changing from 3.727 gear ratio to 4.56
Discussion in 'Technical Chat' started by tacowithbeans, Apr 17, 2012.
  1. Apr 23, 2012 at 10:02 AM
    jwmaynard
    jwmaynard Member
    Virginia
    2012 TDR Sport 4x4
    Exactly!
  2. Apr 23, 2012 at 10:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I believe you are confusing down shifting with "Over drive". "Over Drive" is usually the top gear (or top 2, depending on tranny), that have a ratio of less than 1 to 1, I.e. .75, .83, etc.
  3. Apr 23, 2012 at 6:03 PM
    tacowithbeans
    tacowithbeans [OP] Member
    michael
    troup, tx
    o7 prerunner lifted 6" by fabtech
    6" suspension lift, custom drive shaft, lime green underbody and airbrushed dash piece
    mine is an automatic i rarely ever use the shifter deal unless im pulling something extremely heavy like my horse trailer
  4. Apr 26, 2012 at 10:06 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    i use mine like its a standard :burnrubber:
    RicosTaco likes this.
  5. Jun 15, 2012 at 4:05 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You already have 4.10 with the I4 4X4 Stick.
  6. Jun 15, 2012 at 5:18 PM
    worthywads
    Or you could swap to 4.56.
  7. Jun 15, 2012 at 6:04 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  8. Jun 15, 2012 at 6:20 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    No losing torque, just gaining.
    With the 5spd and .81 OD and 33s at 75mph and 4.56 your RPMs might be ~2840 or with stock maybe ~2550. To visualize what kind of jump you might see at highway speeds. I think about an 11% increase.
    As you change the gearing lower, or numerically higher, you essentially decrease speed and gain torque.
    For every 4.56 revolutions of the input you'll see 1 revolution output, so basically think driveshaft and then wheels. With stock 4.10s your driveline is spinning 4.10 times for every one revolution of the axle shaft. So you lose speed essentially, so you'll have to have more engine RPMs to go the same speed, but you gain torque.
  9. Jun 15, 2012 at 6:25 PM
    worthywads
    The bigger tires reduced your rpm by 7%.
    Going from 4.1 to 4.56 increases your rpm by 11%.
  10. Jun 15, 2012 at 6:28 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You'll gain torque but you're going to increase RPMs to go the same speed. It's a fair chunk of change. Cheapest is to have ECGS do it IMO, then they send you new 3rds and you swap them in yourself.
  11. Jun 15, 2012 at 6:31 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  12. Jun 15, 2012 at 6:35 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Lots of guys here want 4.10s though so see if it'd be worth it to pay the core charges and then sell your 3rds on here.
