Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Aug 17, 2013 at 7:26 PM
    #1441
    quantum
    quantum Well-Known Member
    :smack: i know that :p
  2. Aug 17, 2013 at 7:30 PM
    #1442
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Hey... it's not nice to :smack: a girl!!! :angrygirl:
  3. Aug 18, 2013 at 2:43 PM
    #1443
    Ttruck55
    Ttruck55 Member
    Edmonton
    08 Tacoma
    Not sure what you mean by not using synthetic? how does it mess up the seals? Seems the only things ive heard or read is what synthetic to use (mobil1,redline,or amsoil) and whether to add lsd additive even with gear oils that say it has the additive already. Anybody want to add or have opions on the above.
  4. Aug 26, 2013 at 5:12 PM
    #1444
    Mr. Sparkle
    Mr. Sparkle Well-Known Member
    Bryan
    Long Island, NY
    Silver 09 TRD Sport
    Leer Cap Subfloor, water pump, marine battery, 45 gal water tank & plumbing to wash cars anywhere
    another satisfied customer after reading this thread and following the photos (and my haynes manual - blech)
    FWIW truck was on level ground and drained. Then I jacked up the drivers side a bit and found a decent amount was still in the axle. So in the future I'd do that again
    I went with Lucas Oil Synthetic 75w-90 which includes the LSD additive (even though my 2009 does not need it). Will report if I have any problems. Basically I could not find any non synthetic gear oil locally except for walmart supertech (no thank you). So I went with the lucas stuff even though it was synthetic
  5. Aug 26, 2013 at 6:20 PM
    #1445
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    delete double post please
  6. Aug 26, 2013 at 6:21 PM
    #1446
    MattN03
    Bluegrass State
    Is there any issue running Mobil 1 Synthetic 75W-90 in my 07 TRD O/R front & rear diffs and transfer case? I think this oil has LSD additive, but I don't think that will be an issue to use in my truck, correct?
  7. Aug 26, 2013 at 6:24 PM
    #1447
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    It should say if ot has LSD additive in it, spme say LSD compatible. Thats the one you need. Wont hurt to use the other though and most use 75/90 in all 3.
  8. Aug 31, 2013 at 4:20 PM
    #1448
    Devux
    Devux Well-Known Member
    Devin
    Las Vegas, NV
    2014 TRD Sport 4x4
    Leveling kit & wheels
  9. Aug 31, 2013 at 5:28 PM
    #1449
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I got 6qts of Mobile 1 for less than $50 at Advanced Auto a week or so ago thanks to a 40% off coupon they were running. :cool:
  10. Aug 31, 2013 at 6:50 PM
    #1450
    TACO TX
    Kelly
    Denison ,Texas
    My local Autozone gets like $21 bucks a quart for mobil 1. I get it at this local wholesale place called Bi-lo here and i pay $7.99 a quart. I hope they never stop carrying it, probaly should buy 6 more just to have on hand.
  11. Aug 31, 2013 at 7:07 PM
    #1451
    Ostrichsak
    Jer
    Yeah, Advanced had it for $10.99/qt as I recall. Not an amazing price in and of itself but with that 40% off I wasn't finding it cheaper anywhere else that's for sure. I think my price was $48 for 6qts after tax and everything. :cool:
  12. Sep 17, 2013 at 5:45 PM
    #1452
    jcman01
    jcman01 Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    I am confused about what gear oil to buy for my 2011 4WD without the LSD. Should I use the Redline 75w85 or should I use something else like Mobil1, which I can only find in 75w90 in my area?
    This is what my diff looks like - no LSD sticker. Please help. Totally confused here.
    http://postimg.org/image/lzg2g4n6d/
  13. Sep 17, 2013 at 7:26 PM
    #1453
    TacoMan1911
    TacoMan1911 Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    I just did mine with mobil 1 75w 90. No problems so far. Also, I regularly tow a boat at 2500 lbs. I have a regular cab base model.
  14. Sep 23, 2013 at 1:01 AM
    #1454
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Do 1st gens use the same 75-90 gear oil?
  15. Sep 23, 2013 at 3:44 AM
    #1455
    TACO TX
    Kelly
    Denison ,Texas
    First gens call for 80-90 i think in the rear end and 75-90 in the TC and FD. I use 75-90 in all 3. Just 5 degrees difference.
  16. Oct 4, 2013 at 9:50 AM
    #1456
    wheelerkr2
    wheelerkr2 Well-Known Member
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    Was just trying to do this and i cant get the first bolt out, i tried oiling it to loosen it up but im afraid of stripping it, any recommendations?
  17. Oct 4, 2013 at 10:43 AM
    #1457
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    PB Blaster and let it soak in a fairly long while...like maybe overnight?
  18. Oct 4, 2013 at 10:45 AM
    #1458
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm hoping you mean the fill plug! If so, do what Moose said, soak it in PB blaster, just keep dosing it every couple hours and trying to work the bolt loose. If that doesn't work, you might have to resort to a little bit of heat.
  19. Oct 4, 2013 at 12:56 PM
    #1459
    wheelerkr2
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    haha yes i mean the fill plug, im gonna pick up some PB blaster, if that doesn't work ill have to wait to go to my dads garage as i have minimal tools at my apartment.
  20. Oct 4, 2013 at 2:48 PM
    #1460
    ImpulseRed008
    Susan
    SC
    He's alive!!! How's it going Rob? :wave:
