Changing My Lift
Discussion in 'Suspension' started by wayneb03, Jan 27, 2011.
  1. Jan 27, 2011 at 6:25 PM
    wayneb03
    wayneb03 [OP] New Member
    Forks, WA
    07 Tacoma TRD
    Hello. I have a 07 Double Cab TRD Off-Road. Last summer I had Schwab put on a Tuff Country 52907 lift kit. I have BFG ATs, 265/75. Thinking about changing my setup without spending too much cash. I would like a more level look than I am getting now. Doesn't look bad but could be a little higher in the front or maybe a little lower in the back. Just wondering if Bilstein 5100's would be a better lift option than I currently have. Thanks
  2. Jan 27, 2011 at 6:27 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
  3. Jan 27, 2011 at 6:29 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Definitely. They are specifically designed to dampen the stiffer spring rate, unlike you current lift.
  4. Jan 27, 2011 at 6:37 PM
    wayneb03
    Forks, WA
    07 Tacoma TRD
    I will admit I'm not a big off road guy but it seems that the spacer lift is about the worst lift option? Any idea which Bilstein setting would work with my BFG's. I see there seems to be some debate about Bilstein settings and UCAs.
  5. Jan 27, 2011 at 6:42 PM
    TexasTacoma37
    You can set the billys to whatever you like with the 265/75's since they are 32's. Mine are at 1.75, you can see pics in my build thread.
  6. Jan 27, 2011 at 6:50 PM
    wayneb03
    Forks, WA
    07 Tacoma TRD
    Great looking truck. When I had mine lifted they installed an AAL. If I set Bilsteins at 1.75 I would probably need to have it removed to be level?
