Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 21, 2012 at 12:18 PM
    #981
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Last I checked, they wanted about 89 bucks, but Im sure that varies from dealer to dealer.
  2. Apr 21, 2012 at 12:37 PM
    #982
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    so im savin like 30 bucks not bad :)
  3. Apr 21, 2012 at 4:25 PM
    #983
    dmb
    dmb Well-Known Member
    Boise, ID
    Great write-up. I changed my rear diff fluid today and it was a a piece of cake...besides the fill-plug not wanting to come off. Had to put the big vice-grips on it. Feels good to do your own work and save some $$.
  4. Apr 21, 2012 at 6:18 PM
    #984
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    OK - gotcha thanks. :rolleyes: Guess I missed that comment. Removed about 1/3 quart. The manual called for 3.12 quarts.
  5. Apr 21, 2012 at 6:43 PM
    #985
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I don't get it...as long as your on a level surface how can you overfill? Toyota put the fill hole at that location for a reason...you fill until it starts to drain out of the hole. The amounts given in the owners manual are the same called out in the Chiltons manual. They say the capacities called out are "approximate" and to add as necessary to bring to appropriate level.. which they say to be at the bottom of the plug opening. In addition the Toyota Factory Service Manual calls for the level to be within 5mm (0 to 0.20 in.) of the bottom of the filler plug opening.
    For those that don't fill till it starts to drain out the bottom of the filler plug hole and just add the specified (approximate) amount called out how do think your suposed to check the level inbetween gear oil changes...you remove the fill plug and verify the level is at or within 5mm of the bottom of the hole.
  6. Apr 21, 2012 at 6:50 PM
    #986
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    good job guys.... nice write up... my only question is should I do this step:
    (for you guy like me w/ the Sport model, you'll need a 4oz. tube of LSD additive).
    if I have a trd 1st gen... I know what it says but I guess the better stated question is could ... would it be a good thing....????
  7. Apr 21, 2012 at 7:13 PM
    #987
    chriss
    chriss Well-Known Member
    chris
    I'm having a problem understanding how the level affects cavitation. The spinning gears do induce a significant amount of aeration. Cavitation though?
    As long as there is sufficient air space and an adequate vent it should be fine.
  8. Apr 21, 2012 at 8:21 PM
    #988
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    This.
    Most OEMs will tell you to fill until level with the fill hole. That's pretty standard.
    Overfilling can cause excess heat build up (due to excessive aeration/cavitation, for our purpsoses it's the same thing, which causes metal to metal contact resulting in heat build up) , but filling to level with the hole isn't over filling. Though some may have trouble believing that, most OEMs will agree.
    Edit: If you have rotated your axle with the use of axle shims this won't be exact. Then again if you're lifted with new springs it might have tilted your axle anyway. I would just follow the general idea of 3 qts and get it close to the fill hole whether you're under 3 qts slightly or over slightly.
  9. Apr 23, 2012 at 5:45 AM
    #989
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    I had a question here,although I'm pretty sure I already know the answer. I've seen quite a few posts saying " I don't use my 4WD very often so the fluid in the front diff should be ok. " Correct me if I'm wrong,but everything inside the front diff still turns when you're moving whether or not the 4WD is engaged. The power disconnects at the transfer case,so mileage is mileage on both diffs regardless of how often you use the 4WD correct?
  10. Apr 23, 2012 at 7:50 AM
    #990
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You are correct.
    Gears inside the front diff are spinning at all times - when you have ADD (automatic disconnecting differential).
    The only time they are not spinning, is with manual hubs.
    If you DO NOT have to turn a dial on your front wheels, then you have ADD
  11. Apr 29, 2012 at 7:19 PM
    #991
    redes
    redes Well-Known Member
    Central Texas
    4x4 TRD Offroad
    double car seat mod
    Thank for the write up and all the advice here. I did the front, rear and transfer case today.
    Easy job, took a little time, and the gear oil smells awful, but not a very hard job.
    I did go out a pick up an 18" breaker bar and was able to loose all the plugs very easily. Only the fill plug on the front diff was tough because I did not have clearance to use the breaker bar there. My ratchet did a decent job though my knuckles may disagree with that.
    The truck has 25k on it and the front and rear diffs were both very dark with some gunk built up on the magnet in the drain plug. The front had a bit lighter color to it, but it was still pretty dark. The transfer case oil looked dirty, but was still translucent. In the future I may wait a little longer on the changing the oil there.
    BTW: is there any reason I couldn't use anti-seize on the fill and drain plugs to make future removal easier?
    Thanks for all the wisdom here, I really appreciate it.
  12. May 3, 2012 at 11:27 AM
    #992
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I'm changing the fluid in the diffs this weekend. I just wanted to make sure i get his right, I have just about read all 51 pages of this thread and it appears there are a lot of people with the sport model. So I have a 2010 with the TRD off road package with the e locker and no LSD sticker on the rear. What I am getting is there no additive needed?
  13. May 3, 2012 at 11:33 AM
    #993
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont need the addative.
  14. May 3, 2012 at 12:04 PM
    #994
    jrzyshore
    Scott
    SNJ
    That's what I thought but I wasn't a 100 percent sure. Thanks Chris.:)
  15. May 4, 2012 at 12:37 PM
    #995
    kcinga
    kcinga Member
    Middle GA
    09 TRD Sport 4x4
    Nav/DVD unit, Magnaflow exhaust
    okay, so i have read pretty much everything and i know that i do not need the LSD additive in the rear diff. However, am I okay to run mobil 1 75-90 LS in the rear diff? It appears that it is okay, but is there anyone out there that thinks this is a bad choice and will cause issues? Thanks!
  16. May 4, 2012 at 12:42 PM
    #996
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It's a good choice.
  17. May 5, 2012 at 4:09 PM
    #997
    Muscles
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    did my rear diff fluid today, was a biiiiiiitch haha. the plugs were on supppper tight i had to use a impact wrench to get it off. Then there was wind out of no where blowing my oil all over my drive way haha. Well atleast i found out what not to do.
    The oil looked really good......looked brand new almost but i have put about 20k miles on the truck since i bought it......
  18. May 5, 2012 at 7:15 PM
    #998
    kcinga
    kcinga Member
    Middle GA
    09 TRD Sport 4x4
    Thank you sir!...I did the spark plugs too, thanks to the awesome step by steps from TW. It sure does feel good saving that $$ by DIY.
  19. May 5, 2012 at 7:29 PM
    #999
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    great to hear!
  20. May 6, 2012 at 2:39 PM
    #1000
    david75
    david75 Member
    david
    ringgold,ga
    1998 tacoma reg cab 4x4 2.7 225,000 miles
    k&n filter
    what kind of rear diff does a 1998 4x4 2.7,reg cab have in it and does it need the additive?and how much does it hold
