Changing engine coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IslandBoy71, Sep 20, 2010.
  1. Sep 20, 2010 at 12:08 AM
    IslandBoy71
    IslandBoy71 [OP] Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    My 06 has around 126k miles and I know the coolant is due at 100k miles. Is this something that I can do myself with basic tools or do I need to bring my truck in for service? How many gal. coolant will I need?
  2. Sep 20, 2010 at 4:29 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You can do it yourself......
    Search www.google.com for some writeups and information.
    This is how my husband and I did it on our 96.
    Cold Engine
    Open radiator cap
    Drain old fluid (open drain cock at bottom of radiator)
    After draining, close drain cock & fill radiator & overflow with water (from hose)
    Run engine and allow the system to cycle the water through to flush out the engine block. Open drain cock to let if flow out. Keep the hose ON and continue to pour water into the radiator while the engine runs. At the drain cock, when the water is clear...shut off engine. Let water drain out.
    Close drain cock.
    Fill radiator & overflow tank with 50/50 premixed radiator fluid & distilled water. You can buy the stuff premixed or mix it yourself. You may neeed to use a 'tester' to test the level of protection you have with the mixture depending on your climate.
    Keep the radiator cap off and run the engine to allow the system to cycle and 'burp' out the air bubbles. You'll have to add more fluid as necessary as the system 'burps' out the air bubbles. Keep your eye on the temp gauge also. This will let you know if you still have air pockets in system. You want to make sure all the air is OUT. Continue to keep the radiator & overflow filled during the burp process.
  3. Sep 20, 2010 at 4:56 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Keep in mind that when you flush with water, some stays in the block, lines and heater core. Make your mix heavier on coolant. 60/40, coolant/water.
  4. Sep 20, 2010 at 5:18 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    No you don't want to do it that way you want to find the thread here. It's a process. Doing it that way will not chances are drain the block. Filling it back up is a process too. I've posted the PDF or picture twice here already. If I find it I'll post the link.
    http://www2.toyota.bruceusa.com:8083/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/01600210.pdf
    I think the engine drain is very hard to find. The other one is you have to be super careful not to strip it. It does not go very tight.
  5. Sep 20, 2010 at 8:57 AM
    reg boulette
    reg boulette Well-Known Member
    Only thing I'd add is to turn your heater temp up full blast when you drain and refill so that the heater core is evacuated and then replenished. I usually drive it highway speed with the heater on before draining the system to get all the sludge out that builts up between spring and fall.
    Scrat likes this.
  6. Sep 20, 2010 at 10:45 AM
    IslandBoy71
    Reggie
    Lakewood, CA
    thanks for all the info guys! I will flush out my coolant this weekend.:)
  7. Sep 20, 2010 at 6:54 PM
    snowmansgarage
    snowmansgarage Well-Known Member
    Portland, OR
    '06 TRD Offroad AC Tacoma
    I just did mine last week and it's quite simple. The dealer sells pre-mixed coolant and you'll need two gallons. There are two drains, one on the driver's side of the radiator and the other is on the passenger side of the block. The block drain can be seen between the strut tower and the rubber splash shield to the left of it. It's as simple as drain the radiator and the block, close them back up, fill it up and bleed it out.
  8. Sep 20, 2010 at 9:39 PM
    Trap
    Indego Ink TRD OR
    You have to watch though. the 4 banger block drains are on the other side of the block from the 6 cylinder.
  9. Jun 14, 2012 at 5:16 PM
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Maybe a dumb question but how do you bleed out the air??
  10. Jun 14, 2012 at 5:19 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Dude use the Toyota coolant (RED) and don't mix! yours should use the long life. make sure you burp the system when filing.
  11. Jun 14, 2012 at 7:03 PM
    eyball
    Dudley, MA
    I only drained out of the passenger side & radiator, I noticed there really is a third drain after I already refilled. I did manage to get 2 gallons out & back in though. I ran the heat, massaged the hoses & revved it a bit then went for a ride. Seams ok. I did use the Toyota long life pink shit. Amazingly my dealer had it for $20.99 & they had a 20% off coupon on their website.
