Changing distributor on 4cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Jan 8, 2021.
  1. Jan 10, 2021 at 7:36 PM
    #61
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    I tested the wires on the clip to see for continuity and all good so.
  2. Jan 11, 2021 at 1:34 PM
    #62
    Allex95
    allex
    So while I wait for the ecm I took the valve cover off for the timing and the crank to 0
  3. Jan 12, 2021 at 1:07 PM
    #63
    Allex95
    allex
    Another update: so i was able to find a ecm from out in kanas city gonna ship it over and I’m also getting my original one fixed so I have two in case. In the mean time I was installing the distributor took off the valve cover timing was good everything lined up. I heard 1st gen Tacoma ecms don’t need to be flashed?
  4. Aug 22, 2025 at 7:13 AM
    #64
    Tacoma1997$
    Tacoma1997$ Member
    Stephen
    97 tacoma 355,000 miles
    oil catch can-mini header-painted it last year
    Just start over - top dead center compression stroke #1 cylinder - the distributor is installed pointing at 12 o'clock and naturally turns to the right about an inch and points at #1 spark plug!! After replacing distributor cap during tune up cut the top off the old one so u can actually see if rotor is pointing at #1 spark plug - exactly pointing at it!!
  5. Aug 22, 2025 at 7:18 AM
    #65
    Tacoma1997$
    Tacoma1997$ Member
    Stephen
    97 tacoma 2.4 MT - has 3 connectors at ECU automatic trans has 4 connectors -take cover off and check out the big capacitors - make sure they aren't bulged or leaking - its a common problem with older toyota ECUs !!
