Had to get some PB Blaster and a breaker bar to get it off. I would recommend you take the spare tire off it gives you tons of room to work. Filled mine up with Mobil 1 Syn 75-90. I have a 2010 Tacoma TRD Off Road V6.
    Thanks for the information!
  5. Apr 15, 2012 at 7:08 PM
    #965
    TruckerRich
    TruckerRich Member
    Rich
    Redding, CA
    05 Tacoma 4 dr
    Thanks for the great instructions. I used Lucas synthetic 70W-90 it said no need for LSD as it contains all need additives. I bought 4 quarts for the extra 4 oz. I'll let the wife drive it and I'll check the level next week. As far as I know it the first change at 155k. I also changed the spark plugs and cleaned the TB and Mass Flow sensor.
  6. Apr 16, 2012 at 7:14 AM
    #966
    TruckerRich
    TruckerRich Member
    Rich
    Redding, CA
    05 Tacoma 4 dr
    My rear end had an LSD sticker on it as shown in the pictures in the step by step instructions. Fluid had a redish tint to it.
  7. Apr 16, 2012 at 9:56 PM
    #967
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    so if you have a 05 you need to add the LSD additives? and thats only when ur changing the rear diff? dont need lsd for the front diff or t case?
  8. Apr 16, 2012 at 10:03 PM
    #968
    Muscles
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    oh ok thanks ill have to look for it :D
  9. Apr 17, 2012 at 2:43 AM
    #969
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    This was a great write-up, Chris! Just completed this at 30K. I'm one of the people that was able to pump in close to 3.5 quarts of oil. After reading the thread, looks like a few others had the same experience. I used a breaker bar and the bolts came off with ease. Thanks again for saving us some $$ and teaching us something.
  10. Apr 17, 2012 at 9:57 AM
    #970
    Phrendo
    Phrendo Member
    Austin, TX
    09 Sport
    Did you see this comment by chris4x4? I overfilled mine as well, but went back after this comment and redid the entire process with Royal Purple (Expensive). 3 quarts straight.
  11. Apr 20, 2012 at 5:11 PM
    #971
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    I read through most of the pages in this thread and got confused in terms of needing to add the additive or not. In the first post by the OP, brianr, his sig shows that he has a 2010 and in the pics he is adding the Equa Torque additive. However the edit made in the post notes that 2009 and newer trucks do not need to add the LS diff additive. :confused::confused::confused::confused:
    I have a 2009 SR5 v6 4x4 non TRD/OR and I do have the LSD sticker on the rear. So do I need the additive or not?
  12. Apr 20, 2012 at 10:26 PM
    #972
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have this sticker???
    Do you have these buttons?
  13. Apr 20, 2012 at 10:26 PM
    #973
    Muscles
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    hmm wierd from my understanding it was 09 and up didnt need it so i dont see why ud have a sticker...but i would just add it just to be on the safe side it wont hurt anything
  14. Apr 20, 2012 at 10:44 PM
    #974
    Janster
    Jandy
    Lancaster, PA
    This is something to try.....and my mind is a little foggy, so perhaps someone else can confirm or deny this...
    Jack up the rear of the truck and put it in neutral (chock the front wheels).
    Spin one of the tires by hand....
    If the other tire spins in the OPPOSITE direction, then you have a mechanical LSD and NEED friction modifier.
  15. Apr 21, 2012 at 4:23 AM
    #975
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    You have that backwards. If your checking for a mechanical LSD, when you jack the car up and the tires spin in the opposite direction then you have a open diff. If they spin in the same direction then you have LSD. Keep in mind the trucks that use E-LSD will have an open diff and spin in the opposite direction.
  16. Apr 21, 2012 at 6:57 AM
    #976
    Janster
    Jandy
    Lancaster, PA
    I have the mechanical LSD and I'm pretty sure mine spins opposite (and why I mentioned it).
  17. Apr 21, 2012 at 7:05 AM
    #977
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Weird. Ive got open diff with locker... Tires spin opposite.
  18. Apr 21, 2012 at 7:49 AM
    #978
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine spin the same direction. My open diff on my 2000 did the same thing. This isnt an accurate way to determin what rear you have.
  19. Apr 21, 2012 at 11:14 AM
    #979
    Muscles
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
  20. Apr 21, 2012 at 12:00 PM
    #980
    boshak
    AG
    CA
    Im not sure which forum I read this but the dealership quoted someone $250 for all 4x4 fluids.
