Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Mar 4, 2014 at 5:44 PM
    #1581
    morelia
    morelia Well-Known Member
    conroeeee
    k&n intake. hid kit sound system
    Could anyone recommend any 80w90 synthetic oil that doesnt have any lsd additives since i do not have lsd... most of the synthetics i see are 75w90 w lsd additives.
    i bought master pro 80w90 from oreilly but have yet to do the change.
  2. Mar 5, 2014 at 5:56 AM
    #1582
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    I use the Mobil 1 syn 75w-90...the additive won't hurt
  3. Mar 5, 2014 at 6:21 PM
    #1583
    morelia
    conroeeee
    Ok. i went and got some mobile 1 today. not looking forward to the smell though. :crapstorm:
  4. Mar 16, 2014 at 2:55 AM
    #1584
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    Subbed...
    Long over due for this one!
  5. Mar 22, 2014 at 9:35 PM
    #1585
    BRUIN8124
    Mark
    This write up is incredible! I am doing this tomorow.
    I have a couple of clarification questions. I saw a bit of conflicting info in the 80 pages here so I just wanted to double check...
    I have an 09 4X4 with LSD (no LSD label though?) no TRD/no locker. No LSD additive is needed right? It is no longer mechanical?
    I was planning on using Mobil 1, What are these noise issues I read about?
    To avoid noises and leaky seals, should I run Dino instead? This has not been done for roughly 60K miles.
    Is/should there be a gasket? Some said there is none, some said there is/replace it.
    If the oil already has the LSD additive (like Mobil 1) Is that still ok to be used?
    I may be over analyzing a bit but this is my first time doing it and I dont want to F it up. If this goes well, I will attemt the front diff and transfer case.
    Thank you all for your help!
  6. Mar 22, 2014 at 9:37 PM
    #1586
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the noises are only hear in mechanical LS Diffs. You will be fine with the Mobil 1 oil, and don't need addative. You should be able to re use the original gasket.
  7. Mar 22, 2014 at 9:54 PM
    #1587
    BRUIN8124
    Mark
    Awesome! Thank you Chris! :thumbsup::bowdown:
  8. Mar 22, 2014 at 10:22 PM
    #1588
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Mar 23, 2014 at 8:01 AM
    #1589
    ehp
    ehp Member
    ED
    2014 Tucoma
    Mobil one has 75-90 LSD can I use that in my rear that has Auto LSD
    Thanks
  10. Mar 23, 2014 at 4:06 PM
    #1590
    Wired
    Wired Member
    Chino Hills
    06 PreRunner TRD Sport
    I got a Noob question. Does it take all 3 Qts of the oil to fill the rear diff?
    I have the TRD Sport 2x4.
  11. Mar 23, 2014 at 4:18 PM
    #1591
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    It will start pouring out of the fill plug when it gets close to 3 qt. At that point, quickly reinstall the fill plug.
  12. Mar 23, 2014 at 5:40 PM
    #1592
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  13. Mar 25, 2014 at 6:11 PM
    #1593
    BRUIN8124
    Mark
    DONE! Piece of cake! I had a bitch of a time getting the fill plug loose but I got it eventually.
    Thank you all for the help! ...and the extra change in my pocket from doing it myself!
  14. Mar 29, 2014 at 9:19 AM
    #1594
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    OK maybe this has been covered here but I have a question/problem.
    I recently changed my diff fluid (3rd time 90k miles) and when I tightened the fill bolt I'm pretty sure I stripped it. Seemed like I just got past setting the new crush washer when it started slipping, you know the feeling.
    So I just left it where is was, so far no leakage but I'm sure it's a matter of time. So, what should I do? I'm wondering if maybe the bolt threads are softer & designed to fail there rather than the diff case. Can I just buy a new fill plug? Or does this mean a trip to a shop for a real repair?
    Thanks & sorry if this is repeat maybe point me to post #!!
  15. Apr 8, 2014 at 8:12 PM
    #1595
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  16. Apr 8, 2014 at 8:22 PM
    #1596
    BeeRadd
    BeeRadd Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Subbed so i can remember to flipping do this already
  17. Apr 19, 2014 at 5:05 AM
    #1597
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    First, thanks to folks like Brian and Chris, with what seems like a limitless supply of patience in answering questions.
    Dealer did the 30k service. Plugs, fluids, rotate tires, just shy of $600.00. Never again. I'm doing the 60k myself. So I'm heading to Advanced Auto to pick up fluids for changing the rear and front diff, plus the transfer case. My Taco is an '11 SR5 quad cab with auto LSD. I planned on getting 6qts of Mobil1 syn 75-90 LS. Ok, to use in all three, front, transfer and rear?
    Apologies, if this has been asked and answered previously.
  18. Apr 19, 2014 at 6:56 AM
    #1598
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, you would be fine using it in all 3.
  19. Apr 19, 2014 at 8:25 AM
    #1599
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    If U haven't gone already - buy on line - use code TRT30 - pick up at local store - save 30% :D
  20. Apr 19, 2014 at 9:37 AM
    #1600
    rtkbowhunter
    Southeast PA
    You read my mind. 6qts of Mobil1, small pump, $53 and change. Just savin' all kinds of money today!
