Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. May 16, 2012 at 8:22 AM
    #1001
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    This might be a dumb question, but I was at autozone yesterday and bought gear oil to do both my front and rear differential. At the time, for some reason I didn't think I had the Limited slip differential, so I just bought regular synthetic 75-90W gear oil. To my dismay, I looked under the truck and scraped away some dirt and found the "LSD Oil Only" sticker. DOH! Thinking back to the parts store, there were bottles of gear oil that said "LSD Gear Oil" in various weights, which I steered away from at the time because of my ignorance. I was gonna return the gear oil I bought yesterday and go back and buy the LSD gear oil. Is that the right stuf to get or would I be okay with using the regular gear oil that I already have and just buying the tube of additive?
  2. May 16, 2012 at 8:38 AM
    #1002
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Anytime Ive tried Synthetic, with the addative, the rear end has developed chatter. Best off getting the regular dyno oil, in the same weight, and the addative as listed in the first post.
  3. May 16, 2012 at 9:42 AM
    #1003
    BassMaster06
    Dan
    South Carolina
    You da man Chris. So I already bought the Mobil 1 synthetic gear oil 75-90w, without the additive. Should i return it and get a non synthetic gear oil in the same weight?
  4. May 16, 2012 at 9:43 AM
    #1004
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would.
  5. May 16, 2012 at 9:50 AM
    #1005
    BassMaster06
    Dan
    South Carolina
    Thanks for the info
  6. May 16, 2012 at 2:41 PM
    #1006
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  7. May 17, 2012 at 1:37 PM
    #1007
    tacdm717
    tacdm717 New Member
    Florida
    tacoma Prerunner SR5
    Hi folks. I am new to this forum, and my 2000 tacoma with 142K miles. I want to change my rear diff oil(4x2). Reading the manual mentions about the LSD type. I am not sure if I have a lsd. Any input is welcome.
  8. May 17, 2012 at 10:44 PM
    #1008
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    Just look for a sticker on your rear axel that says LSD if you dont have one you dont need the additive
  9. May 21, 2012 at 2:48 PM
    #1009
    tweeter
    tweeter New Member
    Dale
    So. Cal.
    2010 Toyota Tacoma 4Door 4x4 short bed.
    Have a few questions before i do this. I am wanting to change the front dif, transfer case, and rear dif. fluids all at the same time.
    Here is what i have.
    2010 4x4 with the little push button locking dif. 57,000miles on it
    so from what i have read so far i need the following
    about 4qts of 75/90w Royal Purple or Mobile 1
    1) 4oz LSD additive
    and the crush washers for all plugs
    Important steps:
    Soak all plugs with WD40 the night before
    bust fill plug loose before even touching the drain plug
    Is this correct
  10. May 21, 2012 at 3:15 PM
    #1010
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. You dont have a LS Diff, so you dont need the addative.
  11. May 21, 2012 at 3:19 PM
    #1011
    tweeter
    tweeter New Member
    Dale
    So. Cal.
    Thank you Chris4x4
  12. May 27, 2012 at 2:34 PM
    #1012
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    my '08 4x4 now with 45000 miles, and I just changed the oil & air filter today. no idea if the previous owner did the front / rear Diff so that'll be my next project.... next weekend I hope.
  13. May 27, 2012 at 2:48 PM
    #1013
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Might as well do your transfer and tranny while you're at it!
  14. May 27, 2012 at 2:58 PM
    #1014
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Hate to be a dead horse but Im a little confused. I have an 06 Sport 4x4. do i need the additive?
  15. May 27, 2012 at 3:04 PM
    #1015
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Do you have the LSD sticker?
  16. May 27, 2012 at 5:24 PM
    #1016
    stmpjmpr
    Jimmy
    what do you do with the used diff oil? is it same as motor oil? drop off at nearest Oreillys?
  17. May 27, 2012 at 10:59 PM
    #1017
    boshak
    AG
    CA
    Yep... I usually store all my fluids/oils and drop them all off at local hazardous waste events. You can find a schedule on the OC city website.
    This saves multiple trips to the store and no hassle to have to dump liquid yourself... Just load in your bed, drive through the event, and they take the fluid.
  18. Jun 3, 2012 at 10:20 PM
    #1018
    JasonY
    JasonY Active Member
    Austin, Texas
    09 Access Cab, Prerunner, SR5, Alloys,
    Went to the Toyota of Round Rock dealership down here in Austin and asked him what kind of rear diff oil I needed. I figured I'd get it from them since I wasn't sure (I am now, after reading this whole post). Can you believe he gave me 2 QUARTS (wrong, I needed 3) of 75W-140 (NO! I needed 75w-90) and the tube of friction additive (NOPE! It's a 2009 with the Auto LSD. The stupid dealer couldn't even get that right! Not just one, not just two, but three separate mistakes that could have boned my rear diff. I was so mad when I found out. I have to go back in for some minor warranty work tomorrow (the squeaky rear springs TSB), but honestly, after that major screwup I'm never going to that place again. What a joke! On the plus side, after reading this post I got three quarts of Valvoline synthetic 75w-90 and did the job myself in about an hour. Piece of cake. Thanks for all the help here. I'll never believe that "The Mighty Dealer" has a clue again.
  19. Jun 7, 2012 at 1:26 AM
    #1019
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Chris, Brian,
    Your contributions and patience on this forum are incredible to say the least.
    I have read this entire post and wish many members would. It would eliminate a lot of repeat questions about servicing the fluids. I lost count of how many times you had to repeat in different posts 3 quarts of fluid for the rear diff.
    Great job gents!
    Thank you!
    Dave
  20. Jun 7, 2012 at 7:11 PM
    #1020
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Just drained mine until it stopped dripping (about 2.75 qts came out), then put the new oil in. However, it only took 2.5 qts of the new oil before it began running out of the fill port. I jacked the rear tires off of the ground, spun them backward and forward for a few minutes, then tried adding more oil - it only took about 1 more ounce. I waited several more minutes, tried again, but it only took about half an ounce. Is it always this slow of a process trying to fill the last 1/2 qt?
