Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Nov 21, 2015 at 11:12 AM
    #1961
    MPOW33R
    MPOW33R Well-Known Member
    MoMo
    East Bay, California
    A Few Air Cooled Porsche, A Few Water Cooled Porsche, 2018 Mag Gray Limited 4x4 (TRD Pro Rep 6/2023) 17 Mag Gray DC SB TRD Sport Premium JBL NAV Tech | 10 Mag Gray DC SB TRD Off Road JLB Audio
    10' TRD Beadlocks, LTX MS/2s , Skid Plate, Roof Rack , Tonneau, Full Stereo System w.DVD 17' TRD Pro 17s, TRD PRO Grill, TRD Pro Rigid Fog Lights, TRD Pro Tails, TRD Pro Knob, TRD Pro Bugle and Hood Decal, 265/70/17 BFG KO2s (C), TRD Skid Plate, OEM Tri Fold Tonneau, OEM Roof Racks, TRD Exhaust Tip, All LED Lighting, Tacoma Matte Tailgate Lettering, OEM Rear Bed Step, Remote Start, Locking Tailgate
  2. Nov 22, 2015 at 1:49 PM
    #1962
    MPOW33R
    MoMo
    Oh boy!!! Ok here we go
    Changed out the diff and Trans fluid here is what I used and my results
    OEM Trans Fluid simple pan flush and fill
    Royal Purple diff fluid
    Redline additive
    Chatter is a WORSE and now in more gears then just 4th going into 5th -
    In the best way I can explain this is as if you're driving an manual transmission and you go from 1st to 4th by accident - that chatter that feeling you get the mild bumpy jerky feeling is what I get- keep in mind my truck is automatic, the chatter lasts a few seconds the car engages upshift and I'm good to go
    My problem only occurs at low speeds and when driving aggressive there is no issue whatsoever -
    Thinking it may be a sticky solenoid or maybe just my tranny going out - any ideas fellas !!??!??
  3. Nov 22, 2015 at 3:38 PM
    #1963
    MPOW33R
    MoMo
    Well the only thing I did do to the transmission was a pan flush and fill do you think I should do a complete pressurized flush the transmission and then try ?
    Strangely enough if I drive in fourth gear again in my automatic but just slap the stick over to the left into fourth I never experience the problem . In regular drive mode I can feel that issue in other gears like second third and usually and most commonly 4th going into 5th. I'm stumped
  4. Nov 22, 2015 at 3:48 PM
    #1964
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Some rear diffs DO NOT like synthetic fluid others it does not bother. drain and fill with dino oil and see if it goes away
    DoorDing likes this.
  5. Nov 22, 2015 at 4:02 PM
    #1965
    MPOW33R
    MoMo
    Thanks fellas will try this tomorrow !!
  6. Nov 22, 2015 at 4:04 PM
    #1966
    ImpulseRed008
    Susan
    SC
    :smack: :rant: :annoyed: :mad: o_O :angrygirl:
    :D
    ajohnson and 303tacoma like this.
  7. Nov 22, 2015 at 4:15 PM
    #1967
    MPOW33R
    MoMo
    Where do I get DINO oil from? Does it have a brand or name I can search?
    Is there weight to it? IN a quick google search its not very specific
  8. Nov 22, 2015 at 4:16 PM
    #1968
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    So I changed my rear differential oil today, and had some questions and some comments
    First off, the oil didn't seem bad at all after 22,000 miles. I know it's short, but some have said it was bad in the 25-30000 range. Plug didn't have much for gunk either. I only drained out about 2.5 quarts, don't know why it was low.
    Two questions
    1. When I loosened the fill, there was a slight release in pressure. Shouldn't the breather take care of that? I haven't put the rear in any water so I wouldn't expect it to be blocked
    2. When refilling, it took a little over 3.5 quarts. Seems weird, truck was level. Anyone else have this amount go in?
  9. Nov 22, 2015 at 4:18 PM
    #1969
    ImpulseRed008
    Susan
    SC
    I use lucas gear oil [​IMG]
  10. Nov 22, 2015 at 5:02 PM
    #1970
    MPOW33R
    MoMo
    Does this Lucas or "DINO" oil need 4oz additive as well? i.e. Valvoline
  11. Nov 22, 2015 at 5:09 PM
    #1971
    ImpulseRed008
    Susan
    SC
    If it's a sport with the sticker, yes.
  12. Nov 22, 2015 at 5:09 PM
    #1972
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    1. Stock breather is one-way. It will let pressure out when the diff heats up, but when it cools there will be neg. pressure. What you heard was likely vacuum release and not pressure release. You should consider a breather relocate with a 2way valve.
    2. I got almost 4 in mine but I also tilted the axle each way to make sure I drained all I could.
  13. Nov 22, 2015 at 5:27 PM
    #1973
    MPOW33R
    MoMo
    Thanks man much appreciated, Yes its a real SPORT model , thank you again
  14. Nov 22, 2015 at 5:38 PM
    #1974
    MPOW33R
    MoMo
    HAHAHAHAHAHAHAHAH I THOUGHT I WROTE BABE THATS AMAZING ,
    IM MULTI TASKING WITH MY WIFE IN THE KITCHEN HAHAAAAA
    IM NOT GOING TO EDIT THAT NOWW HAHAAAAA
  15. Nov 22, 2015 at 5:49 PM
    #1975
    ejl923
    Eric
    Western Mass
    Yup you're prob right. Thanks!
  16. Nov 23, 2015 at 11:55 PM
    #1976
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    I just changed both diffs and transfer case to Mobil 1 75w90. The diffs were dirty but nothing crazy or bad at 20000 miles. 5000 of those miles have been towing. I don't feel much of a difference just slightly smoother. It was much easier than I thought and the hand pump was well worth the 5 bucks. And it took almost exactly 6 quarts.
  17. Nov 24, 2015 at 12:51 PM
    #1977
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    So I am about to do the rear, front, transfer case at 30K. Been buying supplies a little here and there, do I need crush washers for these or no? how many, 2 each, sizes?
  18. Nov 24, 2015 at 3:22 PM
    #1978
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I'm going to try AMSOIL when I change my diff oil, assuming I can get the drain plug and fill plug off. The first time I tried they wouldn't budge so I sprayed them with PB Blaster and bought a breaker bar for my ratchet. I'm kinda one the fence with the cost of synthetic visit dino as I plan on changing it every 25-30k.
  19. Nov 24, 2015 at 6:53 PM
    #1979
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    My rear diff oil was either original or it was changed sometime before I got her at 42 k miles (unlikely). When I changed it at 137 k miles it was very clean. Almost like new oil.
    However, I only dunked the rear once that I can remember.
    My manual ONLY says to change it if you fall into the non-standard service schedule. The other schedule never says to change it, only check it. If I don't dunk the rear I'll probably wait at least 50 k miles before I change it again and yes, I used synthetic.
    Transfer case and manual transmission oil were also ridiculously clean. Same history on those and same plan for future changes. I am doing the front diff Friday and I suspect it will be just as clean and if so I will wait 50 k for another change.
    If I was dunking it a lot I would go with dinosaur oil and change it more often.
  20. Nov 27, 2015 at 2:15 PM
    #1980
    Gooch
    Orange County CA
    Finally did my front diff. 10 mm hollow hex head for both plugs. Old oil was just as clean as the rear diff. Torqued plugs per the TFSM as follows:
    Drain plug: 48 lb-ft
    Filler plug: 29 lb-ft
    48 lb-ft sounds like a lot but I had actually already hand-tightened it beyond that with a ratchet. I had to back it off. :D
