Changing Headlight Bulbs- How dumb can I be?
Discussion in 'Lighting' started by headhunter247, May 13, 2009.
  1. May 13, 2009 at 5:35 AM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Ok, so I realized last night after I stopped at happy hour after work (3 beers, thats it!!) , that one of my headlights were out. SUCK. I stopped at Autozone and bought a set of the silverstars, and ATTEMPTED to put them in.
    I saw where people have said for a second gen to take the whole headlight out, but I didnt, and was able to get the bulbs in to the slot at least. Now, Im not stupid, but I cant seem to get them to line up correctly in the little tabs. The metal brackets that hold them on are locked in, but I can tell from the beam that they just arent right. There are half moon indentions in the bulb surround that you can see from the front of the headlight housing, and neither side is the same. Right now, ones sitting at like 11 o clock and the other about 9 oclock angles.
    Can someone shed some light:D:D about where these should sit? A picture from the front would be awesome. Do I really need to take the whole headlight out to do this? Thats plain silly if so.
  2. May 13, 2009 at 6:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just don't ask this guy for halp!
  3. May 13, 2009 at 6:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I didnt have to remove the headlights.....The bulbs should go right in, like they came out...
  4. May 13, 2009 at 6:30 AM
    headhunter247
    St. Louis, MO area
    Yea, well they did, but I cant seem to get them to sit right.
  5. May 13, 2009 at 6:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take them out, and try again....Also, be sure not to touch the glass, or the bulbs will burn out quickly.
  6. Aug 9, 2009 at 3:02 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Do you have to put grease on the bulbs? They sell something next to the bulbs in a little packet. DO you need to use that?
  7. Aug 9, 2009 at 3:29 PM
    98tacoma27
    Ben
    Not Beech Creek
    For headlights, no. It's a grease that keeps them from corroding.
  8. Aug 11, 2009 at 11:19 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I just swapped my headlight and foglight bulbs out last night for some Silverstar Ultras. Naturally nothing like the HID's I had in my previous vehicle, but still a nice improvement. I didn't pull my headlights out. A little tight working to get the bulb in but it went smoothly for me. Like the others said, I'd just try taking them out and putting them back in.
  9. Feb 27, 2016 at 12:19 PM
    Mgrant8163
    Mgrant8163 Super-commuter
    Sacramento, CA
    MGM Double Cab Pre-runner 4x4
    Did you say Horse power?
    I was able to get them in and lined up without taking out the entire light but on the first one (passenger side) I managed to break the plastic tab that holds the wire spring. Am I hosed?
  10. Feb 27, 2016 at 12:20 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  11. Feb 27, 2016 at 12:22 PM
    Mgrant8163
    Sacramento, CA
    crap. i used silicon to glue it in but now that same side bulb went out again. Was hoping one of you guys had a better idea.
