Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 21, 2014 at 4:51 AM
    #1541
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I've read that B 4. I ass U me U have tried it.:confused:
  2. Jan 21, 2014 at 10:36 AM
    #1542
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    ok I have been reading a lot and need to change the rear differential oil this weekend.
    I would appreciate if anyone can help me here:
    q1. I have a 2010 double cab tacoma with a tow package. Its NOT the one with the sports package. would I need the LSD additive? The article says for its needed for the sports package. Just want to make sure. I have seen something on my truck somewhere on a slip differential.
    thanks.
  3. Jan 21, 2014 at 10:37 AM
    #1543
    Manwithoutaplan
    ID
    off roads dont come with LSD ^. IF you have locker all you need is diff oil.
  4. Jan 21, 2014 at 10:45 AM
    #1544
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    None after 09 need LSD additive. They are not mechanical LSD's. They are brake controlled.
  5. Jan 21, 2014 at 11:12 AM
    #1545
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    I used the correct socket, it fit on the drain plug perfectly, the plug was just plain stuck. I already ordered a new plug, once it comes in I'll go to my buddys and try the tack weld to get it off.
  6. Jan 21, 2014 at 11:19 AM
    #1546
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If stuff is stuck I always try to use 6point sockets/wrenches. Much less chance that it will round it off.
  7. Jan 21, 2014 at 11:23 AM
    #1547
    TACO TX
    Kelly
    Denison ,Texas
    The problem is the depth of the plug. Its only a 1/4" and if you get just slightly off angle with it it slips. Like Sandman said a quality 6pt socket and a swivel head break over bar are ideal.
  8. Jan 21, 2014 at 11:33 AM
    #1548
    wuzzy121
    wuzzy121 Well-Known Member
    Colorado Springs
    05 AC 3" lift
    ARB front bumper w/ Warn M8000 winch and lights, 3" lift, Tire gate tire carrier, All-Pro Expedition leaf springs, weather tech floor mats.
    A De Walt cordless impact takes them off nice too.
  9. Jan 21, 2014 at 11:43 AM
    #1549
    dctamcoa
    dctamcoa Well-Known Member
    Dan
    Tulsa, Oklahoma
    Double cab TRD
    Pelfreybilt front and High clearance rear bumper +3 lift on LT 285 75 16R Goodyear MT/R, All pro Apex rock sliders, bed rack with CVT Mt. Hood
    So I have 09 OR and I pick up Synthetic with LSD additive all ready in it, is it a bad idea to use it anyways. even if I don't have an LSD?
  10. Jan 21, 2014 at 11:57 AM
    #1550
    TACO TX
    Kelly
    Denison ,Texas
  11. Jan 21, 2014 at 3:14 PM
    #1551
    JUJtacoma2010
    Fresno
    oh man, after reading first 20 pages, this is amazing. really good stuff here Brian and Chris. I appreciate the information and the stuff I am learning about the truck itself.
    Can some one please clarify couple more things...
    Would Any of these oil would work for my 2010 off road tacoma?
    Mobile 1 synthetic 75w-90
    Redline 75W-90
    Valvoline 75-90 or 80-90
    Royal Purple 75w-90
    I was reading somewhere that using synthetic damages sometype of oil seal. It said that when you switch to synthetic to be ready to change seals. is that correct?
  12. Jan 21, 2014 at 4:08 PM
    #1552
    TACO TX
    Kelly
    Denison ,Texas
    I switched my 03 to Mobil 1 at 150,000 miles and not a single leak. Yes you can use 75-90 in all 3. Rear, trans case, front.
  13. Jan 21, 2014 at 4:14 PM
    #1553
    JUJtacoma2010
    Fresno
    Thanks Taco tx. do you change the crush washer each time?
  14. Jan 21, 2014 at 4:20 PM
    #1554
    TACO TX
    Kelly
    Denison ,Texas
    Nope, never changed one on the truck at all. Still using the same one on the oil pan also.
  15. Jan 22, 2014 at 8:17 AM
    #1555
    JUJtacoma2010
    Fresno
  16. Jan 22, 2014 at 8:26 AM
    #1556
    Sandman614
    Tim
    '06 SR5 Off Road
    Advance Auto has the same price. That's the cheapest I could find so far. I need to call the supplier and see what they have available.
  17. Jan 22, 2014 at 8:39 AM
    #1557
    Sandman614
    Tim
    '06 SR5 Off Road
  18. Jan 22, 2014 at 8:50 AM
    #1558
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    No, you can run synthetic, that's little validity to that. You can change back and forth too.
  19. Jan 22, 2014 at 10:14 AM
    #1559
    george3
    New Jersey
  20. Jan 22, 2014 at 10:23 AM
    #1560
    Sandman614
    Tim
    '06 SR5 Off Road
