Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 24, 2015 at 4:29 PM
    #1741
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Thanks for the write-up guys. Just flipped 30,000 so started searching threads for maintenance items. I've read through a lot of this tread and it seems that there are mixed reviews on using synthetic. The local Advance Auto Parts has Royal Purple Dino for $20.99. Amazon has Royal Purple Synthetic for $17.79 and free shipping. The price difference isn't a big deal and don't mind paying more for the Dino oil if that's better for the truck. What would you do? 2011 Base SR5 4x4 Thx
  2. Jan 24, 2015 at 4:30 PM
    #1742
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can run a good synthetic with no issues in your truck. Only have to worry about it in the '08's and earlier with the LS Diff.
  3. Jan 24, 2015 at 4:54 PM
    #1743
    sdc09taco
    sdc09taco Well-Known Member
    dave
    central ma
    09 access sr5 trd off road
    not yet
    being to lazy to do this myself(unheated garage in winter),i had i done and told them not to add any additive to it...but when i started to look the the receipt i notice that it said that additive was added to mine :mad:...its a trd OR, is this a problem or issue waiting to happen?they said no harm done and that its good to have it :confused: can someone add there 2 cents on this
  4. Jan 24, 2015 at 4:57 PM
    #1744
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I don't think it should hurt anything, but I would make them re do it.
  5. Jan 24, 2015 at 5:59 PM
    #1745
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    Dang really? I've got an 08 and filled with full synthetic... So far honestly somehow my gas mileage has improved. Do I need to switch it out and replace the synthetic?
  6. Jan 25, 2015 at 6:01 AM
    #1746
    Bagman
    Area 51
    Thanks for the quick response. Will get this done today. Although your "Reps" are full I added to it anyway. Cheers
  7. Jan 25, 2015 at 8:09 AM
    #1747
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As long as the diff isn't chattering, you should be fine.
  8. Jan 25, 2015 at 8:09 AM
    #1748
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Jan 25, 2015 at 9:45 AM
    #1749
    johnny2154
    johnny2154 Well-Known Member
    Johnny
    Brewster, MA
    I just changed the oil in the transfer case, started it up and put it into H4, then put it into L4 and the beeper went off, then back into H4 the beeping continued, then into H2 and the beeping still continued and still read in Lo. Finally after going up and down the driveway I stopped and put it into Nuetral and into H2 and it went back to normal. Anybody have any ideas?
    Thanks
  10. Jan 26, 2015 at 12:07 PM
    #1750
    12MGM
    12MGM Active Member
    Josh
    VA
    12 PreRunner DCSB Off Road Package
    Westin Nerf Bars, Weathertech Floor Mats, Carhartt Seat Covers, Salex Center Console Organizer, Bed mat
    This seems like such a simple thing to do.... unless it seems like the fill plug has been welded on at the factory... Not literally, but I could not, for the life of me, get the thing loose... Tried a cheater bar too, no go... I usually don't have that much trouble with simple maintenance but this truck is making me feel less and less mechanically inclined...
  11. Jan 26, 2015 at 3:14 PM
    #1751
    12MGM
    12MGM Active Member
    Josh
    VA
    So I contacted the local shop I use (not a dealer). I told them I couldn't get the bolt off but already had the gear oil, what would they charge to finish it up? $83.49 for labor using my oil. Suddenly, I became more mechanically inclined and got my hands on an impact wrench and got that bolt off. Turns out the previous owner must have been on top of things, the oil came out pretty clean and there was nothing on the magnet. Anyway, thanks for the write up and saving me $83.49
  12. Feb 1, 2015 at 8:27 PM
    #1752
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
  13. Feb 12, 2015 at 6:48 PM
    #1753
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Should I use the same oil and additive for the first gen non-Trd?
  14. Feb 12, 2015 at 6:52 PM
    #1754
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only if it has an LS DIff.
  15. Feb 12, 2015 at 7:28 PM
    #1755
    Shortman5
    Supercharged TRD
    LS?
  16. Feb 12, 2015 at 7:44 PM
    #1756
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Nobody seems to read whole threads anymore..
    Limited Slip
  17. Feb 12, 2015 at 7:51 PM
    #1757
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Why should I read, when I can ask the same question that's already been asked 100 times? :rolleyes: :cool:
  18. Feb 12, 2015 at 8:02 PM
    #1758
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take it easy folks.
  19. Feb 13, 2015 at 3:00 PM
    #1759
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    1000 X more like it:D
  20. Feb 14, 2015 at 1:25 PM
    #1760
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Dun. Thanks for the write up. Front, rear and transfer case all happy playing in royal purple now. Just a little late @ 41k, but nothing to speak of in either diff and the transfer case looked like new oil.
    Time to roll out to the Endemion parade.
    :woot: :cheers: :drunk: in that order for the rest of the day
