changing lower fog lights...
Discussion in 'Lighting' started by doons, Aug 14, 2011.
  1. Aug 14, 2011 at 12:59 PM
    doons
    doons [OP] Active Member
    KANADIA
    2011 V6 4X4
    how do i change my lower fogs in my 2011 tacoma i know it looks easy but what do i order...thanks!
  2. Aug 21, 2011 at 12:16 PM
    morphius
    morphius Well-Known Member
    Santa Clara, CA
    2010 4x4 Access Cab TRD Sport
    You mean just changing the bulbs?
    It is easy.
    Just hold the plug with your thumb and middle finger and with your index finger lift the center brown clip about 1/8 inch before pulling the plug off the lamp housing.
    The rotate the lamp 1/4 turn counterclockwise to release and pull out the bulb.
    Notice the position of the bulb.
    To install the replacement bulb, insert the bulb in the same position and turn clockwise 1/4 turn to seat.
    Then slip the wiring plug back on until the center clip clicks into place.
  3. Aug 21, 2011 at 4:40 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    bulb is a 9145
