Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Apr 19, 2014 at 9:45 AM
    #1601
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    DIY saves U the most $$ but 30% ain't bad on parts:D Enjoy your day of wrenching - beautiful here in Joisey
  2. Apr 19, 2014 at 10:11 AM
    #1602
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    You just saved me $30! Thank you:D
  3. Apr 19, 2014 at 10:29 AM
    #1603
    george3
    New Jersey
    U R Welcome Sir ! U owe me a tour of your favorite micro brewery if I ever get to Colorado :D
  4. Apr 19, 2014 at 10:42 AM
    #1604
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I'm sorry but we're no longer allowing people from New Jersey to come to Colorado.
    I don't make the rules....
  5. Apr 19, 2014 at 12:16 PM
    #1605
    george3
    New Jersey
    U R just too damn cheap 2 buy a guy a beer and U R taking advantage of the rules to further line your pockets after I saved U $30:(
  6. Apr 19, 2014 at 12:27 PM
    #1606
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I may be able to arrange a two day visa. No way I'm going to jersey though... Snookie scares me
  7. Apr 19, 2014 at 12:29 PM
    #1607
    george3
    New Jersey
    :cheers::cheers:
  8. Apr 19, 2014 at 12:31 PM
    #1608
    george3
    New Jersey
    And after she went thru all that plastic surgery just 4 U :p
  9. Apr 19, 2014 at 3:07 PM
    #1609
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    Ok...did the rear and transfer case. Both looked like honey, with some gunk and crap on the rear diff plug. One question, on the transfer case, both plugs were identical. No magnet on the drain plug.
    Is that normal?
  10. Apr 19, 2014 at 3:17 PM
    #1610
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Must be normal. I just changed mine today at 30k. Both the diffs had really dark fluid and a gooey sludge on the drain plugs but the tcase fluid looked brand new.
  11. Apr 19, 2014 at 4:45 PM
    #1611
    rtkbowhunter
    Southeast PA
    I meant that the transfer case drain plug did not have a magnet. Both fill and drain plugs were identical.
  12. Apr 19, 2014 at 4:46 PM
    #1612
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Yeah, sorry I meant to say that mine were the same way. No magnets on the t-case.
  13. May 1, 2014 at 4:15 PM
    #1613
    Deidara7117
    Deidara7117 Active Member
    Brandon
    Houston Texas
    A Tacoma
    ICON 3 leaf progressive AAL with Bilstein 5100 shocks and OME 885X coils
    sooo i have an 05 trd off road 4x4 with locker can i use Mobil1 syn 75-90 LS?
  14. May 2, 2014 at 6:58 AM
    #1614
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Yep. That's what I used in mine.
  15. May 4, 2014 at 10:44 AM
    #1615
    Deidara7117
    Brandon
    Houston Texas
    A Tacoma
    thank you:)
  16. May 27, 2014 at 10:29 AM
    #1616
    oldstick
    oldstick Medicare Member
    GA
    One more testimonial here, I browsed through this thread back from when it started several years ago. Didn't read everything carefully enough so I assumed the Mobile 1 Synthetic - LSD product was a newer version that overcame the LSD chatter mentioned way back earlier. (Hey, it say's LSD right on the bottle :D)
    I have the 07 TRD Sport 2WD with the LSD differential and I used the above. Couple days later I am getting a chattering or vibration first starting out in the am backing out at a 90 degree and such.
    So I now see my error and will be dumping that in favor of regular oil with additive immediately.
    At least that is what I hope the noise is anyway, the dealer just did the full tranny flush a week or so ago as well. Going to be POd if it turns out something in the tranny.
  17. May 27, 2014 at 10:46 AM
    #1617
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    No need to dump the new oil. Just add the lsd additive
  18. May 27, 2014 at 11:12 AM
    #1618
    oldstick
    GA
    I was under the impression that has already been tried with the Mobile 1 synthetic without success. I read (here) that the issue is only with the 05 - 08 models with the mechanical LSD unit.
    But, yes it would be great if I can find an additional additive that would correct it. Any others have experience or feedback on that?
  19. May 27, 2014 at 12:08 PM
    #1619
    ImpulseRed008
    Susan
    SC
    the "lsd" on the bottle just means it's compatable. If you have the sticker on your LSD you NEED the additive.
  20. May 27, 2014 at 12:44 PM
    #1620
    oldstick
    GA
    Yes, understand that. But has anyone recently used Mobile1 LSD synthetic plus some additive without problems? If so what brand of additive? Because the posts from several years ago said that combination was tried and it didn't work. The prevailing wisdom then was to use regular (non-synthetic) gear oil plus an additive in those units with a sticker. Unless I hear otherwise, I am going to have to drain out the synthetic and use plain oil and an additive.
