Changing fluids in truck need opinions
Discussion in 'Performance and Tuning' started by Masada, Nov 30, 2009.
  1. Nov 30, 2009 at 11:47 AM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I'm going to be changing my fluids (everything but the engine I use mobile 1 for that) in my truck and would like some opinions on Royal Purple synthetic.
    I saw on trucks and other shows that they are a good brand and help eliminate drag on the moving parts.
    Anyone have onions or stories otherwise?
  2. Nov 30, 2009 at 11:49 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I prefer mobil 1 as my synthetic engine oil. I have not heard anything bad about any RP products.
  3. Nov 30, 2009 at 11:52 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Are you just talking about the engine oil, or other fluids too?
  4. Nov 30, 2009 at 12:01 PM
    Masada
    Taylor
    Laveen, AZ
    Diff, trans, transfer case and all others...
  5. Nov 30, 2009 at 12:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I prefer Mobil 1 as its more readilly availible.
  6. Nov 30, 2009 at 1:16 PM
    Masada
    Taylor
    Laveen, AZ
    Ya that's what I was thinking, I don't even know where I could get RP.
    There sight says Autozone, but I've never looked and I have never scene it there.
  7. Nov 30, 2009 at 1:27 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i saw the show and royal purple says that you must also use filters made for synthetic oil,they say synthetic oil breaks the media or filter down in a conventional filter,i dont know thats just what they said.:rolleyes:
  8. Nov 30, 2009 at 1:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think that was proven to be a myth.....I cant find the site right now, but as soon as I do I will post it up....
  9. Nov 30, 2009 at 1:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Here:
    http://www.ehow.com/about_5510369_synthetic-oil-myths.html
    Special Filter Required for Synthetic Motor Oil
    Any oil filter can be used with synthetic oil. An oil filter is designed to catch solid particles, and the filter element acts just as well with synthetic oil running through its fibers, as it does with conventional oil. It is always recommended that a high performance oil filter is used, regardless of what type of oil is going to be running through it.
  10. Nov 30, 2009 at 1:35 PM
    Masada
    Taylor
    Laveen, AZ
    part in bold:
    Would you consider the Toyota filter a high performance filter? If not, who makes one?
    I still plan on running Mobile1 Synthetic in the motor and I was thinking RP for everything else...but if I can't find it to buy then something else. I just want to make sure no one else has tried it and said it killed their truck or something crazy like that :)
  11. Nov 30, 2009 at 1:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used to doubt the Filter from the dealership, but after doing some testing, the particulates in the oil are no more when useing it, as opposed to useing a Mobil 1, K&N, or other filter.
  12. Nov 30, 2009 at 1:46 PM
    dually
    dually Low and slow
    I like the OEM filters!
  13. Nov 30, 2009 at 1:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  14. Nov 30, 2009 at 1:53 PM
    Masada
    Taylor
    Laveen, AZ
    My dad has always told me to get the OEM filter, they are usually cheaper and better quality.
  15. Nov 30, 2009 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, I noticed the Mobil 1 filters cause the oil pressure to build more slowly in the winter months.....
  16. Nov 30, 2009 at 2:27 PM
    Masada
    Taylor
    Laveen, AZ
    Wow that just sound kind of scary...I think I'm going to stick with the OEM filter.
    So no one has any horror stories or anything about RP huh...
  17. Nov 30, 2009 at 3:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not really scary. I noticed this in my Dodge (as the Tacoma doesnt have a oil psi gauge), that it took about 4 to 5 times longer for the psi to build up to operating pressure. I tested 3 different Mobil 1 filters, and had the same results, so Im pretty sure its a design thing....Not sure what kinda damage/wear can result from this, but I know start up is where the most wear can happen, so I wont use them.
  18. Jan 3, 2010 at 9:24 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    i know this is an old thread but seriously check into rp b4 u buy it! it's one of the worst performing motor oils on the market. they just market the crap outta it! i use amsoil in my taco and mobil 1 in my corolla both of these oils are excellent! mobil one is just slightly cheaper and easier to get. since i tow things with my truck and it also cost alot more than my car i feel comfortable paying the extra $ on the amsoil for it. its suppose to give better heat and wear protection?
