Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Oct 23, 2012 at 4:28 PM
    #1121
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Duh. 6 speed. Sorry.
  2. Oct 23, 2012 at 4:37 PM
    #1122
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Exactly, then mine broke and had to borrow one and it was the one pictured. I went right out and got the store to exchange the broken one and got the other one and used it on the 60K service. Way better!
  3. Oct 23, 2012 at 6:06 PM
    #1123
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Looking forward to my 60 with the new gizmo :D
  4. Oct 25, 2012 at 10:51 PM
    #1124
    Taco 12
    Taco 12 Well-Known Member
    Mark
    Phoenix
    2012 4x4 TRD-Off Road
    thanks. will try soon
  5. Nov 4, 2012 at 10:43 AM
    #1125
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    So for the Tranny on a manual 6-spees v6 4wd takes 1.9 correct?? just want to make sure before i order the redline MT 90
  6. Nov 4, 2012 at 2:47 PM
    #1126
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    This is a handy little tool I saw at Auto Zone today - shown here screwed onto the mouth of a Royal Purple gear oil bottle:
    553C2A61-D294-402C-9F2E-8BDE02FCFF30-579_edb18a90aa51d8e14e8bc669c1bc65c9e6722c78.jpg
    Even has an on/off mechanism.
    $3.99 at Auto Zone, probably cheaper at Wal-Mart
  7. Nov 4, 2012 at 2:55 PM
    #1127
    george3
    New Jersey
    Good find ! Worth a shot for $3.99. Wonder if you will be able to get the bottle high enough for the gravity feed into the tube and then diff, T case etc. ??
  8. Nov 4, 2012 at 2:58 PM
    #1128
    memphis guy
    Nashville
    If I remember correctly, I think you can. I just used a length of tubing fitted over the pointy spout of the gear oil bottle, but I would have bought one of these had I known about it. Probably will next time I service the diff.
  9. Nov 4, 2012 at 3:28 PM
    #1129
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Front diff may be a little more difficult that the transfer and rear. I just did all of mine and the front I had to use a pump but the transfer and rear were no problem, squeezed it right outta the bottle :cool:
  10. Nov 4, 2012 at 4:15 PM
    #1130
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I have a little marine pump from HF. Put one in a gallon of fluid and the other in the diff an walk away with a drain pan under it. Come back in 10 min and it's done. No time fooling around with bottles in the cement driveways
  11. Nov 10, 2012 at 6:01 PM
    #1131
    rokedawg
    rokedawg Active Member
    NY
    09 dbl cab trd off-road 6sp mt
    Thanks for the writeup. Tried it today and took less than 30 minutes to do.
  12. Nov 15, 2012 at 4:55 PM
    #1132
    nine2nine
    nine2nine Well-Known Member
    Greensboro N.C.
    06 TRD Tocoma Sport 4wd
    just had the fluid in my limited slip differential at the dealership and now it's chattering bad .took it back and they said they did'nt put in the additive in so they added some.well it got worse so took it back and now they say i need new differential.and it just was a coincidence that it went out after the service. what do you all think
  13. Nov 15, 2012 at 4:56 PM
    #1133
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    its happened in the past to a couple others.
  14. Nov 15, 2012 at 4:58 PM
    #1134
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  15. Nov 15, 2012 at 5:56 PM
    #1135
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If that ain't a bunch of BS!!! Not you.... The dealer. They're trying to make a few bucks on you!! Screw that!!
    Sounds like you need to get 'pissed off' and ruffle some feathers until they fix it RIGHT!!! Sounds like their techs are a bunch of morons!!
    If that doesn't work - tell them to go pound sand. You could change the oil yourself.
  16. Nov 15, 2012 at 6:24 PM
    #1136
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I agree. I didnt read the post correctly when I posted. Make them own up to the mistake!
  17. Nov 17, 2012 at 12:14 AM
    #1137
    Chris C
    Chris C Member
    Northern California
    07 PreRunner TRD DCB
    To: nine2nine
    Very similar situation happened to me. I had to take my truck back to the Toyota dealership a couple of times. I also advise you to call Toyota Customer Svc. and let them know your situation. If you are like me you are probably really pssd off, however try to stay cool and stay professional when talking to the dealership. You also must stay persistent. The remedy to fix the problem is to replace the "differential carrier" (which is not the whole lsd differential). Otherwise, you have to take off the carrier and go through each gear and replace one by one. The best thing to do is to get the dealer to replace the carrier, which would come with all new gears, etc. The carrier is expensive ($1600.00 online and $2000.00 + at certain dealers). After 30,000 miles later, my lsd has had no problems ever since I got my carrier replaced, however now I change the fluid myself to make sure it's done right.
    If you are within power train warranty you are covered. If you are out of warranty, you still have a case against that dealership. Of course it helps if you have something in writing. If anything is noted on your "RO" (work order) by the service dept. stating that they did not add "lsd fluid" that would definitely help your position when trying to get the dealership to pay for the labor and parts.
    Sorry to hear this happened to you (It's a BIG HEADACHE trying to get them to own up!).
  18. Nov 18, 2012 at 7:59 AM
    #1138
    mardoqueo galindo
    mardoqueo galindo Well-Known Member
    marcos
    socal
    08 preruner
    toyota 20" wheels,borla double tip exaust,running boards,K&N air filter.
    thanks guys ,exelent job
  19. Nov 18, 2012 at 8:39 AM
    #1139
    nine2nine
    Greensboro N.C.
    just picked up my truck from the dealership,they replaced the carrier assembly at a total cost of $ 2,730 lucky i have a extended warranty which made it easy because they got paid for their mistake and they even paid my $100 deductible.their head tech who looked like he was 20 years old tried to tell me they use synthetic fluid and it doesn't need the additive but when i first took it back that's what they did was to put in the additive,but by then it was to late the damage was done.on the new carrier assembly repair order that was the first item listed on the parts required to complete the job was lsd additive.
  20. Nov 18, 2012 at 12:56 PM
    #1140
    Chris C
    Chris C Member
    Northern California
    Good news nine2nine. In the future, I would recommend that you change the fluid yourself to make sure it has the right oil and additive added, it's really easy and cheaper than paying the dealer to do it. Unfortunately, I had to find out the hard way like you.
