Changing height of Bilstein 5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MadeInMaine, Jul 5, 2010.
  1. Jul 5, 2010 at 1:56 PM
    MadeInMaine
    MadeInMaine [OP] MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Hey Guys,
    Forgive me if there is already a thread made for this, I didn't see anything...
    I just got my hands on some 5100s, and want to set them at the highest setting... but I don't know how to change the height setting.
    Could you give me a quick walk through, or throw some pictures up, or send a link my way?
    Thanks
    Cheers
  2. Jul 5, 2010 at 2:00 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    put the C-clip in the top notch, then put the bottom coil bucket on to where it hangs around the C-clip, then reassemble as normal
  3. Jul 5, 2010 at 2:02 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Just an FYI, if you bought them pre-assembled with coils, you'll need to disassemble, change the spring seat setting, and reassemble.
  4. Jul 5, 2010 at 2:02 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    thats what I figured... but that c-clip is the only thing that holds up the coils?
    Do I need a special tool to move the c clip?
  5. Jul 5, 2010 at 2:02 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Cheers, thanks for the tip
    Although I did just buy the shocks alone, but thanks
  6. Jul 5, 2010 at 2:04 PM
    The_Hodge
    SC
    nothing special...just easily pop it out and reseat it in the top notch
  7. Jul 5, 2010 at 2:08 PM
    TexasTacoma37
    Correct, but the spring perch envelopes around the c-clip, holding it in place. So although its easy to take the c-clip out by hand, it's very sturdy once the spring perch is around it. You'll see when you get them set up.
  8. Jul 5, 2010 at 2:11 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 285 x 70 x 17 Toyo Tires on 17" x 8" ICON Wheels
    As previous members have posted, no special tools needed to move the clip.
    Good luck!
  9. Jul 5, 2010 at 2:47 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    My special tools for moving them was two fingers and a thumb... although I did split my thumbnail far enough to draw blood doing the second one. Might want to try some pliers? :eek:
  10. Jul 5, 2010 at 5:02 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Cheers fellas,
    thanks a lot for all the info.
