Changing my differential fluid.
Discussion in '1st Gen. Tacomas (1995-2004)' started by xJRich5, Aug 1, 2011.
  1. Dec 16, 2015 at 7:10 PM
    #61
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    diffs and transfer case yes. transmission no. it is best to use exactly what the dealer would use in the transmission which i can't remember just now.
  2. Dec 16, 2015 at 7:17 PM
    #62
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I think the answer is IT DEPENDS on the gear oil you choose. I run Amsoil-recommended Severe Gear 75W-90 in my front & rear diffs, transfer case, and transmission.
  3. Dec 16, 2015 at 7:18 PM
    #63
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Also I was thinking automatic transmission. It might be different for a manual.
  4. Dec 16, 2015 at 7:22 PM
    #64
    Norton
    Good point. Obviously, my answer was predicated on the opposite (manual transmission) assumption.
  5. Dec 17, 2015 at 2:15 PM
    #65
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    not in an auto youll need ATF which is very different. yes in both diff's and the transfer case...thats what i do i get a carton of quart jugs in mobil1 synthetic 75w-90 every 30-35k and change all 3 at the same time with the same oil in all...toyota makes their fluids very easy to change. :thumbsup: to drain plugs!
  6. Dec 17, 2015 at 3:07 PM
    #66
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    doesn't the GL-4 specificity only apply to the tranny? Won't any GL4/5 oil work for everything else? I don't even know what I have in my tranny, I bet it's GL4/5. I think the purely GL5 stuff is what you don't want in there.
  7. Dec 17, 2015 at 6:39 PM
    #67
    Norton
    The short answers are yes and yes.
    GL-4 and GL-5 are American Petroleum Institute (API) service characteristic ratings for (spiral-bevel and) hypoid gear lubricants. The primary difference between GL-4 and GL-5 is the amount of extreme pressure additive package. GL-4 has less than GL-5 does. The caution here tends to be with regard to certain manual transmissions. The GL-4 specification is primarily used for those with high yellow metal content (e.g., brass and/or bronze sometimes found in manual transmission syncros). Under certain conditions, the higher additive content can corrode yellow metals. As I understand it, certain lubricants (e.g., Amsoil Severe Gear 75W-90) are safe for use in both applications.
  8. Jan 27, 2016 at 10:53 AM
    #68
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Thanks. My first gen was 10mm top and bottom.
  9. Feb 10, 2016 at 1:17 PM
    #69
    jsway9
    jsway9 Ninja
    Monterey CA
    2000 Toyota Tacoma 4x4 TRD SR5
    Front Relentless Bumper Rear Outdoor Logical Swing Out Front King Coilovers Rear Fox Shocks All Pro Expo. Leaf Springs
    Thank Goodness for this thread!
    About to do The Diffs and Tranny next week for a trip to tahoe
    Veryhelpfulforum likes this.
  10. Feb 10, 2016 at 2:26 PM
    #70
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'm in the middle of doing mine too. Gonna try these 10mm hex drain plugs from Low Range so I can just use a single wrench to change gear oil in the diffs and transfer case.
  11. Jun 23, 2016 at 8:37 AM
    #71
    Tomato1981
    Tomato1981 Well-Known Member
    PROseur likes this.
  12. Jun 23, 2016 at 3:40 PM
    #72
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is correct
  13. Jun 23, 2016 at 4:24 PM
    #73
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Is that the same for the 2.7L 4cyl 2wd?
  14. Jun 23, 2016 at 8:05 PM
    #74
    Digiratus
    Roaming the PNW
    The RedHead
    Pretty much except you don't have a front diff and a transfer case.
    PROseur likes this.
  15. Jun 23, 2016 at 8:38 PM
    #75
    Tomato1981
    Any recommendations for atf? Was going to order toyota brand type IV, but that's not going to work now. Thanks
  16. Jun 23, 2016 at 8:48 PM
    #76
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    What year is your truck?
    It could be the Type IV or WS Fluid.
    RJM
  17. Jun 23, 2016 at 8:52 PM
    #77
    Loco38SUP
    North Seattle, WA
    I use Amsoil 80w-90 Synthetic in both front and rear differentials.
    It was recommended by one of the best gear shops here in the Northwest.
    RJM
  18. Jun 23, 2016 at 8:57 PM
    #78
    Tomato1981
    02' extended cab 3.4l v6 4x4. Any recommendations for atf would be great. Thxs
  19. Jul 1, 2016 at 1:06 PM
    #79
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
