Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Sep 12, 2014 at 8:11 PM
    #1681
    meangene21
    meangene21 Well-Known Member
    Gene
    Virginia
    2008 Double Cab SR5 4x4
    Are crush washers needed on the plugs? I plan to change mine in the near future but didn't see any mention of washers being needed. This may have been addressed but I'm too lazy to read through all 85 pages.
  2. Sep 12, 2014 at 8:17 PM
    #1682
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Yes, they have crush washers. I re-used mine but all depends on the condition of the old one.
  3. Sep 13, 2014 at 5:11 PM
    #1683
    meangene21
    Gene
    Virginia
    Changed mine today and picked up the crush washers for $1.50 each at the stealership. I'm sure I could have picked them up cheaper online but didn't want to wait. Great writeup and made the process very simple.
    Keep up the good work and thanks for saving me $$$. Changed my plugs last week thanks to this site also!
  4. Sep 14, 2014 at 3:33 AM
    #1684
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes.... FYI - they're two different sizes.
    I went to my dealership and told the guy I needed 1 for each (front & rear) and he gave me two of the exact same size.
    It wasn't until my diff was empty that I discovered there are two different sizes. I had to reuse the one - luckily, it hasn't leaked yet.
  5. Sep 16, 2014 at 4:06 PM
    #1685
    norb240
    norb240 Member
    Norb
    CA
    06 PreRunner
    LOL yea i have the oh so great mechanical LSD that came factory installed on my 06 Prerunner:D
  6. Sep 17, 2014 at 7:08 AM
    #1686
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Crush washers are no big deal, i still have the original oil pan washer. 11yrs and 190,000mi later still using it.
  7. Sep 17, 2014 at 8:24 AM
    #1687
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Don't know if it has ever happened on a truck or not, but I've seen many cracked aluminum engine cases on motorcycles from reusing crush washers. Some of the washer gets pushed into the hole between the bolt and the female threads and eventually wedges a crack
  8. Sep 17, 2014 at 8:48 AM
    #1688
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Ok so I have a 2011 TRD off road Prerunner no sticker on the diff. My question is do I need the LSD additive or not ? :confused:
  9. Sep 17, 2014 at 7:39 PM
    #1689
    TACO TX
    Kelly
    Denison ,Texas
    Nobody from i believe 2009 and up needs LSD additive, they are not mechanical LSD's. You being a TRD off road definatley do not.
  10. Sep 17, 2014 at 7:41 PM
    #1690
    TACO TX
    Kelly
    Denison ,Texas
    Yea i definatley need to replace it, better safe that sorry i guess.
  11. Sep 18, 2014 at 5:34 AM
    #1691
    tacoma guy
    Joe
    Phoenix Az.
    Ok awesome . Thanks for the info !!
  12. Sep 23, 2014 at 12:44 AM
    #1692
    DaveIRC
    DaveIRC Active Member
    David
    Seattle, WA
    07 Tacoma 4WD SR5 TRD Sport
    I've been reading for hours most of the pages on this thread.
    I have a 07 trd sport pack with the lsd sticker.
    Been to autozone today and could not find any non syntethic oil.
    By experience I would be curious what specific non syntethic oil would you guys recommend for the rear and what specific ls aditive
    Few options that I came up with so far, but please add to it. Would appreciate others input by experience.
    Aditive:
    GM 1052358 - some say they like it
    CRC SL2411 Equa -Torque Differential Friction Modifier, 4 Wt Oz - as the post mentions
    CRC 402508 Trans-X Posi Trac Limited Slip Gear Oil Additive, 7 Fl Oz - looks like would do the same job as the crc 4oz option
    Oil with aditive:
    Dexron LS 75W-90 Gear Oil - by Gm with aditive already added in it
    Oils:
    75W90 NS GL-5 Gear Oil RedLine
    MT-90 75W90 GL-4 Gear Oil RedLine
    Severe Gear® 75W-90 Amsoil
    Any one experienced better results with a specific?
    Would like to purchase one of this and change the diff oil asap.
    Last q: what would be best option for the front diff oil?
    thanks in advance
  13. Sep 23, 2014 at 2:50 AM
    #1693
    Janster
    Jandy
    Lancaster, PA
    I use FORD XL3 friction modifier - bought at Ford dealer (with Mobile 75w-90). You can actually buy this stuff online/ Amazon.
    We've used Amsoil Severe Gear in our Corvette - has done nicely in the corvette.
    Each situation is different. Amsoil is a synthetic. Since I use synthetic, I've had to use extra modifier to keep the diff / prevent rumbles & such.
    If you use synthetic and/or a synthetic oil with the friction modifier already in it, you may (or may not) need to add more modifier.
  14. Sep 23, 2014 at 8:09 AM
    #1694
    DaveIRC
    David
    Seattle, WA
    Isn't Mobile 75w90 a synthetic oil? Is it ok to use synthetic oil?
    thank you
  15. Sep 23, 2014 at 8:38 AM
    #1695
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yes its OK but you may have to use more friction modifier as stated.
  16. Sep 28, 2014 at 5:46 PM
    #1696
    No Way Out
    No Way Out Member
    Doug
    PA
    07 Tacoma SR5
    2011 Grille, Painted lower valance, Fog Light Mod, Black Headlight Mod, Rugged Trail Rims, Bilstein 5100's, More on the way.
    Great write-up! Just did this today on my 07 Sport. Used Castrol non-syn with LSD additive. Also did the t-case and front diff but used Mobil 1. Thanks!
  17. Oct 5, 2014 at 6:50 AM
    #1697
    RTD
    RTD Well-Known Member
    Taxachusetts
    I had clutch grab(inside tire grabbing on a turn) with Mobil 1 LSD and RP, but smooth as silk with RP plus MOPAR LSD additive
  18. Oct 5, 2014 at 6:54 AM
    #1698
    RTD
    Taxachusetts
    I was at the Toyota dealer yesterday, and I was told they use the FORD additive!
    I've been using MOPAR
  19. Oct 8, 2014 at 11:54 AM
    #1699
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
  20. Oct 8, 2014 at 11:56 AM
    #1700
    Z E R 0
    California
    02 Tacoma 4x4
    I have a 2014 tacoma prerunner 4.0.. Do I need the lsd additive? And should I buy the fluid at the dealer? Or what do you guys recommend? Thx a lot
