Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 6, 2013 at 2:23 AM
    #1281
    PDReino
    PDReino Member
    Southern Maryland
    06 Tacoma SR5 4x4
    Awesome how-to. Yesterday I changed the fluids in both front/rear diffs, and transfer case. Did the front first, no problems, except that you have to have a pump or some other way to get the oil from the bottle to the fill hole. I used one of those tubes that screws onto a quart bottle. Someone in this thread had a pic of one. Worked good enough, but leaves a few ounces of oil in the bottle, so I just poured the left over into the next bottle I opened. The fluid in the front diff was NASTY, and the mag plug had lots of sludge on it, glad it's got clean fluid in there now. I used valvoline high perf 75w90 dino.
    The transfer case oil was VERY clean, looked like new, and had I known, probably would have left it alone. I only use 4wd a few times/year in winter, and engage maybe once/month to keep the juices flowing, so should've figured it'd be pretty clean. Also used the valvoline for the refill.
    On the rear diff, I had a helluva time getting the fill plug to break free, like several others in this thread. Had to borrow a length of pipe from a neighbor as a make-shift breaker bar. Good news is I got the plug to break free. Bad news is I forgot to put my gloves back on before I did it and my driveway is now the proud owner of some of the skin from the top of my left hand. Comes with the territory I guess :) The rear diff fluid also looked pretty good, was red stuff. Magnet on the drain plug had a little sludge, but not as bad as the front. I refilled with LucasOil Synthetic 75w90. I wasn't sure whether or not to put in the LSD additive, since the oil bottle said it was good for use in LSDs, but put a little in anyway. Hope "too much", whatever that is, doesn't give me problems. BTW, truck just went over 100k yesterday, and I've never done this service before. Since I don't tow or do any heavy off roading, doubt I will ever do this again. Maybe if I still own the truck when it hits 200k.
  2. Apr 6, 2013 at 3:06 AM
    #1282
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    It makes me want to change it. I just hit 30k, but since they needed to do a lot of warranty work, took it to have it done at the dealership. Dfinetelly I will do it at 45k.
    Thanks for the write up
  3. Apr 6, 2013 at 7:43 AM
    #1283
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    This is one of my projects for today :D Write-up seems simple enough. More to follow later.
  4. Apr 6, 2013 at 8:41 AM
    #1284
    theredofshaw
    Do i need the additive for the 2011 DC sport 2WD? Seeing conflicting stories in this thread...
  5. Apr 6, 2013 at 8:45 AM
    #1285
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Note from first post \/
    NOTE: 2009 and newer trucks do NOT need LS Diff addative, or TRD Off Road trucks with the factory locker.
  6. Apr 6, 2013 at 9:31 AM
    #1286
    theredofshaw
    Missed that :)...i was going off the google link from the spark plug how to lol
  7. Apr 6, 2013 at 9:39 AM
    #1287
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I'll probably be doing this next weekend along with the tranny fluid. My truck is pushing 85k.
  8. Apr 6, 2013 at 12:34 PM
    #1288
    ImpulseRed008
    Susan
    SC
    :thumbsup:
  9. Apr 6, 2013 at 2:20 PM
    #1289
    theredofshaw
    it was VERY simple. should I be worried that I didn't get the "fluid leaking out" portion of the step? It took the full 3 quarts...It looks just shy of being level if the fill plug as well.
    EDIT: and whoever posted that the oil is rather pungent...I couldn't agree more...I stilled smelled it when I went into the house a couple hours later...
  10. Apr 6, 2013 at 3:24 PM
    #1290
    ImpulseRed008
    Susan
    SC
    I didn't get any leaking out and mine's been fine, or should I say no issues in 12K miles
  11. Apr 6, 2013 at 6:38 PM
    #1291
    BryanWhiteTRD
    BryanWhiteTRD Active Member
  12. Apr 6, 2013 at 8:03 PM
    #1292
    theredofshaw
    I ended up lowering the spare out of the way for this. made it easier to get the bottles up in there (and gave me head room lol)...also gave me a chance to check that tire's pressure (WAY low) and to make sure the cable is rusting like some other vehicles had issues with.
  13. Apr 7, 2013 at 4:45 PM
    #1293
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Ok let me ask this on the fill of the transfer case and front diff and manual gearbox can I fill all these till it starts coming out of the fill hole? I am the most worried about the transfer case and front diff. My truck has 72 thousand and I am going to make a 1500 mile trip to California next week or so.
  14. Apr 7, 2013 at 5:22 PM
    #1294
    ImpulseRed008
    Susan
    SC
    Put in the amount listed in your OM.
  15. Apr 7, 2013 at 8:58 PM
    #1295
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Which is until it comes dribbling out the fill hole... haha :)
  16. Apr 7, 2013 at 9:16 PM
    #1296
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Wrong^
    Toyota put the fill hole at that location for a reason...you fill until it starts to drain out of the hole. The amounts given in the owners manual are the same called out in the Chiltons manual. They say the capacities called out are "approximate" and to add as necessary to bring to appropriate level.. which they say to be at the bottom of the plug opening. In addition, the Toyota Factory Service Manual calls to add as nessesary to get the level within 5mm (0 to 0.20 in.) of the bottom of the filler plug opening.
  17. Apr 8, 2013 at 7:29 AM
    #1297
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    Thats the answer I was hoping for fill till plug the old school way:)
    Thanks for the clarification.
  18. Apr 8, 2013 at 7:42 AM
    #1298
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    I am new to 4x4 so I read your links you posted on 4x4 use. Very good info thanks.
  19. Apr 10, 2013 at 9:35 PM
    #1299
    skygear
    skygear                    
  20. Apr 11, 2013 at 3:22 AM
    #1300
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It DOES NOT have the additive in it.
    It only means that it is compatible for LSD diffs.
