Changing fluids
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chrism0923, Jul 24, 2020.
  1. Jul 24, 2020 at 2:58 PM
    Chrism0923
    Chrism0923 [OP] Well-Known Member
    2012 silver tacoma
    Hey guys. Is it safe to drain your tranny fluid and rear diff fluid to put in new fluid? I know this may sound like a dumb question but I’ve had people tell me to not do it all at one time because of there is trash in it it could cause problems. Any advice?
  2. Jul 24, 2020 at 4:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you have an Automatic, you’re not going to get all the fluid out at once by just draining the pan.
    You’ll get less than half doing just a pan drain.
    If you have a manual transmission, drain it all at once.
    Nothing to worry about.
    As for the differential, drain it all at once.
    Nothing to hurt, just clean the magnet on the drain plug before you reinstall it.
    EdgemanVA and RoughRder like this.
  3. Jul 24, 2020 at 5:15 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    The tranny debate is an ongoing thing on here. Never heard not to change the diff fluids.
    I've changed both more than once and haven't had any problems. It's kind of a silly argument to say DON'T change fluid because it might have trash in it....why would you want to leave the trash IN the diff/tranny?
    Don't buy into the "never follow the manufacturers maint schedule...they want to sell cars" idea. Yes, they do, but they won't intentionally cause harm to a vehicle...especially with regular maintenance. The general rules of that are pretty well known across the board of manufacturers and indy mechanics alike...
    TL;DR
    Change em, feel good that you did it...it's fine.
    RoughRder likes this.
  4. Jul 24, 2020 at 5:40 PM
    RoughRder
    RoughRder What fresh hell is this?
    Garrett
    Hampton Roads, VA
    2011 DCSB TX TRD
    5100s and OME 885 coils front, 5100s and AAL for the TSB leaf pack (overload left in) rear. Jeraco camper shell.
    Well put. Do you have a 2WD model? If not, don’t forget your T Case and Front Diff. Plenty of how-tos around here.
  5. Jul 24, 2020 at 7:15 PM
    jproffer
    Jim
    Perryville, MO
    Not sure about OP. I have a 4WD and I've done them all, so we're all good here. Thanks though :thumbsup:
    None of them are difficult. Worst problem I had was getting the front diff plug out with that female hex. Next time, that problem is solved...got the new lexus plug with the regular male hex (regular wrench) ready to go in.
  6. Jul 24, 2020 at 9:29 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    You can't beat clean fluids in your vehicle!:thumbsup:
    EdgemanVA likes this.
  7. Jul 25, 2020 at 8:24 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    My simple recommendation: always remove the fill plug before draining any gearbox.
    You don't want to be stuck somewhere with no fluid in your gear boxes, nor any way to add fluid to your gearboxes. It's far better to have "old oil" than no oil.
    Also recommend NOT having the dealer change the fluids. They seem to think that using a impact gun is required to prevent leaks (or to ensure you have to come back to them for your next fluid change because you can't break those plugs loose with a breaker bar).
    jproffer and topoutman like this.
  8. Jul 25, 2020 at 9:20 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Ignore the people who told you this.
    EdgemanVA and jproffer like this.
  9. Jul 25, 2020 at 10:49 AM
    jproffer
    Jim
    Perryville, MO
    ....About EVERYTHING related to your vehicle.
