Changing distributor on 4cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Jan 8, 2021.
  1. Jan 8, 2021 at 11:48 AM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Hello so I’ve been working on changing the distributor on my 4 cyl and now it starts and then stalls after 4-5 secs. It pulled a po336 not sure what’s happening
  2. Jan 8, 2021 at 1:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    FSM says in this order
    Check valve timing
    Check distributor instllation
    You can also check the camshaft sensor itself.
  3. Jan 8, 2021 at 1:24 PM
    gearcruncher
    Canadain bumper technician
    Did you have the battery disconnected ?
    Without cleaning the throttle body , it will take a bit for the computer in your truck to relearn the idle position
    Kwikvette likes this.
  4. Jan 8, 2021 at 1:52 PM
    Allex95
    allex
    No
  5. Jan 8, 2021 at 2:00 PM
    Allex95
    allex
    How exactly do I check valve timing? It shouldn’t of changed.
  6. Jan 8, 2021 at 2:17 PM
    Allex95
    allex
  7. Jan 8, 2021 at 2:19 PM
    Allex95
    allex
    Where’s the circuit
  8. Jan 8, 2021 at 2:20 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Does it start easily/normally and does it sound normal when it runs for those 5 seconds?
  9. Jan 8, 2021 at 2:21 PM
    Allex95
    allex
    No I do not. To be exact I installed a distributor and then it pulled a po336
    gearcruncher[QUOTED] likes this.
  10. Jan 8, 2021 at 2:50 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    FSM says distributor installed incorrectly
  11. Jan 8, 2021 at 3:38 PM
    Allex95
    allex
    I had someone doing it for me and how they did it was getting cylinder 1 top center and lining the timing at 0 then putting it on?
  12. Jan 8, 2021 at 3:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And OP wonders why I mentioned checking timing.
    Black DOG Lila likes this.
  13. Jan 8, 2021 at 3:51 PM
    Allex95
    allex
    Well when you mean timing as in it was set at 0 and cylinder one at top center
  14. Jan 8, 2021 at 4:13 PM
    Black DOG Lila
    Virginia
    4 stroke engines have TDC twice per cycle.
    #1 Intake
    #2 Exhaust
  15. Jan 8, 2021 at 4:15 PM
    Allex95
    allex
    Well I’m not sure what happened. I had the guy install it and as soon as it started with the new one it ran for 6 seconds then died and a code po336.
  16. Jan 8, 2021 at 5:26 PM
    tirediron
    Code P0336 Definition
    The engine control module, ECM, has detected an improper/irregular voltage coming from the crankshaft position sensor.
    So, start by verifying that the sensor and/or any upstream wiring/connectors weren't damaged or disconnected in the process of installing the new distributor. Assuming that's all good, get your DVOM/Scope out and find out of if the sensor is good or bad. Hopefully it's just a bad sensor, throw a new one in, and done. If not, things could get spendy.
  17. Jan 8, 2021 at 8:07 PM
    Allex95
    allex
    I’m being told by the shop that when they installed the distributor it fried or messed up the ecm and now I have to get another one.
  18. Jan 8, 2021 at 8:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wait what?
    You said you were changing it out, now a shop is involved?
    Why are you diagnosing work you paid to get done? o_O
  19. Jan 8, 2021 at 8:12 PM
    Allex95
    allex
    I came over to this shop which I’ve been to quite a bit over the while. I watched him replace it and then a po336 code came up. This shop believes it’s the ecm that went out but i need to make sure.
  20. Jan 8, 2021 at 9:01 PM
    tirediron
    If they killed the ECM when they installed the distributor, that's their error and their cost to correct. That said, I find it very difficult to imagine HOW you could damage an ECM installing a distributor, it's a pretty s***t-simple job. And, if the ECM had been "fried", I'd expect a bunch of codes, and not one which points to a specific sensor. Not to say that it can't happen, but I'm suspicious. Check out the sensor, and if it's within spec, and the wiring from the ECM to the sensor is good, it could indeed be a damaged ECM, but I would either check it myself or have another shop diagnose the problem if you have the capability to do it.
    JudoJohn likes this.
