Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. May 27, 2014 at 12:54 PM
    #1621
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you are using it without any issues, no reason to drain it out. if you use it, and the rear end makes a "groaning" sound, then you want to consider changing it.
  2. May 27, 2014 at 12:57 PM
    #1622
    oldstick
    oldstick Medicare Member
    GA
    It is groaning, (post 1630 above). I mistakenly concluded the Mobile LS was newer and had some additive that made it work OK. And since you are the original authority on that, I will take your advice. Thanks for the reply Chris.
  3. May 27, 2014 at 1:07 PM
    #1623
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sorry, I didn't see the post you made :eek: Use a good dyno oil, and an addative. The additive in the original post is very good.
  4. Jun 2, 2014 at 2:32 PM
    #1624
    PICKSTACOMA
    PICKSTACOMA Well-Known Member
    Landon
    Penhook, Virginia
    06 Tacoma 4x4 dbl cab lb 4.0
    ARE MX Truck Cap, Flowmaster American Thunder Exhaust, K&N Cold Air Intake, Weather Tech( Digital Floor Mats,Bug And Side Window Deflectors), Scangauge II, Clearvision Solux Headlight/Foglight Bulbs, Redline Hood Struts, FJ Cruiser Foglight Switch, Illuminated 4x4 Switch, Rain X Latitude Wipers, Brighter Back Up Lights, Dome/Map LED's, Cup Holder LED's, Engine Bay Lights, Foglights On Anytime, Leather Seats With Front Heating Pads OME Lift With DAKAR Springs And LR UCA's, Rear Diff Breather Mod, A/C Drain Mod, Husky Mud Flaps, ECGS Bushing Kit
    Has anyone used the Red Line SAE 75W90 GL-5 gear oil ( already contains the additive ) for the rear diff? If so, did you have to add any more of the friction modifier and how much?
    Thanks
  5. Jun 7, 2014 at 10:19 AM
    #1625
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Drained and filled my rear diff today. It took all 3 quarts and doesn't appear to be up to the level of the fill hole. Should I get another quart and fill it until it dribbles out?
  6. Jun 7, 2014 at 10:55 AM
    #1626
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Interesting... I'd say if you had a leak there'd be quite a bit of fluid all over your ground but still check for leaks. Stick your pinky in an see if you can even find the level, if not just add til it's full and you should be good.
  7. Jun 7, 2014 at 11:07 AM
    #1627
    WilsonTheDog
    Eric
    Myrtle Beach SC
    No leaks. I'll add more. Thanks!
  8. Jun 8, 2014 at 4:53 AM
    #1628
    jcman01
    jcman01 Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    I had the same issue with my diff, as I remember. The axles contain some of the fluid, so that could account for it. Your finger on a level surface is a better indicator than a spec, so I was told by multiple sources when I had the issue.
  9. Jun 8, 2014 at 8:18 AM
    #1629
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    You also have to account for the little left in each quart, hose, pump ect. You cant get every ounce out of and into.
  10. Jun 9, 2014 at 8:23 AM
    #1630
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Hi guys. New to the forum and been lurking and reading for a few days now. I recently just finally bought a Taco after yeards of wanting one. bought one less than a week ago. 2003 Double Cab 4x4. 142k miles.
    As with all used cars I buy, I like to change all the fluids. so my question is is 75w-90 good for this year with that many miles for the rear diff and transfer case? are the transfer case and front diff the same thing?
    Also, any recommendations on what weight, brand, and kind of Transmission fluid I would need to change that? I read i would need between 2-4qts to drain and fill. I dont plan on dropping the oil pan.
    Thanks for any information you guys can provide me.
  11. Jun 11, 2014 at 5:25 PM
    #1631
    Tbryson2
    Tbryson2 Well-Known Member
    Terry
    Central Florida
    05 PreRunner SR5
    Ok, call me a glutton for punishment, but I have read through all of the posts & do not see an answer to THIS question
    I know mine calls for 3 quarts & LSD additive. But do I wind up with 3 quarts, 4 ounces when totally finished? Or do I subtract 4 ounces of lube and wind up with 3 quarts total?, (unless it runs out of the fill port first)
    using Castrol non-synthetic. Haven't read anything about Castrol on this thread.
    Thanks!
  12. Jun 11, 2014 at 5:29 PM
    #1632
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Add 2 qts of oil, then add the right amount of LSD additive, then fill with oil after that until it starts to drip out, put in fill plug, wait a couple minutes for oil to settle, remove fill plug and fill with oil until it drips out again, then install fill plug to appropriate torque.
  13. Jun 11, 2014 at 8:17 PM
    #1633
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    Roger that!
  14. Jun 12, 2014 at 7:13 PM
    #1634
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I think it has been mentioned before, but I recommend a six-point 24mm (or 15/16") socket for the drain/fill plugs on the rear diff, transfer case, manual trans.
    An eight-point socket, if you have stuck drain/fill plugs, it can round the plugs. Six-point works much better . . . . .
    And for the front diff an Allen socket not just an Allen wrench. Just thought of this, is it possible to put a 24mm plug from the rear diff or transfer case into the front diff to replace the 10mm Allen plug? I was at the dealer getting a new 24mm for the transfer case, and they tried to sell me a 10mm Allen like the front diff, said it was the correct one. It LOOKED like the correct thread and it would work when he brought it out and showed it to me, but I told them to get me a rear diff 24mm and that worked fine on the transfer case. But, maybe it's possible to swap out the 10mm Allens. Those 10mm Allens are a little shaky if you ask me.
  15. Jun 12, 2014 at 8:15 PM
    #1635
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    That's honestly a great idea. Plus finding my 10mm Allen socket months from now when I have to replace fluids again will be another challenge altogether.
  16. Jun 18, 2014 at 3:50 PM
    #1636
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    So you only need to buy the pump for the transfer case, right?
  17. Jun 18, 2014 at 7:42 PM
    #1637
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Correct
    Harbor freight has them cheap
  18. Jun 19, 2014 at 6:13 AM
    #1638
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Or just use a funnel and snake some tubing...much cheaper...
  19. Jun 19, 2014 at 2:29 PM
    #1639
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  20. Jun 19, 2014 at 9:47 PM
    #1640
    Jeffaz1
    Phoenix, AZ
    OK, so I have an 06 Prerunner access cab 2wd and what I bought was Valvoline 75W-90 gear oil which says Limited Slip on it. It's not synthetic. And the only additive Autozone had, which is Trans-X Posi-Trac limited slip additive, is 7 ounces! Should I pour the entire 7 ounces in? Thanks in advance. Awesome thread. You can go through the whole thing and anticipate any problem others already had.
