Changing differential + transfer case fluid; Transmission fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by geodude, Sep 14, 2013.
  1. Sep 14, 2013 at 7:28 PM
    geodude
    geodude [OP] Well-Known Member
    My 2002 2.7L 4x4 5spd is about to hit 90,000 miles. I've only owned the truck for a few years, and I'll assume the previous owner hadn't changed any fluids other than the oil, so i'll be changing out the Rear Differential, and Transfer Case fluids shortly.
    My question is whether or not it would be wise to replace the Transmission fluid as well. It's a 5spd, feels smooth shifting, and no noises; so what concerns me is that I've seen that sometimes changing the transmission fluid can cause new problems, especially on trucks where the fluid hasn't been constantly changed.
    Any advice?
  2. Sep 15, 2013 at 8:40 AM
    geodude
    No objections, I guess it's a go.
  3. Sep 15, 2013 at 8:59 AM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    Changing transmission fluid on an automatic at high mileage can be a bad thing, but I've never heard of it being an issue with a manual. Even at those miles I doubt that changing the fluid would create an issue. Your call though...
  4. Sep 15, 2013 at 9:16 AM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Haha x2. Only on autos, manuals is a different story. Go ahead and change it
  5. Sep 15, 2013 at 9:25 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I need to do this. I have read on here somewhere that GL5 I believe could eat up syncros. So what is the best GL4 or GL5?
  6. Sep 15, 2013 at 10:36 AM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Sorry for the thread jack but..why would changing the trans fluid on a auto be a bad thing? Went to my mechanic the other day and he said it was time for a change.. I usually do all my fluids myself so I told him don't bother.
  7. Sep 15, 2013 at 10:56 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2007 DCSB SR5 4X4
    604YOTA, I think you would find that most people on here are talking about flushing a high mileage auto, not fluid changes.
    Here is a link so you can see the reasoning.
    Trans Flush
  8. Sep 15, 2013 at 12:10 PM
    geodude
    Appreciate the info.
    Thank You
  9. Sep 15, 2013 at 12:14 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BEL Pro500; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'd say it's a good idea to change the oil in your (5-spd) Transmission, Transfer Case, Rear Differential, and Front Differential. They'll drain best if they're warm (i.e., recently run). Another important note is to open the FILL plug on each component BEFORE you remove the drain plug. That way, you KNOW you'll be able to re-fill what you drain. (Doing it the other way around can be an inconvenient and expensive lesson...) Finally, don't forget to replace the crush washers!
  10. Sep 15, 2013 at 12:41 PM
    geodude
    Good advice, any opinions on changing out with full synthetics vs traditional after all those miles on traditional? I'm sure there's plenty out there
  11. Sep 15, 2013 at 12:46 PM
    Norton
    Monument, CO
    I'm sure opinions will vary but, FWIW, I'm a fan of full synthetic and run Amsoil in all my vehicles. Keep in mind 90K miles isn't "high" for a Toyota...
  12. Sep 15, 2013 at 12:51 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Cool Post Bro, Tell TJ Hunt To Update The Vlog!
  13. Sep 15, 2013 at 12:57 PM
    geodude
    Very cool.
    Thank You
    Also, do all the drains have crush washers? I'd figured it would be wise to replace those where needed, possibly even replace some of the bolts themselves as they're pretty rusty on the heads.
  14. Sep 16, 2013 at 5:17 PM
    Norton
    Monument, CO
    There are crush washers on all the drains and fills. Replacing the bolts is also a good idea if they're in bad shape.
  15. Sep 17, 2013 at 9:51 AM
    geodude
    Thank you, got a quote from local Toyota dealer; roughly $16 for all fill and drain crush washers (they say gaskets).
    After looking through the FSM it's looking like the approximate 3.7 Qt's of 75w90 GL-4(Transmission + Transfer Case) and 3.8 Qt's of 75w90 GL-5 (differentials) is going to cost me about $120 @ about $15 a quart. That's the price for Redline.
    Seems like a lot for just the fluid. Anyone know what it would cost me at a shop to change out all these fluids? They're oil cost would be a fraction of mine I'm sure since they have it by the 55 Gal drum.
