Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Mar 4, 2015 at 6:00 PM
    #1781
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The LS diff in your truck, is operated by brake application, not a mechanical assembly in the diff.
  2. Mar 4, 2015 at 9:50 PM
    #1782
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    Thx. That explains it. I read the manufactuer's sale sheet and the standard equipments list shows Auto LSD but i don't see the LSD sticker on my car.
  3. Mar 7, 2015 at 5:09 AM
    #1783
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hi Chris . Is this the same on a 2011 TRD OFF ROAD prerunner ? If so then I don't need any additive , correct ?
  4. Mar 7, 2015 at 8:32 AM
    #1784
    amati5
    2010 Prerunner TRD
    From my searchh, I think Toyota stopped using mechanical LS in all Tacomas, starting 09. Their maint. guide says to replaced at 30k only with LS option is misleading. I guess they never bother to change the manual.
    Anyway, I changed mine yesterday and the old fluid, at 30k, looked and smelled just like the new one.
  5. Mar 7, 2015 at 8:33 AM
    #1785
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct.
  6. Mar 7, 2015 at 11:15 AM
    #1786
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes...
    Mobile 1 never put friction modifiers in their oil. They just changed the 'advertising' on the bottle to say its LS compatible.
    Some other gear oil manufacturers do put friction modifiers in the oil (Amsoil Severe Gear - for example). Because you don't have a mechanical LSD, you could use either oils (with or without friction modifier) and you'd be fine.
    It's only those folks who have the mechanical LSD who have to make sure the oil has friction modifier in it (or add it).
  7. Mar 7, 2015 at 12:44 PM
    #1787
    tacoma guy
    Joe
    Phoenix Az.
    Awesome . Thanks Chris for your reply much appreciated !!;)
  8. Mar 7, 2015 at 2:52 PM
    #1788
    sgtcasey
    sgtcasey New Member
    New Mexico
    2007 Tacoma Double Cab PreRunner
    Thanks for this thread. I changed out the rear differential oil on my 2007 Tacoma this afternoon. I think the dealer got it during a service a few tens of thousands of miles ago but I like getting back into doing this sort of maintenance myself.
  9. Mar 8, 2015 at 8:05 PM
    #1789
    TNSPRUCEMICA
    TNSPRUCEMICA Member
    Clarksville, TN
    2013 TRD SPORT Double Cab 4x4
    Ok guys so I have a 2013 Double Cab TRD Sport 4x4, will I be fine if I run Royal Purple SYNTHETIC gear oil in my Front & Rear diff, and Transfer case thanks for the help just got lost with all the info on this one.
  10. Mar 8, 2015 at 8:14 PM
    #1790
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    As long as the weight is right it should be good, AFAIK.
  11. Mar 8, 2015 at 8:18 PM
    #1791
    TNSPRUCEMICA
    TNSPRUCEMICA Member
    Clarksville, TN
    Ok thanks guys I was planning on running the 75-90 Royal Purple SYNTHETIC. The whole LSD additive talk was getting me confused as to if I needed it or not.
  12. Mar 10, 2015 at 12:21 PM
    #1792
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    If you are in a 13 you do not have to add the additive.
  13. Mar 16, 2015 at 9:47 AM
    #1793
    TacoTakeover
    TacoTakeover Well-Known Member
    I have a 2013 DC Sport and I'm a bit confused. For the Sport model beings it greater than 2011, I don't need the 4 ounces of LS additive correct? So the mobil1 70w-90 will be fine to use right? Or do I need the 70w-90 LS? Thanks!
  14. Mar 16, 2015 at 9:55 AM
    #1794
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    you don't need the additive, and any of the oils you posted we'll be fine.
  15. Apr 6, 2015 at 2:41 PM
    #1795
    Titus139
    Titus139 Well-Known Member
    Tim
    NorCal
    2011 Tacoma DCLB
    Hey guys. New Tacoma owner here. Just picked up a 2011 DCLB 4x4 Sport. It's got 91K and was thinking about doing some maintenance on it. What is needed for the front/rear diff oil change? Thanks in advance.
  16. Apr 6, 2015 at 9:10 PM
    #1796
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    Hi all, I'm sure the answer to my question is somewhere in the 1,808 previous posts in this thread, but I can't find it. I have an '09 regular cab 2wd manual trans. My owners manual says the oil capacity in my differential is 3.66 quarts. I drained out the old (which was roughly that amount) and pumped in a full four quarts - and it never did run back out of the top hole where you add it. Do I need to add even more? Have I already put too much? This is an '09, so it's an open diff (first year for the electronic limited slip via brakes)... no locker or mechanical limited slip mechanism in the diff. Maybe the diff. holds more oil without that stuff in there and they neglected to update the manual? WTH?
  17. Apr 10, 2015 at 9:36 AM
    #1797
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    Just to confirm: I have a 2011 Tacoma Sport DCSB. Based on the write-up, I do NOT need to use the LSD additive. Is that correct? Thanks!
  18. Apr 10, 2015 at 9:37 AM
    #1798
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    ^ Correct.
    Read the OP's first line.
  19. Apr 14, 2015 at 2:01 PM
    #1799
    jetspeedz
    jetspeedz Member
    I put in mobil1 75w90 LS in my 07 tacoma with lsd and i'm getting a little judder at slow speeds. I realize this mobil1 has LSD advertised so should I add a 7oz bottle of Trans-X or leave it be? Any harm in adding it? also should i add 4oz or 7oz?
    Thanks
  20. Apr 14, 2015 at 6:33 PM
    #1800
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    from the first post: (for you guy like me w/ the Sport model, you'll need a 4oz. tube of LSD additive).
