Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Feb 16, 2015 at 1:01 AM
    #1761
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I just changed the rear diff fluid at 45k miles. It is dark and smelly. I used Mobil 1 75W90 LS because I couldn't find Mobil 1 non-LS fluid.
    However I found a piece of thin metal strip coiled up like a spring that was stuck on the magnet. Should I be concerned?
  2. Feb 20, 2015 at 10:11 AM
    #1762
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    So I have a 2012 sr5 dclb 4x4. I thought the truck had a auto lsd? Is that correct?
    I am about to change the diff oil..Thanks
  3. Feb 20, 2015 at 10:50 AM
    #1763
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    It should have an auto LSD Yes, But, the Auto LSD is merely the brakes being manipulated to simulate and LSD, so use standard gear oil without friction modifier.
  4. Feb 20, 2015 at 10:57 AM
    #1764
    2ski4life7
    Seattle WA
    So I just read through the manual. It states to only change the diff oils/tf case if you tow. I read for every interval up to 120k. Not for any specific mileage. I have 60k and was going to change all three but I don't tow. It suggests changing every 15k if you tow.
    I realize everyone will say just change them but why doesn't toyota have a specific mileage under normal operating conditions?
  5. Feb 20, 2015 at 10:58 AM
    #1765
    2ski4life7
    Seattle WA
    Thanks!
  6. Feb 20, 2015 at 10:58 AM
    #1766
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I found the same thing on mine as well. My front diff was really dark and my rear was nice and clear.
  7. Feb 20, 2015 at 9:29 PM
    #1767
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    Did mine tonight for the first time in 9 years. I know it should have been done loooooong ago. Things went well except for the fill plug. I could not get it off with my ratchet. So I hooked up the impact and it spun right off. Good to go for another few years. I also changed the plugs, cleaned the MAF, and cleaned the throttle body. Thanks for the write up!
  8. Feb 22, 2015 at 11:08 AM
    #1768
    2ski4life7
    Seattle WA
    So all the oils at the auto shop said ls. Is it okay to put this in the front diff and trans case?
  9. Feb 22, 2015 at 11:43 AM
    #1769
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I am going to be doing mine on my 2011 TRD off road prerunner. Should I be concerned about not being able to get the drain / fill plug off ?
  10. Feb 22, 2015 at 12:50 PM
    #1770
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Breaker bar and you should be fine. Fill plug first!!!!
  11. Feb 23, 2015 at 6:19 AM
    #1771
    tacoma guy
    Joe
    Phoenix Az.
    :thumbsup:
  12. Feb 28, 2015 at 8:04 AM
    #1772
    KaPantsKey
    KaPantsKey Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
  13. Mar 3, 2015 at 5:00 AM
    #1773
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    morning bump.
  14. Mar 3, 2015 at 5:04 AM
    #1774
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Read post #1 on this thread.
  15. Mar 3, 2015 at 5:37 AM
    #1775
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The LS only means that its 'compatible' for Limited slip (mechanical) differentials.
    You don't have a mechanical limited slip diff.
    LS or non-LS - it doesn't matter. Mobile 1 doesn't have friction modifier in it at all.
  16. Mar 3, 2015 at 6:47 AM
    #1776
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
  17. Mar 3, 2015 at 7:05 AM
    #1777
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Thanks. I was confusing the LS on Mobil1's bottle with the additive. I guess that means it is compatible with the additive, not that it has it premixed.
  18. Mar 4, 2015 at 5:22 PM
    #1778
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    I couldn't read all the pages but most of the ones I read implied that you need to change it at 15k regardless. The only difference is adding additive or not (except second gen doesn't need it, period)
    But from reading the Maint Guide for second Gen:
    15k: Inspect front differential oil (4WD) and rear differential oil
    15k with towing: Replace front differential oil (4WD) and rear differential oil
    30K: Replace rear differential oil (Prerunner and 4WD vehicles with optional limited slip differential only)
    30K with towing: Replace front differential oil (4WD), Replace rear differential oil, and Replace transfer case oil (4WD)
    The 15k service seems to suggest change the diff oil only with towing and doesn't say LSD equipped or not. But 30K service says to change only if LSD equipped, and with towing, also change front and transfer case for 4WD.
    This is confusing....
    Also, in case the LSD sticker fell off, is there a way to tell which trim for sure comes with LSD or it's a completely separate option? Mine is Prerunner TRD Sport and was planning doing the 30k service without changing the rear diff oil until I read this thread.
    Thx
  19. Mar 4, 2015 at 5:47 PM
    #1779
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You don't need the LS Diff addative.
  20. Mar 4, 2015 at 5:57 PM
    #1780
    amati5
    2010 Prerunner TRD
    So LSD is part of the Prerunner TRD Sport trim? The wording in the guide sounds like only Prerunners and 4WDs that come with LSD option need to replace the oil.
    Thx
