Changing Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmata, Aug 18, 2013.
  1. Aug 18, 2013 at 8:29 PM
    gmata
    gmata [OP] Well-Known Member
    Gonzalo
    Delaware
    2007 DCB 4x4 TRD sport
    Hello guys,
    I have a 2007 4x 4 tacoma Sport and I want to change the differentials and transfer case oil.
    I understand I need 3 for the front and transfer and 3 for the rear.
    My questions is, since I have LSD differential, what kind of additive do I need to add?
    Can I just use Red Line 75W90 Syntethic for everything? If so do I still need to add an additive?
    How often do I need to change it if I use Syntethic oil?
    Thanks!
  2. Aug 19, 2013 at 5:36 AM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    there is a pretty good sticky on here. saw it the other day.
  3. Aug 19, 2013 at 11:15 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  4. Aug 19, 2013 at 12:24 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i use redline.
    there are two types. one for LS, and one for cars without LS. you have to be perfectly sober to interpret the bottle labels. they are fun to read and decipher..if i remember correctly. edit: just looked that the website..not so sure i am correct. hmmm
    just get a gallon, and one extra qt. that was enough, IIRC. <-----this is all i did. twice. no issues.
  5. Aug 19, 2013 at 3:20 PM
    Maticuno
    2011 Suburban 2500
    However, with your TRD OR, you don't have the mechanical limited slip differential. Running LSD additive oil in a non-LSD will not cause any issues. Most synthetic oils, however (with some individual exceptions), even with limited slip additives, cause chatter in mechanical LSDs.
  6. Jun 3, 2014 at 4:49 PM
    chowderhouse
    chowderhouse New Member
    Washington
    07 Tacoma V6 4x4
    I took mine to the dealer and after approx 1000 miles it started making rubbing noises while turning. I changed mine out with Valvoline dura blend 80w-90w(synthetic blend) plus 4ozs of Sta lube Equa torque fric mod. 200 miles so far so good.
  7. Jul 10, 2014 at 5:27 PM
    jackbower6864
    jackbower6864 Member
    So how often should I change my differential oil?
  8. Jul 10, 2014 at 5:36 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    When i used to change the diff oils in my old 2005 TRD Sport, i used Mobil 1 synthetic LS in 75 or 80-90. Never added any additive in any LSD i've owned unless i've used plain ole gear oil, then i'd add the small tube of additive. I use the same stuff in my transfercase too. Never any problems. Had 130k on that Taco Sport when i sold it. I changed my diff oils about every 35-40k.
  9. Jul 10, 2014 at 6:17 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Do it every 35,000 miles
    Use motorcraft 80w-90 gear oil and also one small bottle of motorcraft friction modifier
    Any ford dealer stocks it
    Thats all ive ever used in my 05 tacoma trd sport with lsd rear
    Also buy 2 new crush washers from toyota for the fill and drain plugs
