Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Mar 11, 2013 at 4:53 PM
    #1261
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    75-140 is a more "heavy duty" weight. Mostly for hotter climates, but many folks use it with out issue.
  2. Mar 12, 2013 at 3:41 AM
    #1262
    TacosNBurritos
    TacosNBurritos Active Member
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    Chris, I live in Louisiana at the moment but will likely me moving to Pacific Northwest in the next 6 months. Is it okay to keep the 140 in there or should I change it out once I move to the colder climate? Also, since I have the 4x4, should I use the Oil with LSD added?
  3. Mar 14, 2013 at 7:50 AM
    #1263
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    subd great write up
  4. Mar 21, 2013 at 3:21 PM
    #1264
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
    need a hand as well. I'm getting ready to do my 30k service- converting to Mobil 1 oil & i'd like to go synthetic on all fluids. read a ton of posts, but i'm still not sure what to use on the front & rear differentials? Mobil 1 as well? i have a 2010 DC 4x4 TRD Sport w/ auto LSD if it matters.
  5. Mar 21, 2013 at 4:18 PM
    #1265
    acrossawire
    Fresno, CA
    2010 DCSB 4x4 Sport
    thanks!
  6. Mar 24, 2013 at 12:24 PM
    #1266
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    Maybe I'm just a pussy but my filler plug seems to be completely locked up, it's not budging anywhere. Any ideas
  7. Mar 24, 2013 at 12:31 PM
    #1267
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Put some ass into it....
    What are you using? Wrench or socket?
    Need a cheater bar for leverage
  8. Mar 24, 2013 at 12:33 PM
    #1268
    dlooney
    Dennis
    Wilmington NC
    Wrench. My bigger sockets are at the garage, which I don't want to drive to cause I got some water in dat der rear diff. I'll keep strugglin then
  9. Mar 24, 2013 at 12:43 PM
    #1269
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Get a breaker bar and a 6 point socket.
  10. Mar 24, 2013 at 12:49 PM
    #1270
    dlooney
    Dennis
    Wilmington NC
    Thanks
  11. Mar 28, 2013 at 4:58 PM
    #1271
    acrossawire
    Fresno, CA
    2010 DCSB 4x4 Sport
    Just finished my 30,000 mile service- couldn't have done it without this and other TW forums. Thought i'd pass along a helpful tool that i made from random parts in the garage. Made putting in the gear oil much faster & easier.
    Took an old hose & cut it down to 6ft or so. Inserted a 3/8in threaded pipe into the cut end of the hose & secured it with a hose clamp.
    It screws directly into the rear differential fill hole- same thread pattern.
    cut the bottom off a 1 QT bottle of Mobil 1 & screwed onto the other end of the hose.
    I pulled the hose through the wheel well and strapped the M1 bottle to my ladder rack & viola! fast & easy.
    TacosNBurritos likes this.
  12. Mar 28, 2013 at 5:25 PM
    #1272
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I fill the diff until it comes out the fill whole. How do you know when the diff is full with the hose screwed into it ? Thanks.
  13. Mar 28, 2013 at 5:50 PM
    #1273
    acrossawire
    Fresno, CA
    2010 DCSB 4x4 Sport
    That's the one downside. i knew it took 3 quarts- just added all 3, let it sit for a while & then unscrewed the hose and checked the level visually with a flashlight.
  14. Mar 28, 2013 at 7:19 PM
    #1274
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    +1
  15. Mar 28, 2013 at 9:03 PM
    #1275
    george3
    New Jersey
    Thanks.
  16. Mar 31, 2013 at 11:06 PM
    #1276
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  17. Apr 4, 2013 at 9:21 PM
    #1277
    Monster1
    Monster1 Well-Known Member
    San Antonio, Texas
    2012 Texas Edition DC Tacoma 4WD
    Weathertech digitals front and rear, TRD exhaust, Coverking dash mat, Oem Tacoma bedmat, Better Built tool box, bed extender, Toytec 1 1/2" AAL, Bilsteins front and rears, fronts set at .85, K&N filter, aluminum skid plate, EGR vent shades, locking tailgate handle, TRD emblems, Cal Trend seat covers front and back.
    I was planning changing my rear differential oil with Mobil 1 is that a good choice or would Redline or Royal Purple be better? I know it's a preference, but do the experts here on the forum suggest and also would I need to add the lsd additive, if so how much (ounces)? Thanks
  18. Apr 4, 2013 at 10:19 PM
    #1278
    650H1
    Michael
    VA
    I used M1, 75w 90 synthetic.... Wanted to use 75w 140 but too much $$$
  19. Apr 5, 2013 at 12:35 PM
    #1279
    joesmith
    joesmith Well-Known Member
    Alaska
    2005 Access Cab 4x4
    I put in Amsoil Severe Gear 75w90.
  20. Apr 5, 2013 at 4:14 PM
    #1280
    Janster
    Jandy
    Lancaster, PA
    I'm using Mobile 1 75w-90. Been using Mobile 1 in all my vehicles for years.
