Changing front/rear Diff, Transfer Case and Manual Trans Gear Oil. How many Quarts do I need?
Discussion in '1st Gen. Tacomas (1995-2004)' started by indetrucks, Oct 26, 2017.
  1. Oct 26, 2017 at 9:03 AM
    indetrucks
    indetrucks [OP] Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    Ensemble88 and MagicMexican like this.
  2. Oct 26, 2017 at 1:06 PM
    indetrucks
    Christian
    Southern CA
    Found this out for anyone who comes across this thread in the future.
    Engine Oil: 4wd With filter 5.5 qts Without filter 5.2 qts Dry Fill 6.2 qts
    Transmission: 5VZ-FE w/ 5 speed = 2.3 qts (but just fill until it comes out of the fill hole).
    Diffs:
    Front: 1.22 qts
    Rear w/o Diff Lock: 2.69 qts
    Rear w/Diff Lock: 3.18 qts
    For the transfer case, just fill until it starts spilling out. I'm guessing around 1.5 qts?
    xcmtb83, Thorian, Ensemble88 and 3 others like this.
  3. Oct 27, 2017 at 7:44 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    opps..i have a 2nd gen.
  4. Oct 27, 2017 at 8:19 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Phew, that's 8.3 qts.
    I've heard really good things about Amsoil full synthetic and severe gear... it's kinda $$ but that's my plan when I get around to it.
    QMEDJoe likes this.
  5. Oct 27, 2017 at 1:06 PM
    Glamisman
    Glamisman Well-Known Member
    take the fill plugs out first... if you dump it and cant get the fill plugs out... On the aluminum cases dont over tighten the fill plug, it is tapered and there is the possibility of spliting the case, stripping the head or ...
  6. Oct 27, 2017 at 1:45 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    For the love of god do not reference the manual for gear oil quantities. There is a major typo for the 5 speed tranny... it says something absurd like 2.something quarts. It easily takes double that after draining. Sure, follow the manual for other stuff but I would buy 1 or two more quarts just in case.
  7. Oct 27, 2017 at 1:50 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    From the manual
    MANUAL TRANSMISSION Oil capacity,
    L (qt., Imp. qt.):
    2RZ−FE engine 2.6 (2.7, 2.3)
    3RZ−FE engine 2.5 (2.6, 2.2)
    5VZ−FE engine Two−wheel drive models 2.6 (2.7, 2.3)
    Four−wheel drive models 2.2 (2.3, 1.9)
    Oil type: Gear Oil API GL−4 or GL−5
    Recommended oil viscosity: SAE 75W−90
    TRANSFER Oil capacity,
    L (qt., Imp. qt.): 1.0 (1.1, 0.9)
    DIFFERENTIAL Oil capacity,
    L (qt., Imp. qt.):
    Two−wheel drive models except Pre Runner
    2RZ−FE engine 1.35 (1.4, 1.2)
    5VZ−FE engine 2.55 (2.7, 2.2)
    Four−wheel drive models and Pre Runner
    Front (except Pre Runner... duhhhhh) 1.15 (1.2, 1.0)
    Rear
    Short wheel base With rear differential lock system 2.65 (2.8, 2.3)
    Without rear differential lock system 2.55 (2.7, 2.2)
    Extra long wheel base With rear differential lock system 2.95 (3.1, 2.6)
    Without rear differential lock system 2.45 (2.6, 2.2)
    Oil type: Hypoid Gear Oil API GL−5
    Front
    SAE 75W−90
    Rear
    Above −18C (0F) SAE 90
    Below −18C (0F) SAE 80W or 80W−90
  8. Oct 27, 2017 at 11:19 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I always filled the diffs and t-case until oil came out. Don't use Delvac 1 in them, that's engine oil. Diesel engine oil to be specific.
