Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jul 1, 2015 at 10:04 AM
    #1821
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Quick question for guys using Royal Purple. Do I need to add friction modifier for my LS rear? I did a quick drive, just to get rid of the old oil, and the rear feels tighter, does that mean I'm binding, or am I good?
  2. Jul 15, 2015 at 3:45 PM
    #1822
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Took care of my rear dif today at just just under 60k. Amsoil 75/90 severe synthetic and Trans-x lsd additive. Pretty easy job. Worst of it is dropping the spare - gotta do the guide mod. Toyota dealer sold me 1 correct crush washer and 1 incorrect larger copper flat washer. I put the new crush on the drain and reused the fill and I'll keep an eye on it.
  3. Jul 27, 2015 at 6:50 PM
    #1823
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Changed rear differential fluid today. Drain bolt had some sludge & metal chips. Fluid looked good though. I'm right at 30K miles.
    Really good how-to write up. Appreciate you taking the time to do it chris4x4 & brianr.
  4. Aug 10, 2015 at 3:25 PM
    #1824
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I had metal chips on my magnet. I found a few in particular to be on the larger size. image.jpg
  5. Aug 10, 2015 at 7:36 PM
    #1825
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Mine was the same, I wouldn't worry about it. Unless someone else says otherwise.
  6. Aug 10, 2015 at 7:56 PM
    #1826
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^^
    4WDTrout[QUOTED] likes this.
  7. Aug 14, 2015 at 12:30 PM
    #1827
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Thinking about changing the rear diff fluid in my 2013 Access cab. Truck is at 42k and i bought it at 35k. Don't know if its ever been done before but its so easy and im sure it wouldn't hurt to change it!
    opteron likes this.
  8. Aug 14, 2015 at 12:31 PM
    #1828
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    Do it, real easy. easier than a oil change.
    moe2o4[QUOTED] likes this.
  9. Aug 14, 2015 at 12:33 PM
    #1829
    moe2o4
    Corey
    Pittsburgh PA
    I'll have to look in the book and see how much it takes and stop and get some fluid on the way home from work. Where can u get one of those quart pumps or i guess u dont need it if you get that bottle with the small needle like tip right?
    opteron[QUOTED] likes this.
  10. Aug 14, 2015 at 12:36 PM
    #1830
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
  11. Aug 14, 2015 at 12:37 PM
    #1831
    moe2o4
    Corey
    Pittsburgh PA
    Sounds good. Gonna go out and get the book now and see what it takes and how much!!!!
  12. Aug 14, 2015 at 12:46 PM
    #1832
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Most gear oils come with the 'needle tip'
  13. Aug 14, 2015 at 12:48 PM
    #1833
    moe2o4
    Corey
    Pittsburgh PA
    So looks like the book says "Toyota Genuine Differential Gear Oil LT 75W-85 GL or equivalent. What the heck is LT 75W-85???? LOL And the capicity it says is 3.12 qtuarts so i guess i gotta buy 4 quarts lol
  14. Aug 14, 2015 at 1:39 PM
    #1834
    moe2o4
    Corey
    Pittsburgh PA
  15. Aug 14, 2015 at 1:44 PM
    #1835
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    You might be able to get away with 3qts, but get 4 to be on the safe side. I'm a valvoline fanboy so my vote is with them.
  16. Aug 19, 2015 at 1:53 PM
    #1836
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Does the drain plug or fill plug have the magnet on it for the rear diff? When I did mine I Put the magnet on the drain is that correct?
  17. Aug 19, 2015 at 2:15 PM
    #1837
    Hardscrabble
    Scott
    McDonough, GA
    The drain plug has the magnet. Pull the chips/debris to low point of housing.
  18. Aug 19, 2015 at 2:17 PM
    #1838
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    Sweet thanks. I was pretty sure that was correct but thanks for the peace of mind.
  19. Aug 21, 2015 at 8:56 AM
    #1839
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I am attempting to remove the fill plug on my rear differential. This may sound like a dumb question but loosening the bolt by turning to the left? That is what I am attempting with a breaker bar but it won't budge. Any suggestions?
  20. Aug 21, 2015 at 8:58 AM
    #1840
    moe2o4
    Corey
    Pittsburgh PA
    Lefty Loosie, Rightie Tightie lol. It should come. Spray some pb blaster on it and let it soak a little!!!!
