Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 19, 2014 at 9:56 PM
    #1641
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    subd about to hit 60K and no clue if it was previously done
  2. Jun 20, 2014 at 1:56 PM
    #1642
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Did you read the first post in the thread?? You ONLY need the additive if you have a Sport with the decal on the diff
    "NOTE: 2009 and newer trucks do NOT need LS Diff addative, or TRD Off Road trucks with the factory locker.
    Yesterday we (Chris4x4, and I) got together to help you all change your diff fluid.
    Here is what is required;
    -24mm socket (1st gen diff may be a different size)
    -ratchet
    -rags/shop towels
    -milk jug or coffe can... EMPTY ofcourse!
    -3 qts 75-90 weight gear oil ( I used 80-90 becasue it was readily available)
    (for you guy like me w/ the Sport model, you'll need a 4oz. tube of LSD additive)."
  3. Jun 20, 2014 at 4:34 PM
    #1643
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    Mine is NOT 2009 and newer, so I assumed I needed the additive!
  4. Jun 20, 2014 at 4:47 PM
    #1644
    ImpulseRed008
    Susan
    SC
    Only if it's a sport model and you have the sticker on the diff. Otherwise not needed.
  5. Jun 20, 2014 at 5:07 PM
    #1645
    Jeffaz1
    Phoenix, AZ
    I'm not saying you are wrong, but I don't see that from the first post of this thread. I got under and took a picture and there are 2 stickers on mine, but it's not a sport..
  6. Jun 20, 2014 at 5:30 PM
    #1646
    ImpulseRed008
    Susan
    SC
    He has a sport model and he has the sticker on the diff
    Post a pic of your truck. What color is your front grill? mirrors? back bumper? are they color matched? do you have the outlet in the bed? Maybe it's a sport with the decals taken off the bed sides? :notsure: it's happened before Or the diff has been replaced.
  7. Jun 20, 2014 at 9:31 PM
    #1647
    Jeffaz1
    Phoenix, AZ
    It's not a Sport. I bought it new. And mirrors are black, chrome bumper, no outlet in bed.
  8. Jun 20, 2014 at 9:38 PM
    #1648
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I had the LS diff on my '07, and it wasn't a sport either.
    Susan, On the '05, thru '08, and LS Diff was an option on the SR5 trucks. Not sure why Brian said TRD Sport's only.
  9. Jun 20, 2014 at 9:41 PM
    #1649
    Round II
    Round II Member #12005
    Because he's watching you through your side window, over the wall, in the bushes.:eek:
  10. Jun 21, 2014 at 3:31 AM
    #1650
    jcman01
    jcman01 Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    I've done both the snaked tube method and the pump method.
    The pump I bought is cheap and less hassle. By the time you snake all the tubing and connect it all up, you might as well just screw on the pump (I had to use duct tape for a tight seal) and pump.
    It took about 2 or 3 minutes. I then soaked the pump overnight in soapy water, and it is ready to use again.
    http://www.amazon.com/gp/product/B000BQW5LK/ref=wms_ohs_product?ie=UTF8&psc=1
  11. Jun 21, 2014 at 7:17 PM
    #1651
    devkurf
    devkurf Member at Large
    midwest
    I just changed it on my 05 non-TRD Sr5, and it has the LS option. Thanks for the write-up.
  12. Jun 21, 2014 at 7:22 PM
    #1652
    ImpulseRed008
    Susan
    SC
    Thanks Chris.... didn't know that. Maybe update the first post :notsure:
  13. Jun 22, 2014 at 9:24 AM
    #1653
    Jeffaz1
    Phoenix, AZ
    Thanks so much for the tutorial and everyone else for sharing their advice because I was a little hesitant, but did this last night and had no problem. I had to buy the 24mm socket and breaker bar, but neither plug gave me any trouble. It definitely looked like it needed changed. So there is now one more thing I know how to do to my truck!
  14. Jun 22, 2014 at 9:25 AM
    #1654
    ImpulseRed008
    Susan
    SC
    :woot:
  15. Jul 5, 2014 at 6:47 AM
    #1655
    K Williams
    K Williams Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Well...the dealership is supposed to "inspect" the diff oil at 15,000 miles. My truck is there and they better do what I paid for. Will be checking for wrenching marks on the plug when I go to pick it up! I don't trust these stealerships for nothing.
  16. Jul 5, 2014 at 7:01 PM
    #1656
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Not for nutt'n but Y wood U pay the stealership 2 inspect the diff - just DYI and change it on your own schedule & save $$$ plus U will know it's done and done right !
  17. Jul 6, 2014 at 11:08 AM
    #1657
    jackbower6864
    jackbower6864 Member
  18. Jul 6, 2014 at 3:00 PM
    #1658
    Stlcardsfan
    Stlcardsfan New Member
    Thanks for the awesome write up! I was a little intimidated having never done this before but the step by step gave me the courage to try. I have an 08 2.7L with 105K miles on it and I doubt this service has ever been performed on the truck.
    All jobs are remarkably easier with the proper tools and in my case I do not have jack stands or a breaker bar - both would have been very useful for this service. So, laying on my back with very little room to work and a 3/8 ratchet made it extremely difficult to remove the fill plug. I hit it with some PB Blaster and let it sit overnight, hit it with a hammer a few hundred times and tried with all my might to get that sucker off until I was about to give up. Then, while laying in my bed this morning and brainstorming about my predicament I came up with a solution that others may find useful. I placed the ratchet on the drain plug and angled it downward at a 45 degree angle and held it to the plug with the sole of my boot. I then slid the cup of my hydraulic jack under the ratchet and jacked it up.....Ta Da!!! Bolt came loose and I celebrated in amazement.
    The oil that came out of that thing was absolutely disgusting: Dark brown, very cloudy and very thick (sludge). So glad I did this and I hope no major damage was done by waiting so long. I didn't see any metal in the oil though. Thanks again for the instructions guys. This forum rocks!
  19. Jul 7, 2014 at 11:14 AM
    #1659
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    You might want to double check your seals for leakage and consider putting in a diff breather mod if you put the back wheels in water sometimes.
  20. Jul 7, 2014 at 11:59 PM
    #1660
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Gonna change my fluids sometime this week when it gets delivered. Can't wait to see how bad it is. Don't know if it was ever changed. Bought the truck at 100k. One prior owner, but I put on almost 20k in two years.
