Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 23, 2013 at 5:26 PM
    #1361
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  2. Jun 23, 2013 at 5:50 PM
    #1362
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    No. You want the bottle to say GL5, whether you get synthetic or conventional, there are also different weights.
  3. Jun 23, 2013 at 5:51 PM
    #1363
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I know that... I just quoted from the very first post in the thread. "(for you guy like me w/ the Sport model, you'll need a 4oz. tube of LSD additive)."
  4. Jun 23, 2013 at 8:39 PM
    #1364
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Thanks guys. I saw that comment in the OP about the OR not needing the LSD additive. I'm sure I meant to type "I don't need" and just wanted to double-check after reading through the thread. Thanks for the smart ass replies too, my mistake. :eek:
  5. Jun 23, 2013 at 9:26 PM
    #1365
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    I used Valvoline DuraBlend 80W-90 for my diffs and added 2oz of LSD additive for my LSD rear with no problems. DuraBlend has 3% LSD additive in it. I've read Toyota calls for 4%. No chatter been 2 months now.
  6. Jun 23, 2013 at 9:33 PM
    #1366
    byrd
    byrd Unknown
    David
    Kansas
    Some SR5 models came with a LSD rear, mine did.
    And yeah I have the sticker and it does say it on my vehicle inquiry report I got from the stealership.
    Limited Slip Differential......Retail 390.00
  7. Jun 23, 2013 at 11:56 PM
    #1367
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The funny thing is.... I emailed Mobile 1 about their 'friction modifier' wanting to know what it is and how much is in a bottle ... But they can't seem to answer my email.
  8. Jun 24, 2013 at 7:39 AM
    #1368
    byrd
    byrd Unknown
    David
    Kansas
    Now that's pretty sad that a company that big can't supply an answer to a simple question about their own product. I have used Valvoline since the late 70s in all my vehicles with no problems and see no point in changing what's not broken.
    However, I have switched to using Royal Purple in my transmission with good results, having the 6 speed and when I bought this truck it had a slight grind going into 3rd gear every so often, I have not had that grind since the switch 2 months ago. Shifting is much smoother as well. Time will tell. When I bought this truck at 47k it had factory fill for all gear oils. Now at 52k all has been changed and everything runs smooth.
    Good luck in getting your answer, I don't know it since I've never used Mobil oil.
  9. Jun 24, 2013 at 1:27 PM
    #1369
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    This may seem obvious (as it did to me about 20 seconds too late to be helpful), but one thing I just learned the hard and very scary way:
    If you're going to use any sort of tubing to get the oil into the pumpkin, make sure the tubing you use is too long to fit all the way into the diff. I got to spend a good hour with a flashlight and wire hanger fishing out a 4-inch piece of nylon hose which I had stuck on the nipple of the oil bottles I had to get some extension and visibility for when the oil was flowing or not - didn't occur to me that this was a bad idea until the hose slipped off of the bottle and sank into the 2/5 quarts of fluid I already had put in (and then had to drain back out and try to funnel back into the bottles so I could put it back in).
  10. Jun 24, 2013 at 8:17 PM
    #1370
    Janster
    Jandy
    Lancaster, PA
    I couldn't agree more. I asked a similar question on their facebook page - and got a 'generic' response. I've read this same paragraph on their website. Hi Jandy - Mobil 1 Synthetic Gear Lube LS 75W-90 contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid. Thanks for using Mobil 1!
    They could theoretically claim they put it in ...but that statement covers just about every situation on the planet. I've always used Mobile 1 and the changes they've claimed over the years never cease to confuse the crap out of me (to the point they're not believable).
    We have used Amsoil Severe Gear in our Corvette diff. That's a highly recommended oil for the corvette diffs and its worked great. Not easy or convenient to get a hold of.....
    Doesn't matter..... diffs are done, chatter is gone (after 1.5bottles). In 3 years from now when I'm ready to do it again - things will probably be different and confusing once again. :D
  11. Jun 24, 2013 at 9:36 PM
    #1371
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Won't do that again! :p
  12. Jun 27, 2013 at 5:05 AM
    #1372
    cleveland48
    cleveland48 Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    If u use anti -seize on this do u have to lower the ft- lbs when u torque them down? I will be working on this this weekend. Got some anti- seize I thought about using on all my diffs. Since I've already heard stories about how hard some are to get out the first time, though mainly its the front diff and transfer case I've heard of issues from.
  13. Jun 27, 2013 at 6:56 AM
    #1373
    byrd
    byrd Unknown
    David
    Kansas
    I didn't have any problem breaking loose any of my drain/fill plugs on my diffs, transfer case nor tranny from the factory fill. I also didn't use a 24MM socket as it felt a little loose on the nut. I used a 6 point 15/16 socket which fit on tight. As for the 10MM hex I took a hammer and tapped it in and then slipped the racket on. No issues.
    I suppose it wouldn't hurt to use anti-seize on them.
  14. Jun 27, 2013 at 8:22 AM
    #1374
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    Good info on the 15/16 socket. I did the math and you're right, it is slightly smaller than a 24mm. I haven't done mine yet but I did buy a 24mm for it, and I'm betting that I already have a 15/16. Thanks.
  15. Jun 27, 2013 at 8:28 AM
    #1375
    DirtEater
    Surprise, AZ
    What is the 10mm hex for? Not sure if I've forgot something or simply overlooked.
  16. Jun 27, 2013 at 1:41 PM
    #1376
    byrd
    byrd Unknown
    David
    Kansas
    10MM hex fits Front Differential fill & drain plugs.
    24MM or 15/16 6 point socket will fit Transfer Case, Manual Trans and Rear Differential fill & drain plugs, a 12 point socket from what I've read can cause the bolt head to strip and/or leave marks. My 24MM socket was a 12 point which could be why it felt loose, my 15/16 was a 6 point.
  17. Jun 27, 2013 at 2:51 PM
    #1377
    DirtEater
    Surprise, AZ
    Thanks! The 24 mm I got from Northern Tools is an el cheapo $5 socket, but it's a 6 point socket. I checked the fit, and it seems snug...
  18. Jun 29, 2013 at 10:06 PM
    #1378
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    I have never done this and it seems pretty simple.
    I am not exactly the most mechanic savvy person but I am learning a lot from this site. I do my own oil changes, thats about as much as I get into it. ...for now anyways
    My 09 DCSB 4X4 (no locker, no TRD) has roughly 65K on it and I dont know when this was done last. I imagine there is some nasty stuff in there.
    Any advice for a first timer. I guess I am concerned about seals, leaks etc. I do have the LSD and I am a bit confused regarding whether an additive is needed or not. Right now everything is fine and I dont want to mess anything up.
    Thank you all for the info and wish me luck!
    AT Fluid change and Front transfer case fluid change maybe next if this goes well.
  19. Jun 30, 2013 at 1:22 AM
    #1379
    Janster
    Jandy
    Lancaster, PA
    You have an 09 which should have the AUTO LSD -which is brake actuated. You do not need friction modifier.
    But to be safe, walk around to the rear of your truck and take a look at your rear diff. If there's a red/white sticker that says "Only LSD Oil", then you'll need friction modifier. I'd post a photo of the sticker but I can't do it with the phone.
  20. Jun 30, 2013 at 8:40 AM
    #1380
    ImpulseRed008
    Susan
    SC
    You only need the additive if you have this sticker ^^
