Changing Differential Oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Logan, Sep 18, 2010.
  1. Sep 18, 2010 at 7:36 PM
    Logan
    Logan [OP] New Member
    I have a 2007 TACO PreRunner Double Cab, 4X2 WD.. Wanting to know..How do I know what type of Differential it has ( Limited-Slip Differential or the other one) and what type of fluid do I use..:confused:
  2. Sep 18, 2010 at 7:42 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    no synthetic if you do NOT have a locker
  3. Sep 18, 2010 at 7:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On the back of the diff, it should have a sticker that says LS diff fluid only. Its a white sticker, with red letters.
  4. Sep 19, 2010 at 2:41 AM
    WINSTEW
    WINSTEW Active Member
    Tim
    Upstate, NY
    06 DCab TRD Sport
    I just did mine on my 06 Dcab TRD Sprt, but I think both rear difffs take the same fluid. I used the Lucas gear oil, I think it was 85W or something like that, just make sure you get the LS additive. The manual calls for 4oz.
  5. Sep 19, 2010 at 3:46 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^
  6. Sep 19, 2010 at 5:45 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Check your owner's manual in the specifications section.
  7. Sep 19, 2010 at 6:05 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
  8. Sep 19, 2010 at 7:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This pic has the sticker you should have if LS equipped:
  9. Sep 19, 2010 at 7:46 AM
    Logan
    thnx for all the information..guys..when reading Brian post..on changing the oil..at the very end..he said to "REPLACE THE FILL PLUG" is there a reason why it need replacing or could I use the same Fill Plug?.. I"m a newbie Sorry if I sound ignorance ...
  10. Sep 19, 2010 at 7:48 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It just means put it back in. No need to replace unless you really messed up the plug taking it off.
  11. Sep 19, 2010 at 8:16 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^
  12. Sep 19, 2010 at 1:39 PM
    larryde09
    Larry
    Rochester, NY
    FYI: don't forget to remove the fill plug before removing the drain plug...you don't want to drain all the fluid only to realize the fill plug is stuck!
  13. Sep 19, 2010 at 2:05 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    that is very important...^^^^^^^^^^^^
  14. Sep 19, 2010 at 7:16 PM
    Logan
    thank U..for stressing that info..I read where ppl had problems when forgetting to undo the fill plug first.. but I"m still confuse on the type of oil..going thru the manual ..it stated to use Hypoid gear oil API GL-5..and the recommended Viscosity for the Rear "Above -18 C (0 F) use SAE 90............ Below -18 C (0 F) use SAE 80W or 80W-90. If I"m reading this right... I"m suppose to use the SAE 90 because where I live the temperature does not fall below 0 F.. am I correct?? Please explain what the correct Viscosity to use..and how much do I need to Fill....
  15. Sep 19, 2010 at 7:18 PM
    crf69
    Ohio
    ummm yeah
  16. Sep 19, 2010 at 7:25 PM
    Logan
    I don't think it's a lsd..from what I read from most of the post..I"m suppose to be checking for a label..and I"m still lost on the Lock ..what's the difrrent.... does a 2 wheel drive have lock or open?? I"m still trying to understand..sorry...for my ignorance...
  17. Sep 20, 2010 at 5:50 AM
    larryde09
    Larry
    Rochester, NY
    If you live in california, arizona or the like, than SAE 90 is probably ok. But I personally chose 80W-90 for all temperatures. This means that it'll act like 80 weight in the winter and 90 in the summer...it splits the difference.
    IMO the 90 is a lighter weight and primarily reduces gear drag (e.g. increases gas mileage, torque, etc), but by choosing a heavier weight, like 80W-90, you won't hurt anything, you'll just be lose that slight increase afforded by SAE 90...but it is negligible and you'll have the confidence of knowing your gear oil is right for any situation.
    As for LSD...I'm not sure if the 2wd as a LSD, but your owners manual should say specificically what you have...if not in the specifications section, than somewhere else in the manual. Even the factory window sticker should say it.
