Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jul 24, 2012 at 10:42 PM
    #1041
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Makes no practical difference, though I'd prefer to drain it cold to avoid burning my hand. Diff fluid is not an exact science. Keep in mind Toyota trucks can be maintained by illiterate cave men in Afghanistan.
  2. Aug 21, 2012 at 2:47 PM
    #1042
    mr.mike8525
    mr.mike8525 Well-Known Member
    Riverside, California
    07' V6 preRunner SR5
    Just changed my rear differential fluid at 118k. Added mobil 1 LS as my prerunner displays the LSD sticker on the rear differential. I didn't use the additive because the the oil I used stated it was for use with LSD's. Took it for a spin around the diff. Seems to hum accelerating after taking a corner from a stand still. Would the additive alleviate the problem or hinder it further?
  3. Aug 21, 2012 at 3:08 PM
    #1043
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    I too just changed my rear diff and transfer case this morning. I have a 2006 DC long bed Sport with LSD. Used 3 full quarts of Valvoline conventional gear oil 75w90 (not synthetic) with 4 oz of additive for my rear differential. For my transfer case and front diff I am using Mobil 1 synthetic LS. Read through a lot of this thread and it keeps coming back to using an additive for the LSD regardless of the gear oil having or not having it already.
    My 115K mile '06 is driving very well. I followed the OP "how-to" to the letter and everything works out fine.
  4. Aug 21, 2012 at 3:15 PM
    #1044
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Mobil 1 gear oil doesnt seem to like the Toyota LS Diff much. Also, the "LS" on the bottle, simply means its safe for use in LS diffs. Not that it has the addative in it already. Your best off to dump the oil, and get a good conventional gear oil, and the addative.
  5. Aug 21, 2012 at 3:24 PM
    #1045
    mr.mike8525
    Thats unfortunate, oh well, $35 dollars worth of fluid down the drain (not literally ). But I'd rather not pay more in the long run, thanks for the advice.
  6. Aug 21, 2012 at 3:27 PM
    #1046
    mr.mike8525
    I'm glad that worked out for you. My truck is at around the same mileage as yours and it runs smooth. Its my job to keep it that way.
  7. Aug 21, 2012 at 4:51 PM
    #1047
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Go to the Ford dealer and pickup 2 bottles of their friction modifier. I think its XL3.
    Ive been running mobile 1 with the 2 bottles of XL3 for 25k miles now.
  8. Aug 21, 2012 at 4:58 PM
    #1048
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know he didnt waste the Mobil 1!
  9. Aug 21, 2012 at 5:04 PM
    #1049
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this is what I have been living by.
    Your the first person I heard say they have had good luck with Mobil1 in the LSD rear. My rear is the only place I don't have mobil1, but with 15k changes that I'm doing now I shouldn't have any issues with dinosaur blood.
    I thought you had personal experiences with this oil and it wasn't good?
  10. Aug 21, 2012 at 5:10 PM
    #1050
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I did. I have tried it with many different addatives, with no luck. However, I havent used the addative janster has, so I cant say if it works or not in my diff. I have no reason to doubt jansters word on it.
  11. Aug 21, 2012 at 6:55 PM
    #1051
    Janster
    Jandy
    Lancaster, PA
    I had called my local Toyota dealership and they told me they use the Ford XL3 in the diffs. I didn't ask them what oil they used....
    I originally put one bottle in, did some driving around and tight circles but I was still getting a bit of chatter even after a week or so. So, I added another bottle and that seemed to work. I only had 26k miles on it when I changed it.
    You could buy one bottle, put it in and see what happens before adding more - in case age and wear are a factor (on the LSD itself).
    I think I've read that other folks needed to use a couple bottles of friction modifier with non- synthetic, so I wasn't worried about needing to add a second bottle. Got 50k on the truck now.
    I'll be ready to change it again soon either this year or next. I plan on doing the same thing.
  12. Aug 27, 2012 at 12:07 PM
    #1052
    MarCsTaCo
    MarCsTaCo New Member
    Idaho!
    04 TRD Supercharged Taco
    Bilsteins Front and Rear TRD Supercharger K&Ns
    New to the Forum... thanks to all for such good info!
    I read 13 out of 54 pages and didn't quite see my answer, so here are my questions:
    I have a 2004 4x4 V6 supercharged tacoma.
    1) I don't see a sticker on the rear differential, so I assume I don;t need any LSD fluid, correct?
    2) Front & rear, 6 quarts?
    Many thanks!
  13. Aug 27, 2012 at 3:04 PM
    #1053
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Welcome to TW! Get 7 quarts just to be safe :)
  14. Aug 27, 2012 at 4:14 PM
    #1054
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    I just completed my 60k fluid swap on both diffs and TC......and a oil change.
    I used valvoline 80w 90 for the gear oil. I also bought a 4oz bottle of the motorcraft(FORD) friction modifer straight from my dealer. Only prob I had was that bought 2 gallons of gear oil and a pump to fill them all. The bottle of modifer didnt have a squirt tube or way of getting it in. If I had the quart bottles I would have just tossed it in there but I tried to rig up a tube to get it in and lost some. So I went and bought another bottle of Tran-x modifer and squirt about an oz in there for good measure.
    So far no chatter and truck runs nice after the fluid swap.
    Nice write up and made it pretty simple.....the front dif is a beotch kinda only cuz my truck is stock but once i get a lift it will def be easier.....yet another reason to get a lift guys.:)
  15. Aug 28, 2012 at 10:39 AM
    #1055
    MarCsTaCo
    Idaho!
    Thanks Chris. And no additive, right?
  16. Aug 28, 2012 at 2:56 PM
    #1056
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Right!
  17. Aug 31, 2012 at 11:39 PM
    #1057
    jacobigindi
    jacobigindi Well-Known Member
    Jacob
    Socal
    '11 SR5 5 lug AC
    I've got a 2011 5 lug with 21K on it. How often am i gunna need to change the rear diff fluid and what weight does is take? I've gotten 3 different answers so far for the 2nd question. One dealership told me 75-85 which the guy at auto-zone had never even heard of, another dealership told me 80-90, and my friend told me 75-90. :confused:
  18. Sep 1, 2012 at 6:30 AM
    #1058
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should be mentioned in the owners manual, in the back with the other service intervals.
  19. Sep 1, 2012 at 6:35 AM
    #1059
    XXXX
    sKiP
    05 Prius
    sounds like way to many miles on gear oil to me....?.... at 40k my 6 lugger is past due.
  20. Sep 1, 2012 at 6:40 AM
    #1060
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On open diffs, I change out the dino oil at 30k, then switch to synthetic, and go with a 60k interval.
