Changing gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdmorehead93, Nov 24, 2016.
  1. Nov 24, 2016 at 12:48 PM
    jdmorehead93
    jdmorehead93 [OP] Member
    I have upgraded to 285/75/15 and I was curious as to which gears I should put in it.
    Thanks in advanced.
  2. Nov 24, 2016 at 12:54 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Nov 24, 2016 at 1:01 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    What gears are in it now and what size came off? Probably not worth changing anything.
  4. Nov 24, 2016 at 4:07 PM
    Pigpen
    Dan
    Northwest Montana
  5. Nov 24, 2016 at 4:19 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
  6. Nov 24, 2016 at 4:21 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Stock gearing is 3.73
  7. Nov 24, 2016 at 4:22 PM
    Pigpen
    Dan
    Northwest Montana
  8. Nov 24, 2016 at 5:19 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Shot missed that. Not sure how a 15 cleared it
  9. Nov 25, 2016 at 12:41 PM
    jdmorehead93
    What would the RPM and mpg be like on a cruising note? If you happen to know this also.
