Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Feb 23, 2013 at 12:18 PM
    #1221
    Redeemed
    Redeemed Well-Known Member
    Jeff
    Southern Maine
    05 SR5 with a "TRD Off-Road" sticker
    Excellent write up... I am going to do this, but want to make sure I do it right. Would someone kindly explain to me, like I am 6 years old, the whole locker thing (or even a link to a thread that will)?
    I have a 2005 TRD Off Road and there is no switch in my cab for any sort of locker--just the clutch cancel button.
    I don't believe I need the differential oil with additive.
    Thanks in advance!
  2. Feb 23, 2013 at 12:20 PM
    #1222
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Do you have an "LSD" sticker on the rear diff?? If you do, then you DO need the additive. If you don't, then NO, you don't need the additive. See the second pic of the OP
  3. Feb 23, 2013 at 1:52 PM
    #1223
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you dont have a switch for a locker, you dont have an TRD Off Road.
  4. Feb 23, 2013 at 3:23 PM
    #1224
    Redeemed
    Jeff
    Southern Maine
    :mad: I suppose a previous owner could have slapped the stickers on there, but it says off-road, and the only switches are for the clutch start cancel and fog lights...
  5. Feb 23, 2013 at 3:30 PM
    #1225
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yup. No locker switch, no inverter, and sport seats = TRD sticker applied to regular SR5 Tacoma.
  6. Feb 23, 2013 at 3:34 PM
    #1226
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That is strange.. according to your picture you also have the offroad hood, chrome grill, and door handles. Do you have a chrome rear bumper?
  7. Feb 23, 2013 at 3:50 PM
    #1227
    Redeemed
    Jeff
    Southern Maine
    Yes.
  8. Feb 23, 2013 at 4:30 PM
    #1228
    OffroadToy
    ^ that pretty much explains things...
  9. Feb 23, 2013 at 5:02 PM
    #1229
    Redeemed
    Jeff
    Southern Maine
    So, riddle me this, Batmen: I don't have an e-locker and I don't have LSD. What do I have?
  10. Feb 23, 2013 at 5:21 PM
    #1230
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Spindle lift ;-)
    Open
  11. Feb 23, 2013 at 6:56 PM
    #1231
    Redeemed
    Jeff
    Southern Maine
    Yeah, ignorance is bliss, isn't it? But I'm trying to quit ;)
  12. Feb 28, 2013 at 7:27 AM
    #1232
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I don't have time to look through 63 pages.....my question is are the part numbers for the crush washers listed above also good for the first generation Tacoma's?
  13. Feb 28, 2013 at 7:29 AM
    #1233
    Sandman614
    Tim
    '06 SR5 Off Road
    Sarcasm :notsure:
    Your answer is Open as in Open-non-locking differential.
  14. Feb 28, 2013 at 7:54 AM
    #1234
    Redeemed
    Jeff
    Southern Maine
    No sarcasm regarding my mechanical ignorance. Sarcasm intended saying it's bliss, but I have been asking questions when I can't find clear answers, so I'm trying to quit my ignorance.
    Thank you for the clarification, though.
    The other question I have is are you guys jacking up all 4 "corners," so to speak, to keep it level and changing all the fluids at once or just the end of the vehicle you're working on. Is there a "best way" to do this?
  15. Feb 28, 2013 at 8:00 AM
    #1235
    Sandman614
    Tim
    '06 SR5 Off Road
    Ai gotcha. You profile on the left says you have a 05 TRD Off-Road, do you not have a locker, what switches do you have?? My brother has a prerunner Off-Road and even that has the locker. Look for "RR Diff Lock". I'm just confused here.
    If you have an Off-Road 4x4 model do you not have enough clearance to crawl under there? Otherwise you should be fine to jack it up, just make sure you aren't leaning it so that it won't drain.
    Pro-tip: for the rear drop the spare tire for more room.
  16. Feb 28, 2013 at 8:15 AM
    #1236
    d.sull
    d.sull Member
    Dillon
    Tuscaloosa
    08 Supercharged TRD Sport 4x4
    Supercharger, JBA headers, Pioneer DVD, Backup camera, two tone leather seats, step bars, HID headlights and fog lights, black billet grill, blacked out tail lights, BHLM, Bull bar, off road lights
    So call me an idiot but this is my first 4WD. I've got a switch for 2WD, 4HI, and 4LO, A switch for the inverter, and A switch for the fogs. The truck has TRD Off Road stickers on it but I am not the original owner. Does this mean I DO NOT have an electronic locker? I'm assuming I don't. I see no LSD sticker (or any stickers for that matter) on the rear chunk so I'm assuming I do not have a LSD differential. I'm planning to put RP 75-90w in the front diff and transfer case and conventional Lucas 75-90w I'm the rear? Sound like a solid plan Tacoma gods? Greatly appreciate the write up, Chris.
  17. Feb 28, 2013 at 8:22 AM
    #1237
    Sandman614
    Tim
    '06 SR5 Off Road
    :D I have an SR5 Off-Road sticker on my SR5 and I have a Diff lock switch :D
  18. Feb 28, 2013 at 8:23 AM
    #1238
    Sandman614
    Tim
    '06 SR5 Off Road
    4wd selector is different from the Diff lock button.
  19. Feb 28, 2013 at 9:10 AM
    #1239
    Drummer0247
    Drummer0247 International Jewel Thief
    Michael
    Rio Rancho, New Mexico
    2013 Toyota Landcruiser
    I am curious to as what this sticker says on the LSD, does it actually say LSD on the diff? cause i have a 2012 tacoma SR5 and i have a LSD according to the window sticker, but no sticker on the actual diff stating this.....?
  20. Feb 28, 2013 at 9:27 AM
    #1240
    Sandman614
    Tim
    '06 SR5 Off Road
    this
