Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Oct 8, 2012 at 1:23 PM
    #1101
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Ah, makes sense,
  2. Oct 8, 2012 at 4:49 PM
    #1102
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Yup this. Punch a hole to vent. Wedge the bottle behind tire while its filling go do something or just wait lol
  3. Oct 9, 2012 at 1:07 PM
    #1103
    Drunknsloth
    Retribution
    South West
    What kind of tube to you use? Does it fit over the mouth of the bottle?
  4. Oct 9, 2012 at 1:41 PM
    #1104
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    Go to Lowe's and get some 5/16" inside diameter clear tubing.
  5. Oct 9, 2012 at 9:52 PM
    #1105
    Drunknsloth
    Retribution
    South West
    The mouth of my transmission oil is about 1" diameter and it doesn't have the pointy lid like the other gear oils...
  6. Oct 10, 2012 at 12:46 PM
    #1106
    memphis guy
    Nashville
  7. Oct 10, 2012 at 12:48 PM
    #1107
    memphis guy
    Nashville
    You need one anyway...or something similar...to add transmission fluid to these trucks.
  8. Oct 10, 2012 at 9:47 PM
    #1108
    Drunknsloth
    Retribution
    South West
    I have one, I used it for my diff oil, I just picked up another one for my tranny. I just wanted to see if there was another option but I guess this is my best bet
  9. Oct 10, 2012 at 11:54 PM
    #1109
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  10. Oct 10, 2012 at 11:55 PM
    #1110
    Drunknsloth
    Retribution
    South West
    I saw one of those, I didn't know how well they worked.
  11. Oct 11, 2012 at 12:02 AM
    #1111
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Haven't used many but I think generally they all work pretty well. I'd expect they work even better with a more viscous fluid like gear oil.
    Basically a plunger with a seal that rides inside that metal body. Works pretty much as you'd expect it too. I think it'll drip a little if you're not careful but they're fine. It'll pump a lot of fluid quickly too.
    Check reviews I guess.
    edit:
    http://www.amazon.com/gp/product/B0..._m=ATVPDKIKX0DER&pf_rd_r=025HS8QAERYYBYZKYAB8
    has great reviews, some of the others -- not so much
  12. Oct 11, 2012 at 12:04 AM
    #1112
    Drunknsloth
    Retribution
    South West
    Nice, I might have to pick one up for next time when I have some extra cash laying around
  13. Oct 22, 2012 at 9:44 AM
    #1113
    cameron172
    cameron172 Well-Known Member
    VA
    2017 Super White TRD Sport MT
    I'm having a hard time getting an accurate count. To change the oil in my manual transmission, transfer case, and both differentials...how much oil should I get from Autozone?
    Also, the Haynes manual recommends 75w90 for the front diff but 90w for the rear diff. Can I get away with just using 75w90 for everything?
  14. Oct 22, 2012 at 7:16 PM
    #1114
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah you'll be okay with 75-90 but for FL you could honestly run something a little heavier most of the time, IMO.
    I think it's what 3 qts in the rear, 2 qts in the trans (6spd?), 1 qt for the t-case, and almost 2 for the front diff.
    I want to say 8 qts but I can't remember.
  15. Oct 23, 2012 at 9:12 AM
    #1115
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Yep, it's about 8 quarts to change out everything.
  16. Oct 23, 2012 at 11:08 AM
    #1116
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I think I used 6 qts.
    1.1, 1.6, 3.3.... Something like that.
  17. Oct 23, 2012 at 12:31 PM
    #1117
    cameron172
    VA
    I found the elusive page in the Haynes manual.
    Manual transmission, 4 cyl, 4WD......2.3qts
    (Manual xmission, 4 cyl, 2WD..............2.7 qts)​
    (Manual xmission, V6.........................1.9 qts)​
    Transfer Case..............................1.1 qts
    Differential, Front (4WD)................1.6 qts
    Differential, Rear (4WD).................3.0 qts
    (Diff, 2WD except PreRunner...............3.5 qts)​
    Total..........................................8.0 qts
  18. Oct 23, 2012 at 4:00 PM
    #1118
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  19. Oct 23, 2012 at 4:04 PM
    #1119
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Best tool by far to use for this. Beats a little screw on pump any day.
  20. Oct 23, 2012 at 4:25 PM
    #1120
    george3
    New Jersey
    When I did my 30,000 I used a little screw on pump. It felt like I pumped 1000 times to do 8 qt :eek:s.
