Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 9, 2012 at 12:54 PM
    #1021
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I need to start doing mine more often. The first 38k it looked great and no metal...last 40k not so much :(
  2. Jun 9, 2012 at 7:32 PM
    #1022
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    Well today I did this for the first time (@ 48k :eek:) The rear diff oil wasn't bad, but it did have a bunch of metallic powder on the magnet. It took 3 quarts easy, without me having to stop and wait, or drive the truck around to circulate it.
    I also changed my xfer case oil, which looked brand new when I drained it...far less used than the rear diff. I will change the front diff tomorrow.
    Thanks for the write-up!
    P.s. I followed chris4x4's spark plug write-up this morning and it went extremely smooth! thanks for that write-up as well. Saved me a ton of cash!
  3. Jun 19, 2012 at 3:56 AM
    #1023
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Hey guys .. sorry for the ignorance. Not sure if my truck has a LSD and if I need the additive? I was planning on using the mobil 1 75w-90 LS, but the more I read the more people seem to have chatter with the synthetic. I am now thinking of just using dino 75w90 or 85w-90 without any type of LS or Limited Slip mention, just straight 75w-90 or 85w-90.. So, do I need the extra 4oz additive?
    2011 4x4 TRD Sport LB
    I think whats confusing me about the additive is that the first post has a note saying "all 2009 and newer do not need the additive" but then goes on to say that he has a Sport model so he needs it (and his sig says he has a 2010).
  4. Jun 19, 2012 at 7:13 AM
    #1024
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You do not need the additive.
    For a recap:
    2009+ models do not need the LSD additive. You have the AUTO LSD which is a 'brake actuated' Limited slip.
    2005-2008 Sport models have the mechanical LSD with clutch paks inside the rear differential.
    For anyone else, if you are unsure - crawl underneath your truck and look at your rear differential. If you have the mechanical LSD, you will see a sticker on the rear diff that looks like this (below). If you have this sticker - you NEED LSD additive / friction modififer.
  5. Jun 19, 2012 at 8:07 AM
    #1025
    puckstopper55
    Long Island
    Awesome! Thank you. Also, I can use the same 75w-90 or 85w-90 for the front diff, transfer case, and tranny .. right?
  6. Jun 19, 2012 at 8:47 AM
    #1026
    Janster
    Jandy
    Lancaster, PA
    You have an Automatic?? Your automatic transmission doesn't need servicing until 100,000 - and uses different fluid.
    Check your owners manual for proper oil information. That may vary depending on where you live and your driving conditions.
  7. Jul 7, 2012 at 12:01 PM
    #1027
    chedv
    chedv New Member
    Just got my rear differential oil changed this morning. Thank you very much for the write-up and all of the other guidance. I put in a little over 3 quarts of Mobil 1 75w-90.
    The only problem I had was a tiny speck of the seal over the gear oil fell into my new bottle of oil and I couldn't get it out. Hope it won't give me any problems!
    Thanks again
  8. Jul 16, 2012 at 9:35 AM
    #1028
    zhukov
    zhukov New Member
    Florida
    2009 Double Cab, Prerunner SR5 TRD Package
    I just changed mine at 45,000 miles. The gear oil that came out was nice and clean, with very little residue on the plug magnet. It took exactly 3 quarts to refill; I used Valvoline 75-90W. Mine's an '09, so from what I've read here, I don't need the LSD additive although my truck has one.
    Only thing I would mention (sorry if it's been brought up already), but the OP said to torque the plugs to 36 ft -lbs. That's way too tight, just a little past snug will do it.
  9. Jul 16, 2012 at 10:00 AM
    #1029
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Didn't Toyota change the recommended mileage to 60,000 for tranny?
  10. Jul 22, 2012 at 3:01 PM
    #1030
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Did my rear today. Oil was dark for sure. Some junk on the magnet. Put in 3qts. Manual states 3.12. Only had 3qts. When I do the front and tc, i will add in the rest. All i can smell us gear oil lol.
  11. Jul 22, 2012 at 3:14 PM
    #1031
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    29 ft lbs front
    36 ft lbs rear
    per toyota Use your best judgement, I always just snug mine. That's something you have to have a feel for though so if not toyota specs ^
  12. Jul 22, 2012 at 3:14 PM
    #1032
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Now that I have my first 4x4 in a long time ... this "pictorial DIY thread" will come in very handy ... thanks to the OP for posting it.
  13. Jul 22, 2012 at 3:22 PM
    #1033
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I believe it's 60,000 or 72 months if you do any towing. Even if you don't tow i'd still do it way before 100,000 miles. I go by the months...(light towing and don't drive much.) I do a drain and fill every 5 years which comes out to around every 20,000 miles.
  14. Jul 22, 2012 at 3:27 PM
    #1034
    SOSHeloPilot
    2024 4Runner SR5
    ... ^^^ ... Informative "hyperlinks" in your signature ... learned something new today. ... :D
  15. Jul 24, 2012 at 9:46 PM
    #1035
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    i know this is a super big thread, so sorry if this has been answered before, but I have a 2006 with lsd, if i use this gear oil that says limited slip, do i need the additional lsd additive, if it doesn't need it, does it hurt to add it?
  16. Jul 24, 2012 at 9:56 PM
    #1036
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    No 'additional lubricant' needed.. Friction additive maybe?
  17. Jul 24, 2012 at 10:00 PM
    #1037
    nammer
    Nam
    Bradenton, Florida
    sorry yea, i meant the lsd additive (friction additive), even if it says limited slip already, i should still add the additive?
  18. Jul 24, 2012 at 10:13 PM
    #1038
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    It's advisable to change it at 5 years / 60k, i.e. just before the powertrain warranty expires. That way, if any problems arise after the fluid change, you still have coverage.
  19. Jul 24, 2012 at 10:18 PM
    #1039
    KenLyns
    Belly of the Beast
    Not necessary. The tolerance for fluid level per service manual is +/- 5 mm. The oil also expands when heated. You won't notice any problems unless the fluid level is way below the fill port.
  20. Jul 24, 2012 at 10:36 PM
    #1040
    nammer
    Nam
    Bradenton, Florida
    i think i saw on page 3, that chris4x4 changed his cold so that less oil in the member, but would hot be better, so it is more viscous and drains out more?
