changing fluids and filters
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Jun 13, 2010.
  1. Jun 13, 2010 at 9:04 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    Gave the truck a much needed and somewhat late oil change yesterday.
    While waiting for the oil to settle to check level I took a look at some other fluids. All were at level( transmission, brake, and coolant) but, what is the recommended time interval for a transmission fluid change? What about a coolant flush? Could I do this at home or is it necessary to take it somewhere? How about the brake fluid?
    The drivetrain on the truck runs fine, and I ma experiencing no problems from anything under the hood. I was just wondering for future reference. I am around 110K miles on it and would like to get another 100k more, if I possible.
    thanx
  2. Jun 13, 2010 at 11:10 AM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    The manual tranny is really easy to change. Every 50K or so
    The AUTO transmission is a pain to change unless you have a lift. You still want the fluid to look pink when you change it.
    The Tranny costs just as much as a motor so take care of it!!!
    I would pay someone to flush and change the filter if it is an AUTO. Much better than draining it and changing the filter. Draining it only changes approx 50% of the fluid. Cost is usually about $250.00 but worth it.
    Read this http://www.tacomaworld.com/forum/1st-gen-tacomas/97562-fun-transmission-fluid-filter-change.html
  3. Jun 13, 2010 at 11:27 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    id rather drain and refill, with 110k miles flushing could damage seals and flush metal particals where you dont want them. take off pan, you have a 2 peice dipstick you have to disconnect, take off the magnetic filer and clean it good, clean off all magnets, and scrape off all toyota gunk on both sides of pan and replace with either rtv silicone gasket or a synthetic gasket, i dont reccomend cork or rubber. be sure to fill the trans to the proper level and not any large metal chunks or excessive metal shavings on magnets (there will be some from clutch pack wear)
    however if your taco is an 05-10 you can change it on your own but its much less of a pain if you take it to the dealer
  4. Jun 13, 2010 at 12:02 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I called my dealer and they said $150 to flush and re-fill.
  5. Jun 13, 2010 at 12:08 PM
    4421.frank
    Southside chicago
    so just have it drained and refilled rather than flushed ? then it's just a matter of getting the tranny pan off and getting a new filter and some new tranny fluid? Should I go with synthetic fluid?
  6. Jun 13, 2010 at 12:16 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    Check this link out
    http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep4.htm
    I would go with conventional since this is your first time changing it. Sometimes synthetics in auto trannys that have not been changed can cause seals to leak or the tranny to slip. I have seen that happen on American cars more than foreign but it is possible on a Toyota. The synthetic is much thinner
  7. Jun 13, 2010 at 12:26 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    I respectfully disagree. If there are fine metal particles they should be stuck to the magnet in the bottom of the pan. For larger particles the transmission filter should trap them. It is unlikely there are chunks of metal in the tranny fluid floating around.
    I have changed a bunch of Trannys with the cork and rubber gaskets and haven't seen them leak especially if you are changing when recommended at 50K miles.
    Flushing will remove all of the old fluid that needs to be replaced. The dirtier the fluid the more important it is to flush. If it is not bad then fluid and filter change should be fine.
    If you are not comfortable with the flush - do the filter and fluid change. Then change the fluid again in another 10K or so miles to get all of the older stuff out. Then you can keep on the 50K schedule.
    ALSO make sure you lube all the grease zerks on your driveshafts while under there.
  8. Jun 13, 2010 at 12:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its not that bad doing it without a lift.......as far as im concerned. i've done mine a few times.
    i'd drop the pan....clean the filter screen....put pan back on and refill. then....wait a couple thousand miles.....just do a drain and refill. do the drain and refill several times.......you wont have to worry about a flush.........you'll have all new/relatively new fluid in the tranny then. thats how i do it anyway.
  9. Jun 13, 2010 at 12:42 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    I have done them with and without lifts.
    Doing it without a lift compared to with a lift is bad. It just takes a lot longer and is much messier.
    Just depends on your experience.
    Yes it can be easily done crawling underneath but not cake like with a lift.
  10. Jun 13, 2010 at 12:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....lift is alot better.....but not all of us have one. wish i did tho.:D
