Changing my differential fluid.
Discussion in '1st Gen. Tacomas (1995-2004)' started by xJRich5, Aug 1, 2011.
  1. Sep 20, 2011 at 2:08 PM
    #41
    window
    window Active Member
    NW Wisconsin
    07 Tacoma, 4Cyl,4WD
    That may be it; I really don't remember. Sometimes I use it; sometimes not. But that makes more sense. How do I check/fix that?
  2. Oct 15, 2011 at 8:41 PM
    #42
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Forget about Mobile 1, use ONLY Royal Purple or AMSOIL. I treated the entire drive-train including zerks, brake and clutch, power-steering and fuel system (Amsoil PI) with the top of the line Amsoil. I can not be happier the truck runs better than new.
  3. Oct 16, 2011 at 11:36 AM
    #43
    xJRich5
    xJRich5 [OP] Well-Known Member
    Josh
    OR
    I ended up using AMSOIL Severe Gear 75w90 in my T case and front and rear diffs. I have 3 quarts of Redline MT90 sitting in the shop for next weekend when I do my tranny.
    Thanks for everyone's input.
    Paulie- my driveshaft is next in line, what grease did you use? I hear some people say you have to follow the manual and go with NLGI 1 and NLGI 2, and others say it don't matter. What did you do?
    And does anyone else have any input on this?
    Thanks everyone.
  4. Nov 3, 2011 at 6:52 PM
    #44
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    Red Line 57904 (75W90) Synthetic Gear Oil
  5. Dec 28, 2012 at 5:50 AM
    #45
    jkarov
    jkarov Member
    New Hampshire
    2001 4x4 SR5, V6 Tacoma Xcab bone stock
    A friend of mine works for Toyota dealership. I had to call him for ideas when i couldn't get the front diff filler hex plug out of the carrier. Tried the usual Kroil and PB blaster, didn't help, and tried heat.
    He said to pound right on the filler plug with a brass or plastic hammer, wait a minute, and try hitting it again. Took a while, but it finally came out.
    Don't risk stripping the hex because then they have to do a repair, and it's not cheap
  6. Dec 28, 2012 at 6:47 AM
    #46
    nitrowrench79
    nitrowrench79 Member
    Michigan
    97 2WD 5-lug
    Custom aluminum diamondplate box and tailgate, rear bumper with LEDs, wood bed with stainless hardware and a Pacesetter header.
    I run Lucas 75W90 in my rear diff. Was using 80W90 but switched back to regular gear lube. I agree with others about expensive stuff. If you're not racing or doing something that generates high heat, regular fluid is fine. And use Toyota axle seals when the time comes. Their design and quality is better than aftermarket. Just my experience.
  7. Dec 8, 2015 at 9:56 PM
    #47
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Can anybody call the size on the hex for the front diff drain and fill?
  8. Dec 9, 2015 at 11:51 AM
    #48
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    I recently changed my rear diff (prerunner) fluid at about 35,000 miles. Replaced it with plain old Valvoline 75w90. I don't offroad, I tow once a year, but I do load the truck up sometimes, maybe once a month. This truck is a street truck only used for commuting to my office job. It came out almost as clean as the stuff that went in, and there was almost zero residue on the drain plug magnet. Honestly I would have no problems going 60,000 miles for my situation. It didn't even smell that bad.
    I'm not sure if this helps anyone, but hey, it just might. Haha
  9. Dec 9, 2015 at 12:07 PM
    #49
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    99.99% of them are 10mm. I have seen one 12mm. It was a "fill" plug and the drain on the same diff was 10mm. It was likely aftermarket, some cussing was involved.
  10. Dec 9, 2015 at 1:07 PM
    #50
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    i've used mobil1 synthetic 75w-90 for the past few years and no trouble... changed every 30-35k and comes out generaly as clean as it goes in. never had very many if any shavings on the plug magnet. 242,xxx on the gears and bearings. alot of mild off road and a lot of city w/ about 50% highway.
  11. Dec 9, 2015 at 1:23 PM
    #51
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Thx. That's kinda what I found too. Possibly both 10mm and 12mm on the front diff.
  12. Dec 9, 2015 at 1:26 PM
    #52
    CStoy
    mine are 10mm...dont cheap out and try 3/8'' it doesnt work. just makes for more work.
  13. Dec 9, 2015 at 1:29 PM
    #53
    Toyomonkey59
    Toyomonkey59 Well-Known Member
    James
    Hedgesville Wv
    2012 toyota tacoma Trd 4.0 4x4 Doublecab
    I used mobile one synthetic in front and rear diffs as well as transfer case and royal purple in the tranny. The rear diff was very dirty the front diff wasnt too bad. The tranny I did for good measure because I wasnt sure if it had ever been done and is very notchy 1st to second. I was very pleased with the royal purple in transmission. It helped a lot in trans but didnt totally take away notchyness but have found this is a common characteristic of these trucks. I am a 5 speed 4cyl by the way.
  14. Dec 9, 2015 at 1:31 PM
    #54
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah I got a 1/2" drive 10mm and 12mm on order. I think my 1/4" drive 10mm probably won't cut it.
  15. Dec 9, 2015 at 1:58 PM
    #55
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    I recently changed all of the fluid on my manual 3.4l 4x4. Everything went smoothly except for that darn 10mm Hex drain plug for the front diff......just wouldn't budge. I ended up buying a siphon tube (HF) and siphoned as much of the old oil as I could from the fill plug and refilling it with new gear oil. It was the best I could do. Hope you have better luck w/that darn drain plug!
  16. Dec 9, 2015 at 2:19 PM
    #56
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Did you strip out the hex with the wrench or was it that the threads were frozen? I'm hoping that a 1/2" breaker bar with a 10mm/12mm hex socket should do the trick.
  17. Dec 9, 2015 at 2:27 PM
    #57
    quetzal
    Mario
    Long Beach, CA
    Sorry, I started to strip the head of the bolt so I decided to leave it alone. It appears as though it is a common problem on our trucks.
  18. Dec 9, 2015 at 3:11 PM
    #58
    CStoy
    same here.
    i even tried acetone/ATF mix and pb blaster on mine...even with a proper size socket it wouldn't budge. butane pencil torch and a brass BFH to hit the plug while turning on it with the allen socket worked after much effort...3hrs worth in my case.
  19. Dec 9, 2015 at 3:30 PM
    #59
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
  20. Dec 16, 2015 at 6:40 PM
    #60
    SpE3dF0x
    SpE3dF0x MD bound!
    Fox
    San Antonio
    2013 TRD Tacoma Sport
    Nothing its tooo new!
    Sorry late post. But, can you use all the same oil 75-90W in all parts? Front/Rear and transmission??! Sorry but, just curious I thought the trans and gear oils were different? I've read them that they were the same. In particular Redlines MT90???? Anyone chime in please I'm about to do it this weekend!!!
