Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Mar 23, 2009 at 5:26 AM
    #101
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The only oil that seems to work that already has the LS addative in it is the Royal Purple. Mobil 1 and the others make the rear chatter pretty bad. If you dont want to use the Royal Purple, use regular oil, and add the addative.
  2. Mar 23, 2009 at 5:50 AM
    #102
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    gawd i love you guys. i have learned so much stuff from this site.
    dont the shops charge like 80 90 bucks to do this for you?
  3. Mar 23, 2009 at 5:51 AM
    #103
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Something like that. :)
  4. Mar 23, 2009 at 6:21 AM
    #104
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    i have 19000 on the pickup and i put a lot of jet skis in the water minds as well get this done. anyone know the best place for Toyota additive and rear end oil?
  5. Mar 23, 2009 at 6:23 AM
    #105
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Last time, I just bought the stuff from the dealer. It was actually a little cheaper than anyother place. Check around.
  6. Mar 23, 2009 at 6:25 AM
    #106
    brianr
    brianr [OP] go shit in your hat
    2010 4x4
    BUILT, not bought...
    regular 75-90w oil from checkers or the dealership.
    I used 80-90 weight because what the store had in-stock.
    4oz. of LSD additive again from the dealer or local auto parts store since you have a Sport model.
  7. Mar 23, 2009 at 6:26 AM
    #107
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hey, Brian, How is your diff doing? Any chattering?
  8. Mar 23, 2009 at 6:29 AM
    #108
    brianr
    2010 4x4
    no chattering buddy.
  9. Mar 23, 2009 at 6:31 AM
    #109
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    sweet.
  10. Mar 23, 2009 at 6:32 AM
    #110
    brianr
    2010 4x4
    sweet sassy molassy.
  11. Mar 26, 2009 at 9:49 PM
    #111
    zigzagg321
    zigzagg321 T100
    Ohio
    96 T100 SR5
    sliding rear window
    does my 96 2.7 4x4 need the LSD additive for the rear?
    blm likes this.
  12. Mar 26, 2009 at 9:56 PM
    #112
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    No, you only need it if you have a limited slip differential....
  13. Mar 30, 2009 at 10:07 AM
    #113
    L8Rmike
    L8Rmike Well-Known Member
    Goose Creek, SC
    08 White DC LB 4x4 sport
    Just went to our local toyota dealer to get the LS additive and all they had was Motorcraft. The parts guy stated toyota corp. sent out a letter of approved additives other than toyota stuff, due to the toyota brand costing so much. Anyone else heard of this?????
  14. Mar 30, 2009 at 11:34 AM
    #114
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Same here, Toyota does not have additive for LSD nor has Gear oil for sale. Oil used in the barrels does come with LSD additive in it and it is the same stuff as Ford and GM uses. I replaced my rear diff fluid after 17k miles and it was burned like hell.
    I changed with Valvoline Synth 75W-140 in hope that I will avoid chatter in differential.
    That of course did not work well. I have chatter when diff is cold. (under 100F) few minutes highway driving will heat up and chatter will go away.
    I am planning to add Amsoil LSD additive to see if I can get rid of chatter on cold.
    So looking at the thread I dont see anybody having sucess with Synthetic oils. :confused:
  15. Mar 30, 2009 at 12:35 PM
    #115
    L8Rmike
    Goose Creek, SC
    Dude your 1st post...welcome to TW.
    I am going to use Valvoline Durablend 80-90 in a couple of thousands miles w/the additive. I'll post any negitive results.
    update 7 Sept - No chatter at all.
  16. Mar 30, 2009 at 12:53 PM
    #116
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    YES
    Lucas Oil 80w90 with this additive from autozone = no chatter
  17. Mar 30, 2009 at 1:21 PM
    #117
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Anyone know if Amsoil Severe Gear 75-90 and the additional additive from amsoil still causes the chatters in the LSD? That's my plan after some research, and trusting amsoil in the past.
  18. Mar 30, 2009 at 1:44 PM
    #118
    BlueT
    NorthEast
    Thank you, :wave:
    I had been lurking around here for some time but usually stayed on Pirate/TTORA/IH8MUD . Its just now I am little emotional with that LSD. :frusty:
    I wish I had known how Toyota LSD works, I would not have bought truck with one. I got DBL cab + Long Bad and LSD is standard on that (don't know why )
    I will either get that LSD to work with Synthetic or Get my myself Truetrac.
    I should have listen to Australian crowd that had the same issues with LSD's in some of their cruisers.(apparently the same type)
    Once i get my Amsoil additive added I am going to know if going Valvoline 75-140 + Amsoil + additive works.
    Amsoil stuff are on order so I should know by this weekend. I will report back. So if anybody wants to wait, we will test on my stuff.:D
  19. Apr 1, 2009 at 11:39 AM
    #119
    BlueT
    NorthEast
    Ok so this is looking actually very good.
    Here is what I did (This is info for rear diff with Mechanical LSD - 2005-2008 TRD Sport or Dbl cab + Long Bed)
    Oil = Valvoline Synthetic 75W-140
    Additive = AMSOIL SlipLock[​IMG]
    I went on the nice grassy field and runned about 20 circles (10 one way 10 other way) After that my chatter had went away.
    So far my LSD seem to actually work much smoother then when it came from factory. :confused:
    To the point that I was afraid its not working at all. But little wheel spin confirmed that it does work its just smooth.
    Lets keep fingers crossed on this one.
  20. Apr 8, 2009 at 11:10 PM
    #120
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    The service dept at the dealer(the computer showed) 120,000 miles is when it is due to be changed.
    Dealer charges $79.
    Do It Yourself $27. For 3 qts of diff fluid. Not sure of price of the LSD additive. Not needed in my 05.
