Changing Manual Transmission Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Geeper, Sep 16, 2011.
  1. Sep 16, 2011 at 2:15 PM
    Geeper
    Geeper [OP] Member
    San Diego
    05 2WD Regular Cab
    I've got an '05 Taco with a 5-speed, 4 cyl, 5-lugger, 2.7L, regular cab and I wanna change the tranny oil this weekend. It's got around 90K on it and I'm pretty sure it's never been changed (2nd owner). I'm looking for a good write-up on how to do this. I saw one on here a while back but I can't seem to find it now. Anybody got any good advice or write-ups? Thanks
  2. Sep 16, 2011 at 2:25 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    It's the same as the diffs. You just unbolt the fill (higher one) first, then the drain (lower one).
    Once you crack the drain, the oil will come out, so have a catch pan under it.
    Put drain plug back in and retorque.
    Use a little cheapo hand pump for the oil (75W90) and pump it back in through the fill.
    Put the fill plug back and retorque.
    Done!
  3. Sep 16, 2011 at 2:30 PM
    Geeper
    Geeper [OP] Member
    San Diego
    05 2WD Regular Cab
    Thanks. Sounds pretty simple. Any idea what the torque value is? And what the best oil would be? I live in a very mild climate.
  4. Sep 16, 2011 at 2:31 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I put in mobil-1 synthetic, because that was the only reasonably priced 75W90 synthetic near me. (The fact that it says "limited slip" on it is confirmed to not be a problem.)
    Haynes manual says 27 lb-ft for the plugs. Oh, and I think they're 24mm bolts, just like the rear diff, but I'm not 100% on that.
    And like the diffs, you refill til it is to the bottom of the fill hole or starts to come out. Should be 2.7 quarts for your 5-lugger.
    Last tip: Hit both bolts with PB Blaster and let it sit overnight (or for at least a couple hours) before trying to get them off. Mine were almost impossible at 30k, and you're at 90.
  5. Sep 16, 2011 at 3:28 PM
    Geeper
    Geeper [OP] Member
    San Diego
    05 2WD Regular Cab
    Okay, good idea.
    It looks like there are two fill holes, one on each side. The one on the passenger side looks lower than the other one. These are the fill and drain holes, correct?
  6. Sep 16, 2011 at 3:56 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    Make sure you're not looking at plugs for the transfer case (in that writeup, which also has the general procedure for doing this).
    But yes, should only be 1 drain and 1 fill plug, on alternate sides of the trans. They're the only 24mm bolts in that area IIRC besides the transfer case plugs.
    The lower one is the drain, the higher one is the fill. Make sure you can bust the fill loose before draining your fluid!
  7. Sep 16, 2011 at 4:07 PM
    saugus
    saugus Well-Known Member
    Nice timing for this. I just came from three stores looking for 75-90 synthetic in a gallon size to do both compartments. I believe it is like 6 quarts for the job. Nobody seems to sell gallon size. The mobil 1 was $10/ quart. Maybe autozone next.
  8. Sep 17, 2011 at 9:41 AM
    Geeper
    Geeper [OP] Member
    San Diego
    05 2WD Regular Cab
    Jeez! $10 per quart?
    Thanks for all the info.
  9. Sep 17, 2011 at 3:33 PM
    saugus
    I got 6 mobil1 for $8.99 at autozone.
  10. Sep 17, 2011 at 4:54 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Yeah autozone has mobil1 for 7.99 / qt here. Synthetic oil costs a bit more...
  11. Sep 18, 2011 at 2:46 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Lots of guys say the syn gl-5 is too slick and causes notchy shifting. I'm running it. I tend to wonder some times. I'm gonna switch to the redline mt-90 next go around.
  12. Sep 18, 2011 at 9:55 AM
    saugus
    Is it o.k. to replace the repair manual spec "APL GL-4 or APL GL-5 75w-90" with Redline MT-90 instead of Redline 75w-90? (so cal btw)
  13. Sep 18, 2011 at 11:57 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    MT-90 is a GL-4 so it's within spec.
  14. Sep 29, 2011 at 7:41 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I am about ready for tranny and diff oil changes with mine as well. I believe I did read some complaining about the GL-5 in the manual tranny. And the manual states GL-4 or GL-5 SAE 75W-90? Lets see if others give us feedback on this. I feel my tranny already shifts a little clunky or not very smooth at times and was hoping to get a better feel with the upgrade on the oil.
    I was planning on going GL-5 for both, but I may go GL-4 in the tranny and GL-5 in the diff. if the tranny likes GL-4 better?
  15. Sep 29, 2011 at 5:15 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    If you haven't done it yet. Use Amsoil severe gear 75w-90. I'm not an Amsoil dealer only a preferred customer. The manual trans in my '02 was very tight, not broken in. After changing the fluid the trans shifts way better. It's an easy job, just get a pump. It's a safe bet that the previous owner didn't change the oil. You should change all the fluids, clutch, brake, rad., trans., front/rear diff, engine, transfer case. DIY for about $200 or pay a shop $800.
  16. Nov 30, 2015 at 5:07 PM
    colton1808
    colton1808 Active Member
    I have a 5 speed manual 2.7 taco with 150000 miles on it 2nd owner, bought it when it had 130000. I don't know if it was ever changed by the first owner but I don't see anywhere in the manual saying I should change it............. Maybe i'm blind
  17. Nov 30, 2015 at 5:11 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    2017 MGM DCSB Off Road, 6 Speed MT
    Can't be repeated enough times, but Always make sure you loosen the Fill Plug before the Drain Plug.
    colton1808 likes this.
