Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 15, 2013 at 11:59 AM
    #1321
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Wow.... Whatever dude. :rolleyes:
  2. Apr 15, 2013 at 2:34 PM
    #1322
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :annoyed: Enough already... You didn't like Jansters answer, so leave it alone. You're not going to like everyone's response to everything. Take it or leave it, but enough already.
    a400ryan likes this.
  3. Apr 15, 2013 at 2:59 PM
    #1323
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    this.
    /end discussion.
  4. Apr 23, 2013 at 3:31 PM
    #1324
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    do i need any additives for my 2007 regular cab 4x2 and dayum i never changed front diff, rear or transfer case and im at 63,000 miles!!!!
  5. Apr 23, 2013 at 3:35 PM
    #1325
    ImpulseRed008
    Susan
    SC
    no
  6. Apr 24, 2013 at 10:17 AM
    #1326
    jmarquez808
    Jess
    Hawaii
    i could of swore my manual said 1.1 quart for my rear diff, or am i smoking crack, i got the regular cab 4x2
  7. Apr 24, 2013 at 7:47 PM
    #1327
    TanaTaco
    TanaTaco Well-Known Member
    James
    Montana
    05 TRD Offroad 4x4
    OME complete kit with dakars, LR UCAs, Seat covers, weathertechs, anytime foglight mod, ABS kill switch, locker anytime mod, powered sub, halos, leer topper, aux/ipod hookup.
    Well got the front diff and t case oils changed, went to do the rear diff and stripped the fill plug. Anybody got suggestions or ideas to get the fill plug out?
  8. Apr 25, 2013 at 10:27 AM
    #1328
    jmarquez808
    Jess
    Hawaii
  9. Apr 25, 2013 at 10:49 AM
    #1329
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15Âş clocking
    By "stripped the fill plug" do you mean that you rounded the head of the bolt, or did you actually destroy the threads of the bolt/housing?
    If you rounded the head, you can get a dremel and CAREFULLY cut or grind two of the surfaces into parallel. Then you can use an adjustable wrench to get it off.
  10. Apr 25, 2013 at 2:31 PM
    #1330
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    What did you do? Round it off with a 12 point? Get a bite on it with Vise Grips, then replace the mangled one with a new one and buy a 6 point socket.
  11. Apr 25, 2013 at 2:51 PM
    #1331
    TanaTaco
    James
    Montana
    05 TRD Offroad 4x4
    Thanks guys, I used a 6 point in the beginning, it started slipping so I soaked the plug with PB, then tried the socket again, nothing. I then used vise grips and hi-lift handle for leverage, still nothing and rounded it off pretty damn good. Took a file to the plug to make 2 flat edges, tried an adjustable and vise grips again, and now it is destroyed. Not sure who did it last, but im guessing toyota did it before they sold it to me last year. Unless anybody else has got more tips I will probably be taking it into a shop. Thanks again
  12. Apr 25, 2013 at 2:59 PM
    #1332
    skygear
    skygear                    
    I used my impact to get mine off. Mine were also to tight.
    On another note. Anyone used the Royal Purple? I was given a few bottles. But WOW these are double the price of the Mobil 1 I got. Cant find much on TW users with them though./
  13. Apr 25, 2013 at 4:14 PM
    #1333
    rtn1911
    Richard
    CA
    2013 MGM 4x4
    You could weld a nut to it or get after it with a chisel.
  14. May 7, 2013 at 6:29 PM
    #1334
    Waikoloa Tacoma
    Waikoloa Tacoma Well-Known Member
    At the beach, Hawaii
    2007 PreRunner DC TRD OR
    Both the local dealer and NAPA use/recommend/sell Valvoline SYN Power full synthetic 75w-90 for limited slip. Both say no additives needed. Only difference is $33 at dealer, $16 at Napa.
    Edit: More content.
    Just finished mine. Took 3.2 qts for mine. The lower plug was a breeze to loosen. The upper plug was a very different story. Used 6 point socket with standard 1/2 inch drive, damn near had an aneurysm trying to loosen it. Went to my impact next, 1st setting - nothing, 2nd setting - nothing, third setting - finally broke loose. Whoever did it last must have had an 800 pound gorilla jump up and down on a 5 foot beaker bar to tighten it. Good lord!
  15. May 8, 2013 at 10:50 AM
    #1335
    jmarquez808
    Jess
    Hawaii
    lmao i usually bust out my breaker bar or a socket wrench with a big pipe for stubborn bastards like this! or my 600lb gorilla, hes usually big enough for the job. lol
  16. May 8, 2013 at 11:25 AM
    #1336
    Waikoloa Tacoma
    Yeah I usually pull out the breaker bar as well but with the impact I am directly in front so less chance of rounding off the corners.
  17. Jun 10, 2013 at 6:42 AM
    #1337
    Janster
    Jandy
    Lancaster, PA
    Changed my diffs again yesterday for the 2nd time.
    First time, was at 26,000 miles (3 years ago). Used Mobile 1 75W-90 and 2 bottles Ford XL3 friction modifier.
    Yesterday, 59,400 miles and 6 years later. Mobile 1 75W-90 and 1 bottle of XL3 so far. It grumbled almost immediately within the first mile or so until I was able to do my 'diff mixing routine' several times. We'll see what happens after I drive it for a few days.
    It's still a *mystery* with Mobile 1 LS compared to 3 years ago and today. This is the one negative thing about Mobile 1 - is that they can't (or don't want to) explain themselves for their 'advertising' of this oil and how confusing it is. Until you actually change your oil and run a diff mixing routine (drive in tight circles / 8's in both directions) -you really and truly don't know how much friction modifiers you'll need.
    The front diff oil was still translucent and only slightly dirty. The rear was darker than the front ....but neither of them were nearly as dark/dirty as the OEM fluid I removed 3 years ago. Both magnets had a similar amount (small film) of material on them.
    OH yeah, and Thanks to my local Toyota Dealer - who couldn't give me the right part I needed for the front diff drain plug gasket and I discover this after draining it. I just re-used the old one. They gave me two rear gaskets.... The front drain is a bigger and copper looking.
  18. Jun 14, 2013 at 10:17 AM
    #1338
    brucejoh
    brucejoh B/CS Tacoma
    College Station, Texas
    2010 Tacoma TRD
    I know the book says 3.12 Qts. or something like that but mine just took 4 qts. of Lucas 75w90. When I checked the level with my finger it was just at the bottom of the fill hole. Is it bad to have this much fluid in my diff? should I drain some out? Is it possible to overfill and cause damage?
    This was my first diff fluid change on my 2010 TRD Pre runner.
    Thanks.
  19. Jun 20, 2013 at 5:39 PM
    #1339
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Sub'd for the answer to this.
    This seems similar to the final drive on my m/c. Supposed to drain, then fill till it starts coming out of the fill hole. In essence, cannot overfill the m/c. Wondering if it is the same for the Taco.
    Thanks.
  20. Jun 21, 2013 at 3:07 AM
    #1340
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    There is probably an official answer but I filled mine til it came out. It was more then it is supposed 2 B. I was worried but its been months now and no problem.
